wd40 contact cleaner
Random13
PostPosted: 10:28 - 19 Mar 2015    Post subject: wd40 contact cleaner Reply with quote
Hi All,
can i use wd40 for contact cleaning ?
or should i use brake cleaner ?
or wd40 contact cleaner ?
many thanks
Islander
PostPosted: 13:54 - 19 Mar 2015    Post subject: Reply with quote
Use switch cleaner. It contains a lubricant to protect the contacts as well as a cleaning solvent that won't damage the switchgear but will remove any deposits.
Taught2BCauti...
PostPosted: 16:23 - 19 Mar 2015    Post subject: Reply with quote
Best to use a proper contact cleaner spray, which you can get from Maplins or RS.
There is a specialist contact cleaner marketed under the WD40 name (Click), but normal WD40 leaves a residue that can attract dust and grit, and is also inflammable - I have seen a switch catch fire after being sprayed with normal WD40.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Random13
PostPosted: 13:51 - 24 Mar 2015    Post subject: Reply with quote
many thanks
The last post was made 11 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.67 - MySQL Queries: 13 - Page Size: 38.46 Kb
