shoulder ache on long trips
Oldie
PostPosted: 06:25 - 22 May 2015    Post subject: Reply with quote
Risers will probably help although I found that changing to a lighter helmet made a bigger difference. Surprising, really, but a few grams makes a big difference (to me anyway).
Taught2BCauti...
PostPosted: 08:03 - 22 May 2015    Post subject: Reply with quote
I had a similar problem when I first started riding, so I undid the handlebars and experimented with different positions until I worked out that I needed to add 30mm risers.
I also swapped the standard screen for a taller one, and that helped to keep the wind off my chest and shoulders.
It would also help me if the foot pegs could be about 2" further forward, but there doesn't seem to be a cheap and easy way to fix this, but I have got used to it now.
The risers and screen did make a big difference though.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
Codge
PostPosted: 09:02 - 22 May 2015    Post subject: Reply with quote
agree about rotating the handlebars, of course you have to adjust the controls accordingly as well but maybe you are gripping too hard? it should be possible to ride a bike with not a lot of pressure on the hands, i put knee pads on my bike to help me hold the machine more with my body rather than through my arms.
Prevarication and procrastination are my worse enemies
Aceslock
PostPosted: 09:04 - 22 May 2015    Post subject: Reply with quote
I agree with Codge. Gripping the handlebars too tight causes your shoulder blades to ache.
Loosen up that grip Thumbs Up Thumbs Up
Previous Bike: Skyjet SJ27
Sold: Yamaha YZF 600 R Thundercat. Sold: ZX636R
Current bike: R1 14B (Beast)
Snowdonia Rider
PostPosted: 09:32 - 22 May 2015    Post subject: Reply with quote
Shoulder blades, isn't that tension? Try doing some sit ups and squats too, strengthen your core, that should help you keep your weight off your shoulders.
hellkat
PostPosted: 11:06 - 22 May 2015    Post subject: Reply with quote
PostPosted: 12:20 - 22 May 2015    Post subject: Reply with quote
https://images.motorcycle-superstore.com/productimages/300/0000_crampbuster_motorcycle_cruise_assist.jpg
Works.
Doomsnite
PostPosted: 12:58 - 22 May 2015    Post subject: Reply with quote
I got one shoulder blade hurtin at the mo.. will check the grip Thumbs Up
Triumph Street Triple-R
Sold: Honda Hornet CB600F-Y / Yamaha YBR125
Oldie
PostPosted: 16:17 - 22 May 2015    Post subject: Reply with quote
If you do decide to fit risers, best to check on your bike-specific forum how easy it is - you'll need enough slack in the various cables otherwise it could be both dangerous and an MOT failure. Even if it's not straightforward, there's usually a workaround. Often is better to go with 20mm risers and no fuss, rather than, say, 30mm blocks and possible pain.
Nobby the Bastard
Harley Gaydar
PostPosted: 17:07 - 22 May 2015    Post subject: Reply with quote
FFS, man up....
Triumph Sprint ST 1050
XBIKER
PostPosted: 00:27 - 23 May 2015    Post subject: Reply with quote
After more than fifteen hours on the bike my arms would feel as though they had crossed over giving me the impression that my left hand was on the throttle and my right on the clutch.
No amount of checking it out , moving hands, touching levers, biting fingers Shocked Shocked etc could rid me of that horrible sensation.
Just had to push on and get the job done. Weird. Shocked
CaNsA
PostPosted: 02:19 - 23 May 2015    Post subject: Re: shoulder ache on long trips Reply with quote
PaulFzs wrote:
Risers?
My sig. Thumbs Up
The Wobbly Orange
PostPosted: 13:10 - 23 May 2015    Post subject: Reply with quote
Are you wearing leathers? I found that my leathers were too tight at one time and it was giving me backache. So I shed a couple of stone in weight, had more room to move and the pain went away. The improved fitness likely helped too.
People tell me I am lovely. How wrong they are!
The last post was made 11 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.15 - MySQL Queries: 13 - Page Size: 96.01 Kb
