| Medicinal_Motocross |
 Medicinal_Motocross Nova Slayer
 Posted: 22:28 - 25 May 2015 Post subject: Snapped cylinder stud |
Along with the other problems i have with my bike today whilst tightening the stud nuts (cylinder onto crankcases) one gave way and snapped the stud half way up I wasnt overly tightening so i put it down to being a weak one the rest had the same amount of pressure with no problems...
In a nutshell what options do i have to repair this without removing the whole cylinder ? Im pretty sure a weld would do it but im clueless. The cylinder is still sitting as it was guessing the other 3 nuts being tight will hold it securely but my question is without the one nut is it going to cause me any issues if i left it as it was? I ran it briefly sounded exactly the same but im hoping a 2stroke fanatic can shed some light on this before the bike ends up in the nearest canal ?  |
| Nobby the Bastard |
| kramdra |
 kramdra World Chat Champion
 Posted: 22:48 - 25 May 2015 Post subject: |
Why were you tightening the cyl head nuts
If you run it, the head will warp and be fucked. Head comes off, stud might be easily removed if protruding, everything back together in an hour or two.
Studs not expensive, why ruin another engine?
Stay away from bikes  |
 - Super Spammer
 Posted: 22:56 - 25 May 2015 Post subject: |
Buy four new studs and strip the top end. Really, you can dismantle that in 15 minutes how can that be too much trouble? ____________________ a.k.a 'Geri'
| kramdra |
 Posted: 13:13 - 26 May 2015 Post subject: .. |
The nuts are in such a position a torque wrench cannot be used (so i believe) but yes im aware i overtightened. Il put it down to experience.
Would it really warp the head in such a short running time?
Theres no stud sticking out from the cylinders hole just my luck it was the shorter front stud of them
It should be possible to remove the top end with engine in frame only thing i might struggle with the engine being in frame is to line up the piston ring grooves, i dont have a stud extractor can the use two nuts on it to lock them together work does anyone know?
It worked on my exhaust studs |
| sickpup |
 sickpup Old Timer
| chris-red |
| Aff |
 Aff World Chat Champion
 Posted: 15:47 - 26 May 2015 Post subject: Re: . |
Have people actually been looking at the pictures he put up?
There is no way he's gonna be able to weld anything to the stud or tap it out with a punch.
However, it's a 2 stroke, it really isn't much effort to pull the head off and replace the stud.
Don't worry about a stud extractor, just put a couple of nuts on it, or attack it with a pair of vice grips. There should be plenty sticking out to play with. ____________________ Current Bikes:Honda 929RR Fireblade, Honda CD200 Benly (Project), Stomp Z2 140
Electric Bike Project |
 Posted: 15:57 - 26 May 2015 Post subject: . |
I tried the two nuts on one of the spare studs i have now they wont come off, even wen put back in because if the nuts come off the studs in secure and wont come out
So i think a stud extractors the most theoretical option ? I take it they dont damage the stud thread in any way when extracting/putting in?
The extractors dont need a certain amount of bolt being there to fit do they? |
| chris-red |
| chris-red |
| chris-red |
| Vincent |
 Vincent Banned
| Vincent |
 Vincent Banned
 Posted: 20:13 - 26 May 2015 Post subject: |
| Vincent |
 Vincent Banned
| Vincent |
 Vincent Banned
 Posted: 21:15 - 26 May 2015 Post subject: |
One thing, the quicker you loosen off the other three nuts, (if you havn't already), the less chance you have of warping the head  ____________________ Space Is Deep |
The last post was made 11 years, 107 days ago. Instead of replying here, would creating a new thread be more useful? |
