BT Infinity - Third Party Router
rideslikean00...
PostPosted: 21:32 - 01 Apr 2015    Post subject: BT Infinity - Third Party Router Reply with quote
I'm thinking of jumping ship from Virgin Media after about 7 years. The speeds have dropped as my area is now oversubscribed and it's annoying me a lot. BT Infinity is available and seems comparable except much better upload speeds.
Thing is, I currently have my old Super Hub 2 set to modem mode so my DD-WRT loaded router can control the WAN/LAN bridge better in terms of port opening, static DHCP IPs, Wake On WAN etc. This is an arrangement I've been using for some years and would like to keep. What I need to know is, can the current BT Home Hub 5 be configured to allow this? Information from a couple of quick Google searches has conflicting info and I don't want to sign up until I know. The technical support lines don't allow me to get through and ask someone direct, they just loop back to assuming you're already a customer with a technical fault and request a phone number for BT which I don't have.
Previous/Current Bikes
2013 Yamaha YBR-125ED -> 1997 Yamaha YZF-1000R Thunderace -> 2009 Yamaha XJ-6 Diversion -> 2007 Yamaha FZ6 Fazer S2
ScaredyCat
PostPosted: 23:50 - 01 Apr 2015    Post subject: Reply with quote
I don't use BT Infinity but I have an FTTC connection and an OpenRetch VDSL modem like the one in the link below. I use a MikroTik router.
This might be useful:
https://edspencer.me.uk/2015/01/18/using-your-own-router-with-bt-infinity/
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
CaNsA
PostPosted: 23:56 - 01 Apr 2015    Post subject: Re: BT Infinity - Third Party Router Reply with quote
What speed line do you have from VM?
Philly46
PostPosted: 01:18 - 02 Apr 2015    Post subject: Reply with quote
I've just took up BT Infinity again after moving and they supplied us with the aforementioned HomeHub 5. You can't put it into modem only mode as I discovered and I ended up purchasing the white Openreach modem from eBay to utilize my TP-Link router.
I stuck the HomeHub upstairs as an access point which works while it blinks repeatedly that it can't make a broadband connection. Laughing
(o.0)
o(")(")
rideslikean00...
PostPosted: 06:11 - 02 Apr 2015    Post subject: Reply with quote
Just the regular 50Mbps one, which at full speed was enough for most things. These days I get an average of 3-5Mbps.
Nice, my router is TP-Link as well, good kit for not much money.
So you're saying that if I purchase this Openreach modem I can use the same BT line, scrap the Home Hub 5 and keep my current setup? Is there more than one kind of this modem, if so which is the best one assuming they're not basically identical.
temeluchus
PostPosted: 06:15 - 02 Apr 2015    Post subject: Reply with quote
sounds more like a fault!
rideslikean00...
PostPosted: 06:21 - 02 Apr 2015    Post subject: Reply with quote
I was told on the phone by the support team yesterday that it sounds like a combination of that and high utilisation by people in my area. It's been ongoing for about 2-3 months though and I don't think it'll ever get fixed.
CaNsA
PostPosted: 12:14 - 02 Apr 2015    Post subject: Reply with quote
What model router with dd-wrt are you using?
rideslikean00...
PostPosted: 13:23 - 02 Apr 2015    Post subject: Reply with quote
It's a TP-Link WR1043ND running Firmware: DD-WRT v24-sp2 (12/22/14). I used to get 80-90Mbps on speedtest.net on the wireless using the MacBook Air when I had a faster BB speed some months ago before I took it down to 50Mbps.
CaNsA
PostPosted: 13:56 - 02 Apr 2015    Post subject: Reply with quote
You might want to consider updating that firmware...
ftp://ftp.dd-wrt.com/betas/2015/04-01-2015-r26635/
Also, check/replace the uplink cable.
rideslikean00...
PostPosted: 15:25 - 02 Apr 2015    Post subject: Reply with quote
Yeah DD-WRT ay need updating, it's all time to do it and test though as I work 50+ hours a week, BH weekend might be time.
Uplink cable is good, problem is with either the SH2 or something between my place and the head end. When I had a long hour on the phone with VM tech support I tried plugging straight in with the SH2 back in full modem router factory reset mode. Speed was just as bad on down, up has been restored to 3Mbps so it means at least I can VNC or TeamViewer into my home systems again. This is with the SH2 back in modem mode and the TP-Link router doing the rest.
Still seriously considering going to BT Infinity. If I can use an Openreach modem and still use a DD-WRT router for the extra features I could get a huge boost to my upload speed, useful for streaming content from my home LAN to anywhere else even for HD content.
