Twin headlights & MOT?
stirlinggaz
PostPosted: 22:18 - 19 May 2015    Post subject: Twin headlights & MOT? Reply with quote
hi,
if a bike is fitted with twin headlights, do they BOTH have to work for the MOT?
bike has twin headlights,but its just 1 big unit, with each side separated by a piece of black plastic.
both sides have main/dipped & those wee useless bulbs (T10?) but the glass is cracked on 1 side after a run in with a swan. yes, a f*ckin swan. b*stard nearly killed me with its suicidal tendencies! Shocked
would covering up the broken side be ok?
i was thinking of just taping a piece of black plastic over the one side.
i cut out a template out of cardboard then cut out the shape on thin plastic, the type that ice cream containers are made of.
I then sprayed it black & i could stick it on fairly easy..
i have pulled out the bulbs on the broken side, just in case some light could be seen through my ghetto lense cover.
opinions?
i dont care how it looks, i just want it to pass the MOT.
please dont tell me to buy a new headlight unit, they cost around £150 & have to be ordered & they are like hens teeth 2nd hand.
cheers,
GAZ
grr666
PostPosted: 22:33 - 19 May 2015    Post subject: Reply with quote
I think fitted is the key word here, can you remove the iffy one?
Never mind, just read that with my glasses on,
what you have in mind sounds reasonable, got to be worth a go, I'd get some plain black self adhesive vinyl from eBay
and use that, less of a faff.
https://www.ebay.co.uk/itm/Matt-Black-Vinyl-Wrap-Car-Air-Bubble-Free-Matte-All-Sizes-/190969655428?pt=LH_DefaultDomain_3&var=490212885511&hash=item2c76adb084
SQL
PostPosted: 22:45 - 19 May 2015    Post subject: Re: Twin headlights & MOT? Reply with quote
cheers,
GAZ
Tape all lights and switchgear up and mot it
moonzoomer
PostPosted: 23:21 - 19 May 2015    Post subject: Re: Twin headlights & MOT? Reply with quote
SQL wrote:
cheers,
GAZ
What if he wants to ride at night, use the indicators and horn?
SQL
PostPosted: 23:23 - 19 May 2015    Post subject: Re: Twin headlights & MOT? Reply with quote
Take the tape off Thinking
moonzoomer
PostPosted: 23:28 - 19 May 2015    Post subject: Re: Twin headlights & MOT? Reply with quote
With a daylight MOT? hardly worth the hassle from plod and the insurance company, easier just to remove the faulty headlight as only one with both dipped and high beam is required for a proper MOT, costs nothing and is legal.
SQL
PostPosted: 23:31 - 19 May 2015    Post subject: Re: Twin headlights & MOT? Reply with quote
No such thing as a daylight MOT, you get lights not fitted at time of test, daylight only advisory.
Thats it its a advisory nothing more nothing less.
The same as chain is a bit slack.
Paddy is our resident expert on such matters.
moonzoomer
PostPosted: 23:38 - 19 May 2015    Post subject: Re: Twin headlights & MOT? Reply with quote
A daylight MOT would require a motorbike to have a horn and a rear registration plate.
The testing guidelines state that motorbikes can be exempt from having lamps tested if they meet the following criteria:-
machines which have neither front nor rear position lamps, or have such lamps permanently disconnected, painted over or masked that are:-
only used in daylight hours
not used in times of serious reduced visibility
The following items/lamps are not required to be tested in order for a MOT to pass a daylight MOT test as long as they meet the criteria above.
Front and Rear position lamps
Headlamps
Stop Lamps
Rear Reflectors
Direction Indicators
SQL
PostPosted: 23:40 - 19 May 2015    Post subject: Reply with quote
He has working lights, tape them up for the MOT, untape them after Wink
moonzoomer
PostPosted: 23:45 - 19 May 2015    Post subject: Reply with quote
On a daylight MOT which only permits the bike to used during daylight hours? that would require another full MOT with functioning lights, again much easier and less hassle just to disconnect the faulty light which takes a few seconds to do.
SQL
PostPosted: 23:46 - 19 May 2015    Post subject: Reply with quote
No, with a daylight advisory.
moonzoomer
PostPosted: 23:50 - 19 May 2015    Post subject: Reply with quote
why not simply unplug the lamp connector on the faulty light?
salem1987
PostPosted: 07:36 - 20 May 2015    Post subject: Reply with quote
from personal experience as long as one light works properly you're fine.
PostPosted: 09:13 - 20 May 2015    Post subject: Reply with quote
Tape all lights.
Get it passed with lights not fitted.
Remove tape.
It isn't a daytime MOT as SQL says, it'd merely an advisory. You don't get it tested again with advisories. Done it plenty of times and will be doing again for my triples MOT.
stirlinggaz
PostPosted: 12:10 - 20 May 2015    Post subject: Reply with quote
Hi,
Just quickly read through the replies so apologies if I have missed or misunderstood anything.
I don't want a "daytime mot" which is just a MOT with an advisory to not use the bike after dark.
I want to be able to use the bike at night.
I also dont want to tape up all indicators etc.
the headlight thats fitted, is a sealed unit. So I cannot remove the broken one or even remove the glass as its not available separately, you must buy the complete unit.
I can pull the harness out of the back so nothing lights up on the broken side.
I was gonna cover up the damaged side with something black so the lense isnt visible on the damaged side.
MOT is due now, so no time to wait on a new headlight unit becoming available.
in past 6 months i think I have seen 3 come up on ebay, at prices very near the rrp of a new one!
cheers,
GAZ
PostPosted: 17:36 - 20 May 2015    Post subject: Reply with quote
YOU CAN USE IT WHENEVER YOU WANT WITH THE TAPE REMOVED.
HTH.
<helpful> If you are passing it to sell it on, fix it, if you are going to use it then just tape up for the MOT and remove after. You can ride at night. Brick Wall
The last post was made 11 years, 111 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 91.7 Kb
