| Dedge1 |
 Dedge1 Borekit Bruiser
| cormac83 |
This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
 cormac83 Nova Slayer
 Posted: 03:24 - 02 Jul 2015 Post subject: |
Sounds like the cylinder has seized.  ____________________ Suzuki GSX750 Inazuma |
| Robby |
 Robby Dirty Old Man
| Just_James |
 Just_James Could Be A Chat Bot
 Posted: 10:11 - 02 Jul 2015 Post subject: |
Sounds like your clutch may have gone, though it's a little unusual that it's apparently gone so suddenly.
If you put it in gear (with engine off) and try pushing it, is there any drag at all? Or does it just feel the same as being in neutral?
As mentioned above, check to see if you have any free play in the cable first but if it is the clutch and it's at the stage where it's slipping so much that you're not moving at all then you're most likely going to be needing to replace the clutch plates at least. ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125 |
| Dedge1 |
| stickybackbob |
 stickybackbob Trackday Trickster
The last post was made 11 years, 82 days ago. Instead of replying here, would creating a new thread be more useful? |
