Destroyed bearings
dsharman1
PostPosted: 22:48 - 09 May 2015    Post subject: Destroyed bearings Reply with quote
Hi, I was on my bike yesterday when the back wheel went wobbly and to cut a long story short, basically one of the rear wheel bearings had totally fallen apart. Now replacement isn't a problem but what I do want to know is what could have caused it, they hadn't been in very long, maybe 1000km max and they are good quality bearings (fag) , any ideas? [/quote][/list]
Aprillia rs 50 2000
derbi city cross 125 2007 (RIP 08/2015)
Honda CG 125 2001
PostPosted: 22:52 - 09 May 2015    Post subject: Reply with quote
My opinion, either:
1) improper installation
or
2) Grease washed out with a jetwash
dsharman1
PostPosted: 23:29 - 09 May 2015    Post subject: Reply with quote
I don't know if this would affect it but the edge which houses the bearings on this side dies have a slit out of it but the bearings are still snug in there
Aprillia rs 50 2000
Honda CG 125 2001
Major Doss
PostPosted: 03:21 - 10 May 2015    Post subject: Reply with quote
Early FireBlades munched RW bearings, just saying. As has been said, do it yourself with quality bearings, and replace the the sprocket carrier one, if fitted, I dunno the bike. Odd that the FAG let go, good brand.... Thinking
dsharman1
PostPosted: 07:58 - 10 May 2015    Post subject: Reply with quote
The bearings were good quality ones, the brand was fag, I was told they were decent, also I did buy the high speed variety.
[quote
[/quote]
I am not aware of there being one on the sprocket, the last one was fitted at the same time as all of the bump there 4 which seem fine which were all fitted by me with guidance from my dad since I haven't done it before
Aprillia rs 50 2000
Honda CG 125 2001
PostPosted: 08:47 - 10 May 2015    Post subject: Reply with quote
There certainly is a bearing in the sprocket carrier.
I just thought of another reason for the bearings to fail prematurely:
3) missing tubular spacer between the wheel bearings
If you look at the colour-shaded photo (or a Hayabusa wheel) in this thread you'll see the spacers shaded red.
https://www.bikechatforums.com/viewtopic.php?t=221851
If either of the two internal ones are missing it will trash the bearings very fast indeed. You'll also probably notice more thread than usual poking through the axle nut.
salem1987
PostPosted: 08:55 - 10 May 2015    Post subject: Reply with quote
Agreed, i had a cbr400 that kept munching rear wheel bearings. Was all because the tubular spacer in between the bearings being missing. When you tighten the wheel up it will put way to much lateral pressure on the bearings.
PostPosted: 10:22 - 10 May 2015    Post subject: Reply with quote
My guess, presuming all components have been fitted correctly, would be a spanner monkey hammering the bearings in by hitting the inner race or the guard rather than the outer race.
evilzed
PostPosted: 16:20 - 10 May 2015    Post subject: Reply with quote
I know one of my rear wheel bearings developed very small amount of play but enough to feel it in the handling, I adjusted the chain about 1k miles prior and used the manuals specified 93Nm of torque on the axle nut however that was on greased threads which increased the torque so was most likely the cause.
I swapped all 3 bearings out (inc sprocket) and used 70Nm instead and all was fixed.
dydey90
PostPosted: 17:15 - 10 May 2015    Post subject: Reply with quote
It's amazing how easy it is to damage a bearing during fitting. I once got told that 80% of failures are in the first two months of service due to rough fittings.
PostPosted: 00:02 - 11 May 2015    Post subject: Reply with quote
If the spacers are in place it shouldn't make any difference. Not until you torque it high enough to start to crush the inner races of the bearings or the steel spacers (and the thread would strip long before then)
K
Stalk
PostPosted: 06:51 - 11 May 2015    Post subject: Reply with quote
I might be wrong but, you say you fitted the high speed ones. C type? If so I believe that they are incorrect for bike wheel bearings as they are designed to go a lot faster and are made loose so that they expand to the right size when in use. Use normal ones.
Feel free to correct me people.
Stalk
evilzed
PostPosted: 08:46 - 11 May 2015    Post subject: Reply with quote
K
Yea the bearings looked new when I was swapping them and thought what you said would be the case, maybe it was just time for them to go it was at 9k miles 93nm sure did feel tight though (borderline scary stripping point) my fazers manual asks for 150nm!!!
dsharman1
PostPosted: 10:27 - 11 May 2015    Post subject: Reply with quote
i think i may have found the culprit, the spacer in the middle of the wheel in between the 2 bearings is a little bit to short so it is not quite up to the bottom of the lip which the bearing sits on so it isn't making contact with the center of the bearing.now just to make a new one up tonight when i get back Sad
Aprillia rs 50 2000
Honda CG 125 2001
PostPosted: 19:10 - 11 May 2015    Post subject: Reply with quote
Might be worth checking the front wheel in case the spacers have been swapped around
K
dsharman1
PostPosted: 11:38 - 12 May 2015    Post subject: Reply with quote
i had the front wheel out when i first got the bike because all bearings needed replacing,and the one in the front is a lot shorter than the rear one. but i have replaced the rear spacer and fitted 2 new bearings and sop far all seems well but i have only gone about 8 miles on them this morning
Aprillia rs 50 2000
Honda CG 125 2001
PostPosted: 12:43 - 12 May 2015    Post subject: Reply with quote
The best way to check for significant axial loading is to leave off the dust seals and mount the whole rotating assembly then spin it by hand. It should spin a good few turns and coast to a stop. If you witness it being 'braked' it's time to investigate.
One thing that's quite common to find is that the bearing seat get's nicked when drifting out the old bearing raising a burr. This causes the new bearing to sit canted on the seat when it's clamped up by the axle. Could be why your tube spacer appears short.
The last post was made 11 years, 153 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.92 - MySQL Queries: 13 - Page Size: 106.4 Kb
