Fireblade RRT (1996) misfire and ticking noise
pooley_99
PostPosted: 09:39 - 05 Apr 2015    Post subject: Fireblade RRT (1996) misfire and ticking noise Reply with quote
I've changed the spark plugs which were black and sh*ty. The HT leads and coils look ok.. Its a loud ticking noise coming from around the head, hard to hear exactly where, i'd describe it as a tick rather than a knock and its related to the RPM, comes and goes on tickeover. It is there now more than not. In fact putting new plugs in seemed to make it more noticeable. Its also there on acceleration and backfires loads when you get off the power after booting it. Its defo missing. Any ideas?
CBR 900RR Fireblade
serlant
PostPosted: 09:55 - 05 Apr 2015    Post subject: Reply with quote
exhaust leak, will cause a ticking noise, and also allows fresh air in to mix with the unburnt fuel as it comes out of the exhaust port, my VTR1000 used to sound like a gun going off when the manifold leaked at the header and i chopped the throttle closed.
04 CBR1000RR, 1995 Husqvarna TE410, 1998 VTR1000(Sold), 1990 XJ600(sold), 1996 KH125(dead and sold)
wots
PostPosted: 10:01 - 05 Apr 2015    Post subject: Reply with quote
New plugs were the same bog standard plugs, not iridium? My RR-W ran shit on them.
jjdugen
PostPosted: 10:10 - 05 Apr 2015    Post subject: Reply with quote
Hard to say without hearing. I'll go with the header/s leaking, especially if its still on the original mild steel pipes.
Blades don't usually run sooty, if anything they are a little weak as standard. Check the air-fiter isn't clogged rotten and then nothing daft in the carb settings.
Next is CCT an then valve clearances.
pooley_99
yea same NGK plugs... Exhaust leak is a good shout, ill and devise a smoke test.
CBR 900RR Fireblade
pooley_99
PostPosted: 18:08 - 27 May 2015    Post subject: Reply with quote
bit of a late reply but this was a corroded manifold gasket... It had welded itself to the cylinder head over winter!
CBR 900RR Fireblade
serlant
PostPosted: 18:44 - 28 May 2015    Post subject: Reply with quote
3 ponds 19 pence for that advice. Thumbs Up
The last post was made 11 years, 110 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 51.88 Kb
