fireblade (918) popping brake & indy fuse
mudcow007
PostPosted: 09:41 - 01 Jun 2015    Post subject: fireblade (918) popping brake & indy fuse Reply with quote
changed a fuse in a mates bike at the weekend as he had no brake lights or indicators Shocked
just rang me now to say its happened again.
any ideas?
he was told that the reg/rec was changed recently
WD Forte
PostPosted: 11:16 - 01 Jun 2015    Post subject: Reply with quote
I wouldn't be suspecting the RR if the fuse that protects the
flashers and brake lights ( possibly other stuff too) blows.
I'd be doing stuff like inspecting connectors, related switches, bulb sockets etc
and looking for shorts, chafed cables and owner 'improvements' first
bikers smell of wee
Taught2BCauti...
PostPosted: 11:32 - 01 Jun 2015    Post subject: Reply with quote
If you are sure that all of the bulbs and the fuses are the correct rating, it wouldn't hurt to substitute the fuse with an ammeter, to see how much current is being drawn - ot to put a volt meter across the battery to check the maximum voltage.
If any accessories have been added, like heated grips or spotlights, check where they are getting power from.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
mudcow007
PostPosted: 12:05 - 01 Jun 2015    Post subject: Reply with quote
cheers will do, looks pretty much standard except for a charging cable dangling out from the seat.
will check
ta Thumbs Up
Minty
PostPosted: 14:20 - 01 Jun 2015    Post subject: Reply with quote
My 918 kept blowing the headlight fuse as a wire was arcing behind the clocks. Check for worn wires too.
My fingers smell of your mum.
wots
PostPosted: 19:10 - 01 Jun 2015    Post subject: Reply with quote
Multimeter on battery, measure off, idle and 4K do it, do it now.
My RRW fried the starter solenoid when the RR went.
mudcow007
PostPosted: 08:17 - 09 Jun 2015    Post subject: Reply with quote
twas a loose indicator bulb
all fixed-ed
danke
The last post was made 10 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 2.65 - MySQL Queries: 13 - Page Size: 51.43 Kb
