Cracked Sump - leaking oil - UPDATED
CVSensei
PostPosted: 18:58 - 14 Jul 2015    Post subject: Cracked Sump - leaking oil - UPDATED Reply with quote
So I just started the first oil change on my brand new MT-07.
Changed filter no problem.
Drained oil no problem.
Went to tighten up the bolt when I noticed there was a crack about 4cm long running underneath the casing. https://imgur.com/A2x4Pq5
I'm sure I didn't over tighten it, I only have a tiny torque wrench and I hardly gave it any effort which makes me think it might have already been there and I just made it worse.
Spoke to dealer and Yamaha assist about warranty and both of them got very tight lipped when I said I was changing the oil myself.
They're picking it up in the morning to take it to the dealer to check it out - anyone have any advice?
2014 Yamaha MT-07 ABS Deep Armour
'If all else fails, read the instructions.' - Grandpa
'Two possibilities exist: either we are alone in the Universe or we are not. Both are equally terrifying.' - Arthur C. Clarke
Sload
PostPosted: 18:59 - 14 Jul 2015    Post subject: Reply with quote
Nothing constructive other then brace for an argument. Might be worth trying to see if this is a common issue on other bikes.
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
Nobby the Bastard
Harley Gaydar
PostPosted: 19:00 - 14 Jul 2015    Post subject: Re: Cracked engine - leaking oil Reply with quote
1) Collect your tool up
2) Throw them in teh bin.
Triumph Sprint ST 1050
CVSensei
PostPosted: 19:16 - 14 Jul 2015    Post subject: Re: Cracked engine - leaking oil Reply with quote
Please.. I'm already on the verge of weeping.
yen_powell
PostPosted: 19:28 - 14 Jul 2015    Post subject: Reply with quote
Is there a crush washer missing between the bolt and the engine case or can I just not see it?
XT1200Z and a DR350 in bits
CVSensei
PostPosted: 19:29 - 14 Jul 2015    Post subject: Reply with quote
There was no washer there.. Should there be?!
PostPosted: 19:33 - 14 Jul 2015    Post subject: Reply with quote
Going by the state of the sump plug I'd say you over-tightened it and had the spanner slip off too. The dealer is going to say it's user-inflicted damage IMO
CVSensei
PostPosted: 19:35 - 14 Jul 2015    Post subject: Reply with quote
I don't see how I could have overtightened it though.. It took all of my might to unscrew the bloody thing, I gave about half the force to tighten it back up..
PostPosted: 19:46 - 14 Jul 2015    Post subject: Reply with quote
Yamaha won't replace that Laughing
Sump for me is done up with fingers until washer presses against casing and maybe, just maybe 1/8 turn. 1 finger at end of spanner/ratchet. No more should be needed.
Can you buy just the sump...
First oil change. Y u no free dealer.
Az
PostPosted: 19:47 - 14 Jul 2015    Post subject: Reply with quote
A quick google of MT07 sump plug returns images of it with a washer on the sump plug. Whether the lack of washer caused the split, I'm unsure.
spannermonkey...
PostPosted: 19:49 - 14 Jul 2015    Post subject: Reply with quote
It's been Over tightened, mechanics don't lie. What torque is your sump plug, you'll be surprised you can over torque very easy. You should a crushable washer to seal the bolt between the sump, copper or bonded washer type. Best bet to source a replacement sump and fit that. Unless you can find a man who can weld alloy.
Because you've serviced it yourself the warranty many not be covered as the dealers like to do everything and charge a fortune for doing not a lot.
I've been there and done this myself on a Suzuki a few years back, cracked the sump and stripped the thread. I learnt my lesson, young and stupid and brought a torque wrench best thing in the tool box.
Current machines - Aprilia RS250. Kawasaki H1A 500. Past machines - Kawasaki ZX7r P6, Yamaha RD250E (the one that got away), BSA Racing bantam (revs over 10'000 sweet as), Yamaha RXS100, Suzuki GP100, Suzuki GS500K2 - best all year machine ever - come rain, sleet and snow just epic.
PostPosted: 19:53 - 14 Jul 2015    Post subject: Reply with quote
Actually, having taken another look at it, It looks like a bolt that has been wrung-off with a six-sided socket in a nut gun. If it really was as tight as you say then the damage could have been done by the monkey that assembled from the crate. Unfortunately, you're never going to get the dealer to admit to it all the time you have a hole in your, err, sump.
