| stirlinggaz |
 Posted: 22:18 - 19 May 2015 Post subject: Twin headlights & MOT? |
hi,
if a bike is fitted with twin headlights, do they BOTH have to work for the MOT?
bike has twin headlights,but its just 1 big unit, with each side separated by a piece of black plastic.
both sides have main/dipped & those wee useless bulbs (T10?) but the glass is cracked on 1 side after a run in with a swan. yes, a f*ckin swan. b*stard nearly killed me with its suicidal tendencies!
would covering up the broken side be ok?
i was thinking of just taping a piece of black plastic over the one side.
i cut out a template out of cardboard then cut out the shape on thin plastic, the type that ice cream containers are made of.
I then sprayed it black & i could stick it on fairly easy..
i have pulled out the bulbs on the broken side, just in case some light could be seen through my ghetto lense cover.
opinions?
i dont care how it looks, i just want it to pass the MOT.
please dont tell me to buy a new headlight unit, they cost around £150 & have to be ordered & they are like hens teeth 2nd hand.
cheers,
GAZ |
| grr666 |
 grr666 Super Spammer
| SQL |
 SQL World Chat Champion
| moonzoomer |
 moonzoomer World Chat Champion
| SQL |
| moonzoomer |
| SQL |
| moonzoomer |
| SQL |
 Posted: 23:40 - 19 May 2015 Post subject: |
machines which have neither front nor rear position lamps, or have such lamps permanently disconnected, painted over or masked that are:-
only used in daylight hours
not used in times of serious reduced visibility
He has working lights, tape them up for the MOT, untape them after  |
| moonzoomer |
| SQL |
| moonzoomer |
| salem1987 |
 salem1987 Scooby Slapper
| P.addy |
 P.addy Red Rocket
| stirlinggaz |
| P.addy |
 P.addy Red Rocket
 Posted: 17:36 - 20 May 2015 Post subject: |
YOU CAN USE IT WHENEVER YOU WANT WITH THE TAPE REMOVED.
HTH.
<helpful> If you are passing it to sell it on, fix it, if you are going to use it then just tape up for the MOT and remove after. You can ride at night.  |
The last post was made 11 years, 112 days ago. Instead of replying here, would creating a new thread be more useful? |
