Kmx HELP!!
Dedge1
PostPosted: 01:40 - 02 Jul 2015    Post subject: Kmx HELP!! Reply with quote
My Kmx was running fine until today when I was at a set of lights as I put it in 1st gear it wouldn't move at at tried 2nd still nothing. It was as if the chain had came off (it hadn't). The bike starts an ticks over but when I put it in gear it doesn't go any where could somebody give me any idea as to what the problem come be. I've tried starting it up an changing through all the gears be it just won't go😟😟😟
cormac83 This post is not being displayed because it has a low rating (Confusing). Unhide this post / all posts.
Robby
Dirty Old Man
PostPosted: 07:10 - 02 Jul 2015    Post subject: Reply with quote
cormac83 wrote:
Sounds like the cylinder has seized. Sad
No, it doesn't. The bike is starting and running, but not delivering power to the back wheel.
Check the clutch cable adjustment to make sure the clutch is engaging - you should have a few mm of free play at the lever.
Check the sprockets (particularly front) for wear. The front may have worn smooth, in which case it will need a new chain and sprockets.
Just_James
PostPosted: 10:11 - 02 Jul 2015    Post subject: Reply with quote
Sounds like your clutch may have gone, though it's a little unusual that it's apparently gone so suddenly.
If you put it in gear (with engine off) and try pushing it, is there any drag at all? Or does it just feel the same as being in neutral?
As mentioned above, check to see if you have any free play in the cable first but if it is the clutch and it's at the stage where it's slipping so much that you're not moving at all then you're most likely going to be needing to replace the clutch plates at least.
Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125
Dedge1
PostPosted: 17:58 - 02 Jul 2015    Post subject: Reply with quote
Thanks for the replies and help. When the engine isn't running an I put it in gear it's still as if it's in neutral I replaced the clutch plates not to long ago but they were cheap ones to be honest and I didn't replace the steel plates if that would cause them to wear so fast any more info on it would be great help. Thank you. Looks like I may have to strip it down and have a look I will try adjusting it at the lever first tho just incase. Cheers 😉
stickybackbob
PostPosted: 19:33 - 02 Jul 2015    Post subject: Reply with quote
Something working loose on the clutch basket?
The last post was made 11 years, 81 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 48.78 Kb