CVSensei
PostPosted: 20:23 - 14 Jul 2015    Post subject: Reply with quote
Had another look and it does actually have the washer.
I just don't understand how if I really did damage it myself by over tightening then how did the monkey who put it together not crack it? It may as well have been welded together I had to put all my body weight on it to loosen it at all!
I kinda figured I'm in the shit now regarding the warranty. Guess I just gotta take that hit. Worst part about it though is this is the first of my 10 day holiday and the dealer has estimated a minimum of 3 weeks to fix it. /Sigh
PostPosted: 20:37 - 14 Jul 2015    Post subject: Reply with quote
Buy new sump, fit new sump.
Good news - New sump is only £76.55 plus vat.
Bad news - they are on back-order.
https://www.fowlersparts.co.uk/parts/5428532/mt07-2014-1ws1-europe-mat-gray-metallic-3/oil-cleaner
CVSensei
PostPosted: 20:59 - 14 Jul 2015    Post subject: Reply with quote
Already been picked up and delivered to dealer, I will leave it in their capable, money-grabbing hands. Crying or Very sad
PostPosted: 21:04 - 14 Jul 2015    Post subject: Reply with quote
Shame, coz I was just going to offer to weld it up for you whilst they order up a new sump.
delsol
PostPosted: 21:56 - 14 Jul 2015    Post subject: Reply with quote
That is quite a gesture, humanity, faith restored and all that.
PostPosted: 22:20 - 14 Jul 2015    Post subject: Reply with quote
I'm surprised that the threads didn't strip before it cracked.
Supposition: sump was already cracked by the bolt being powered in, bouncing on the spanner or socket handle to free it finally split it.
Sadly it's likely impossibru for you to prove it.
The thing that's really puzzling me, what I just don't understand, is why on earth you told them that it had gone while you were spannering it yourself.
Ring-ring, "WTF Yamaha, new bike is leaking oil, fix it fix it fix it."
PostPosted: 22:25 - 14 Jul 2015    Post subject: Reply with quote
Are you 100% certain that when it was a pig to unscrew you were turning it the right way? Quite easy to do.
K
evoboy
PostPosted: 23:14 - 14 Jul 2015    Post subject: Reply with quote
K
This.
The sump bolt will be fitted from the factory. As to why there is no washer on there, that might be something to bring up as it shouldn't fall off the plug once crushed meaning it may not have been there to start with.
If they honour it ill be amazed, but stranger things have happened...
APT Motorcycles
Taught2BCauti...
PostPosted: 10:22 - 15 Jul 2015    Post subject: Reply with quote
Wouldn't the first oil change normally be done by the dealer as part of the first free service? Just curious as to what motivated you to do it yourself.
I use a 4" long 1/4" drive ratchet for tightening drain bolts - even the smallest torque wrench on the lowest setting could be too much (unless it's a good 'un).
Never seen a sump go like that though, without stripping the threads as well, so my guess is material failure.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
CVSensei
PostPosted: 11:25 - 15 Jul 2015    Post subject: Reply with quote
Pete
That is incredibly generous of you, I didn't even realise that was a possibility. Thank you for the offer mate Karma
Roger
I am asking myself the same question. Innocent old me see's split in brand new bike, panics, calls the authorities and tells them the truth. My head is far more level today, and overflowing with regrets.
K
Well now you say that you have me doubting myself but i'm about 85% sure I was doing it correctly.. Lefty loosy, righty tighty and all that.
evoboy
I think there was actually a washer there, I've never dealt with a 'crush washer' before but there was what I think was a washer pretty much welded to the sump plug. I thought it was part of the bolt the first time round until further inspection.. I couldn't get it off but I presume that's what you're talking about.
Taught2BCautious
Yeah it's first service was coming up in 200 miles but I was planning on a long trip this week and haven't changed or topped up since I bought it. And the oil light was coming on which I realise now might be an important point in this battle. I presumed it just meant it wanted changing.
We live and we learn, thanks for all your replies Thumbs Up
Just_James
PostPosted: 11:50 - 15 Jul 2015    Post subject: Reply with quote
Good attitude Thumbs Up
Think it will be a case of hope for the best but expect the worse with this one but hope it goes your way.
Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125
The last post was made 11 years, 83 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.39 - MySQL Queries: 13 - Page Size: 137.82 Kb
