Dropped bike off paddock stand now it won't start (Resolved)
Az
PostPosted: 22:28 - 16 Mar 2015    Post subject: Dropped bike off paddock stand now it won't start (Resolved) Reply with quote
Took the bike off the paddock stand and naturally lent it to the left so it would fall onto the side stand (thinking it was down) but I'd forgotten to put it down, so the bike fell on the floor.
Snapped my clutch lever and it snapped in the bracket that holds the lever, which made my clutch unusable via the lever. Also scratched the crash bars lightly, no other visual damage.
Anyway, never thought to try and start the bike after I'd dropped it. It was off when I dropped it & ran spot on before it'd hit the floor.
Replaced the lever today, went to start the bike and nothing...
Turn the key in the ignition, lights on dash come on as usual, headlight works, horns work, everything seemed normal... went to start the bike & nothing, no noises, no anything. The lights on the dash didn't flicker or anything. It's as if I never pressed the starter button at all.
I've tried bumping it twice (in 1st and 2nd) doesn't even sound like it wants to start.
Checked the clutch sensor thing (needs clutch lever in to start) and that's in and secure from what I can see.
Any ideas what could be causing the bike not to start?
wots
PostPosted: 22:39 - 16 Mar 2015    Post subject: Reply with quote
Side stand switch, check there, especially if you had it down whilst on the stand.
Doovy
PostPosted: 22:45 - 16 Mar 2015    Post subject: Reply with quote
Killswitch?
And why, if you leant it to the left, did the clutch lever snap? Confused
Az
PostPosted: 22:46 - 16 Mar 2015    Post subject: Reply with quote
Bike starts in neutral with the side stand down normally, first thing I did was try & start it in N on the side stand with no luck
Az
PostPosted: 22:47 - 16 Mar 2015    Post subject: Reply with quote
DoovyRR wrote:
Killswitch?
Clutch lever is on the left side of the bike? Laughing
Checked the kill switch too Thumbs Up
Doovy
PostPosted: 22:50 - 16 Mar 2015    Post subject: Reply with quote
Az wrote:
DoovyRR wrote:
Killswitch?
This is true. Carry on Laughing
Have you tried starting in gear with the clutch pulled in?
Az
PostPosted: 22:52 - 16 Mar 2015    Post subject: Reply with quote
Tried bumping it, so I guess that counts? Smile
Ariel Badger
PostPosted: 23:05 - 16 Mar 2015    Post subject: Reply with quote
DoovyRR, easy way to remember....Right hand front brake and wanking. Left hand holding laptop whilst wanking and clutch.
Nemo
PostPosted: 23:14 - 16 Mar 2015    Post subject: Reply with quote
Is your bandit Fuel Injected?
Tried crossing the two terminals on the starter solenoid/relay with a screwdriver?
Fuel pump priming?
Tried shorting the clutch switch just in case?
Checked fuses?
Previously owned: Kawasaki KH125, Suzuki GP125, Suzuki GX 125, Honda CB125 TDC '83, Honda ntv 600, Kawasaki ER5, Kawasaki ZZR600, Aprilia RSV 1000 Mille
Now own: Ducati 848 evo
Az
PostPosted: 23:24 - 16 Mar 2015    Post subject: Reply with quote
Fuel pump priming?
Checked fuses?
Carb'd and the bike wasn't on the floor for more than a minute, so doubt the carbs are flooded or oil in airbox.
Shorted th clutch lever switch/sensor thing with a hair clip, again, no luck Rolling Eyes
Ariel Badger
PostPosted: 23:31 - 16 Mar 2015    Post subject: Reply with quote
Pull plugs and check for a spark. Is airbox full of fuel after the spill?
Az
PostPosted: 23:37 - 16 Mar 2015    Post subject: Reply with quote
Haven't checked, will run down and have a look at the air box first and then plugs.
Isit possible that if the bikes been on the floor for seconds it can flood the airbox and foul plugs?
Just to add, I have dropped the bike from standstill before (similar circumstance, forgot side stand want down) Embarassed , dropped it on the floor, broke the clutch lever (but only the round bit on the end of the lever). It started up straight away after I'd picked it up, it'd been on the floor for about the same amount of time as it had this time (which was seconds).
SQL
PostPosted: 23:51 - 16 Mar 2015    Post subject: Reply with quote
Check the clutch switch and also what Ariel Said
Frog
PostPosted: 23:55 - 16 Mar 2015    Post subject: Reply with quote
If you haven't already, try turning off the kill switch for 30 seconds. I thought it was only FI bikes, but some bikes detect a 'crash' and disable starting until this is done.
CBT 23/09/10 - Theory 19/03/11 - Mod1 19/04/11 - Mod2 06/05/11
Bikes: CBF125 (sold 30/10/10-25/09/12) - CB400 24/06/11 (broken) Sad - ER6-f 25/09/2012 Very Happy
Ariel Badger
PostPosted: 23:56 - 16 Mar 2015    Post subject: Reply with quote
I take it from that it was more than a few seconds and a lot of fuel can flow in that time if the tap was open. If it is not in a pool on the floor it will be in the filter.
Az
PostPosted: 00:08 - 17 Mar 2015    Post subject: Reply with quote
You're right, there's fuel in the airbox, not much but a tiny pool of fuel in the bottom of the airbox.
Not saying you're wrong, but curious, why would fuel in the airbox stop it from even trying to turn over? As in there's no response from the bike what so ever when I hit the starter button.
SQL
PostPosted: 00:13 - 17 Mar 2015    Post subject: Reply with quote
Checked the fuses?
Az
Had a look at the clutch switch, all seems good from what little I can see. Also tried shorting it with a hair clip... Still nothing. But I my gut feeling is that it's to do with the clutch switch. It's as if someone's pulled out my clutch switch making the bike unresponsive when you hit the starter.
Also can't find a screwdriver small enough to get the bloody thing off either to have a proper look at it.
Az
PostPosted: 00:14 - 17 Mar 2015    Post subject: Reply with quote
SQL wrote:
Checked the fuses?
Good shout, will have a look.
Az
PostPosted: 00:33 - 17 Mar 2015    Post subject: Reply with quote
Woo! Finally fucking sorted. The ignition fuse had gone, replaced with spare and it fires up first time. I'm a very happy man aha
Thanks SQL! Very Happy Thumbs Up Karma
Also, thanks Ariel, as I now know I need to clean out my airbox Thumbs Up Karma
SQL
PostPosted: 00:42 - 17 Mar 2015    Post subject: Reply with quote
Mr. Green Thumbs Up
Empty the airbox using the drain plug
Az
PostPosted: 00:54 - 17 Mar 2015    Post subject: Reply with quote
Mr. Green Thumbs Up
Will do, off work tomorrow so will do it then Very Happy
Out of curiousity, why would my ignition fuse blow? At first I thought the impact/vibration from the drop caused it to shatter, but on second thoughts that's probably not the reason.
SQL
PostPosted: 00:57 - 17 Mar 2015    Post subject: Reply with quote
Impact was my thinking, but could be unrelated.
Nemo
PostPosted: 01:51 - 17 Mar 2015    Post subject: Reply with quote
The reason I suggested fuses Is because the impact could have pinched a live wire to earth = short circuit = blown fuse.
Check the wiring just to make sure there's no slices in the wire insulation.
Az
PostPosted: 01:57 - 17 Mar 2015    Post subject: Reply with quote
Didn't even realise you'd recommended checking fuses, jus re read your thread, thanks for the suggestion aha Karma
May check through the wires on the weekend. Where exactly should I be looking? Everywhere?
The last post was made 11 years, 210 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 134.06 Kb