Minty
PostPosted: 15:54 - 02 Apr 2015    Post subject: Reply with quote
I went from 30mb (as it was back then) Virgin to 'between 35-65mb' BT Infinty 2. Started at 30mb and slowly dwindled down to 10mb. Now have a slot for Virgin to be reconnected in early May.
Rule out network/home network issues before jumping ship. Thumbs Up
My fingers smell of your mum.
rideslikean00...
PostPosted: 16:00 - 02 Apr 2015    Post subject: Reply with quote
Good advice. I'd rather not have to make yet more changes to infrastructure at home as it seems I do every other week but I bought my Fire TV last week so I could use more WAN streaming services in addition to XBMC for LAN streaming which is next to impossible at the moment.
Minty
PostPosted: 20:22 - 02 Apr 2015    Post subject: Reply with quote
I too feel your pain. If my daughter goes on Netflix or suchlike, everything grinds to a halt for everyone else.
Philly46
PostPosted: 01:21 - 03 Apr 2015    Post subject: Reply with quote
Yeah, I did that when I was living at home before I came to Uni and I've done it again in the new place.
I had VM in Halls and in the evening it was chronic, paying for 50Mb and barely having enough bandwidth to play Battlefield in the afternoon or evening. In the last week we've moved into a new property and while the BT line is 30Mb here, we get 30Mb 24/7 which is a lot more convenient.
(o.0)
o(")(")
Seb
PostPosted: 09:33 - 03 Apr 2015    Post subject: Reply with quote
I had massive issues with VM's fair use policy and traffic that should have been exempt causing my line to go into throttle+packetloss mode. I switched to BT with a house move and frankly, I've never looked back, the unlimited option infinity is reasonably priced, I get a solid 50mbps+ and I've never yet seen anything throttled (13TB uploaded in the last 2 years so lord knows I've tried Smile )
2010 Triumph 1050 Sprint ST
rideslikean00...
PostPosted: 10:38 - 03 Apr 2015    Post subject: Reply with quote
You had to pay for your broadband in Halls? That sucks. When I was in Uni over a decade ago that was all provided as part of the rent. It had what was for the time very fast broadband, it took the consumer side a lot longer to catch up speed wise. We used to do LAN games of Counterstrike with about a dozen people, good times.
BT Infinity is looking like a much better prospect at this point.
Philly46
PostPosted: 14:11 - 03 Apr 2015    Post subject: Reply with quote
It's an optional extra but the provided Wi-Fi was abysmal and locked down so Torrents were night on impossible to use plus we had no idea on monitoring and so forth.
I took out the contract and it was then split between 6 of us so it only worked out to £5 a month.
(o.0)
o(")(")
bacon
PostPosted: 20:08 - 03 Apr 2015    Post subject: Reply with quote
I have BT Infinity and have had a pretty good experience thus far in the first 8 months, my download speeds max out at 8.7MB/s.
I have downloaded a lot in the last couple of weeks since setting up my microserver (currently on 130gb in 2 weeks on my server alone with Sab) with no issues whatsoever. That doesn't include the games I've downloaded/updated on steam, ps plus games or xbox games with gold. I don't get throttled and there is no fair use policy.
Looking at my router I'm currently connected at
Downstream: 77.09 Mbps
Upstream: 19.53 Mbps
wots
PostPosted: 21:31 - 03 Apr 2015    Post subject: Reply with quote
Virgin generally have much faster speeds, but at great cost in terms of reliability. Most people I know who crow about having 100MB+ speeds, will at one time or another, complain about outages and poor speed. My Sister-In-Law has been out for days and had numerous filters put in/removed and various tuning to make it stable. Then offer higher speeds for the same money, which makes their situation worse.
I've had BT Infinity for about 3 years now. I get 60/19, but that is solid all day long. It doesn't matter what I squirt down there speed is always the same (assuming the source is good for the full speed).
Even though I love to have faster speeds, it's fast/reliable enough for me. Can't remember the last time I was without internet.
bacon
PostPosted: 21:38 - 03 Apr 2015    Post subject: Reply with quote
That's reassuring to read, I did have a down time of just over a week a few months back, but that was something to do with the box on the main road, not something in my flat. Don't ask me for the terminology, I'm not hot with ISP jargon.
And yeh, I've not had shit speeds once since having this. I also have an irritating "my dads harder than your dad" kind of friend who runs with VM and his 150Mb line, which he constantly complains about!
PostPosted: 21:46 - 03 Apr 2015    Post subject: Reply with quote
Must be coming up for five years that I've had BT Infinity and it's been 100% problem free.
The last post was made 11 years, 177 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 119.51 Kb
