| dsharman1 |
 dsharman1 Two Stroke Sniffer
| Pete. |
 Pete. Super Spammer
 Posted: 22:52 - 09 May 2015 Post subject: |
My opinion, either:
1) improper installation
or
2) Grease washed out with a jetwash ____________________ a.k.a 'Geri'
| Pol Anorl |
 Pol Anorl Banned
 Posted: 23:28 - 09 May 2015 Post subject: |
i had this happen 3 times on my old divvy, 4th time i fitted myself instead of a garage and they where fine..
3 times with bad bearings or badly fitted. ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
20:30:37 Pyro.: I don't sort of like men, I take every advantage to choke on dick.
Jewlio Iglesias: You live in Liverpool - Chances are, the front door has already been kicked off the hinges |
| dsharman1 |
| Pol Anorl |
 Pol Anorl Banned
 Posted: 00:10 - 10 May 2015 Post subject: |
do you buy cheap shit bearings?
don't lie either itll waste our time trying to help ____________________ GOOD GAME BODYGUARD: https://i.imgur.com/8WePGgf.jpg
| Major Doss |
 Major Doss Traffic Copper
 Posted: 03:21 - 10 May 2015 Post subject: |
Early FireBlades munched RW bearings, just saying. As has been said, do it yourself with quality bearings, and replace the the sprocket carrier one, if fitted, I dunno the bike. Odd that the FAG let go, good brand....  |
| dsharman1 |
 Posted: 07:58 - 10 May 2015 Post subject: |
The bearings were good quality ones, the brand was fag, I was told they were decent, also I did buy the high speed variety.
[quote
Early FireBlades munched RW bearings, just saying. As has been said, do it yourself with quality bearings, and replace the the sprocket carrier one, if fitted, I dunno the bike. Odd that the FAG let go, good brand.... Thinking
[/quote]
I am not aware of there being one on the sprocket, the last one was fitted at the same time as all of the bump there 4 which seem fine which were all fitted by me with guidance from my dad since I haven't done it before ____________________ Aprillia rs 50 2000
derbi city cross 125 2007 (RIP 08/2015)
Honda CG 125 2001 |
| Pete. |
 Pete. Super Spammer
 Posted: 08:47 - 10 May 2015 Post subject: |
There certainly is a bearing in the sprocket carrier.
I just thought of another reason for the bearings to fail prematurely:
3) missing tubular spacer between the wheel bearings
If you look at the colour-shaded photo (or a Hayabusa wheel) in this thread you'll see the spacers shaded red.
https://www.bikechatforums.com/viewtopic.php?t=221851
If either of the two internal ones are missing it will trash the bearings very fast indeed. You'll also probably notice more thread than usual poking through the axle nut. ____________________ a.k.a 'Geri'
| salem1987 |
 salem1987 Scooby Slapper
 Posted: 08:55 - 10 May 2015 Post subject: |
| Pete. wrote: | There certainly is a bearing in the sprocket carrier.
If either of the two internal ones are missing it will trash the bearings very fast indeed. You'll also probably notice more thread than usual poking through the axle nut. |
Agreed, i had a cbr400 that kept munching rear wheel bearings. Was all because the tubular spacer in between the bearings being missing. When you tighten the wheel up it will put way to much lateral pressure on the bearings. |
| Polarbear |
 Polarbear Super Spammer
| evilzed |
 evilzed Scooby Slapper
| dydey90 |
 dydey90 World Chat Champion
| Kickstart |
 Kickstart The Oracle
| Stalk |
 Stalk Brolly Dolly
| evilzed |
| dsharman1 |
 Posted: 10:27 - 11 May 2015 Post subject: |
i think i may have found the culprit, the spacer in the middle of the wheel in between the 2 bearings is a little bit to short so it is not quite up to the bottom of the lip which the bearing sits on so it isn't making contact with the center of the bearing.now just to make a new one up tonight when i get back  ____________________ Aprillia rs 50 2000
Honda CG 125 2001 |
| Kickstart |
| dsharman1 |
| Pete. |
 Pete. Super Spammer
 Posted: 12:43 - 12 May 2015 Post subject: |
The best way to check for significant axial loading is to leave off the dust seals and mount the whole rotating assembly then spin it by hand. It should spin a good few turns and coast to a stop. If you witness it being 'braked' it's time to investigate.
One thing that's quite common to find is that the bearing seat get's nicked when drifting out the old bearing raising a burr. This causes the new bearing to sit canted on the seat when it's clamped up by the axle. Could be why your tube spacer appears short. ____________________ a.k.a 'Geri'
The last post was made 11 years, 156 days ago. Instead of replying here, would creating a new thread be more useful? |
