Adjusting Throttle Play - GSR750
TheArchitect
PostPosted: 14:25 - 13 May 2015    Post subject: Adjusting Throttle Play - GSR750 Reply with quote
I have 6-8mm of play in my throttle and it's really annoying me now. I understand the normal for most bikes is 2-3mm.
I'd like to adjust it but want to be sure I'm doing it right. I've seen a few vids of it being done but still not sure which adjuster to adjust and how much.
Can someone please see attached pic and let me know what to adjust and how? I've labelled it on the pic for easy reference. In layman's terms would be best so I don't miss something.
Many thanks
https://i.imgur.com/vqVXije.jpg
GSXR 600 K6 - Stolen
MT09 - Almost stolen
TheArchitect
PostPosted: 14:36 - 13 May 2015    Post subject: Reply with quote
Cheers, Vincent Thumbs Up
When you say "the other end", what do you mean?
TheArchitect
PostPosted: 14:49 - 13 May 2015    Post subject: Reply with quote
Vincent wrote:
Where the cable fixes on the carbs.....is it carbs, or Fi? Not that it matters much in this case.
It's easy to put too much adjustment on those plastic adjusters and the thread can give way or the plastic adjuster splits. I wouldn't want to use up more than half of the adjustment at the handlebars.
It's Fi.
So if I just adjust "A" without taking up too much up, and then a bit on "B" to take up the rest, that should do it?
TheArchitect
PostPosted: 15:15 - 13 May 2015    Post subject: Reply with quote
Vincent wrote:
You have all the adjustment available so you should be OK. The locking ring needs to go clockwise to loosen it then the main part anti-clockwise until it's adjusted enough. Remember to leave a small amount of play.
Many thanks. Will have a go tonight.
The last post was made 11 years, 146 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 60.09 Kb
