Do you use battery charger and which one?
Oximiser 900
5%
 5%  [ 2 ]
CTEK XS 0.8
8%
 8%  [ 3 ]
Optimate 4
20%
 20%  [ 7 ]
Other
51%
 51%  [ 18 ]
Do not use any
14%
 14%  [ 5 ]
Total Votes : 35
Val
PostPosted: 13:58 - 19 Jul 2015    Post subject: Do you use battery charger and which one? Reply with quote
If you use it do you have it permanently conected?
Just curious.
I use Oxford Oximiser 900 permanently connected (it has short permanent connection lead included in the box):
https://www.amazon.co.uk/dp/B005X8RAIE/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=569136327&pf_rd_s=lpo-top-stripe&pf_rd_t=201&pf_rd_i=B000R5B386&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_r=1Z7MCMFG29Z2QF0VM3YZ
I have been looking also at:
CTEK XS 0.8 (you need to buy permanent connection comfort lead separetely):
https://www.ctekchargers.co.uk/ctek-xs08.php
Optimate 4 (it has short permanent connection lead included in the box):
https://www.amazon.co.uk/OptiMate-4-Battery-charger-conditioner/dp/B000R5936U
CaNsA
PostPosted: 14:03 - 19 Jul 2015    Post subject: Reply with quote
I have 2.
A Ctek and some other random charger.
Both were free with a bike mag sub.
No way of having a trickle charge thing setup here.
ADSrox0r
PostPosted: 14:05 - 19 Jul 2015    Post subject: Reply with quote
Optimate, but it's only ever hooked up during winter and even then that's only if I'm not using the bike for over a week (hardly ever)
FretGrinder
I have a CTEK, had nothing but good results from it, definitely worth the money Thumbs Up
Yamaha MT-09
ಠ_ಠ
stirlinggaz
PostPosted: 15:21 - 19 Jul 2015    Post subject: Reply with quote
Hi,
I also have the oxford 900 (was a xmas prezzie Smile )
It does everything I need, including rescuing batterries I thought were f*cked. some as low as 5v.
its not connected to any of my bikes permanently but its always wired up to one of my spare batteries. (you never know when your gonna need a fully charged battery, right?)
I guess anythings better than a car charger...or no charger...
cheers,
GAZ
PostPosted: 15:38 - 19 Jul 2015    Post subject: Reply with quote
Aldi/Lidl jobbie. I use it when I have a flat battery.
wr6133
PostPosted: 15:45 - 19 Jul 2015    Post subject: Reply with quote
I don't trickle charge as bikes are outside. For flat batteries I use some £5 ebay special that just looks like a plug with some clips on wires. It does the job.
PostPosted: 15:53 - 19 Jul 2015    Post subject: Re: Do you use battery charger and which one? Reply with quote
B6 'hobby charger'.
If you need to leave a battery charger permanently connected, it generally means you need a new battery of have a problem with the electrics.
talkToTheHat
PostPosted: 15:59 - 19 Jul 2015    Post subject: Reply with quote
Hein Gericke jobby that has bulk charge and maintenance functions. Leave it connected overnight once in a while over winter if i'm doing short runs and using all the heated bits. Actually needing it is a sign i need a new battery.
Bandit. does. everything.
1198
PostPosted: 16:31 - 19 Jul 2015    Post subject: Re: Do you use battery charger and which one? Reply with quote
G wrote:
B6 'hobby charger'.
Or your bike(s) has / have an alarm or immobiliser, you work away and don't to ride them as often as you'd like?
MarkJ
PostPosted: 16:39 - 19 Jul 2015    Post subject: Reply with quote
I have a CTEK MXS 5.0, which can do bikes, cars & AGM batteries. It has a desulphate mode and also recondition mode. While the charger is expensive (£50-60) it has brought two batteries back from the dead with the recondition function so it's paid for itself Thumbs Up
I've had Oxford and Datatool chargers in the past and both have died within a couple of years. CTEK charger is still going strong.
Chuffin Nora
PostPosted: 16:47 - 19 Jul 2015    Post subject: Reply with quote
Yes, I use one.
It's made by the Mitsutachiwakinikkoshima* Corporation (Japan) Ltd.,
and permanently attached to the front-L/H side of my bike's engine; does exactly what it says on the tin/steel/alloy, supplying a great deal more charge to the battery than that which of the battery is demanded.
Weird, eh?
*I made that up.
There's a fine line between integrity
PostPosted: 16:56 - 19 Jul 2015    Post subject: Re: Do you use battery charger and which one? Reply with quote
I'd prefer to have the alarm disconnected and a better alarm unit where it's stored in that case - but yes, I did say 'generally' Smile.
talkToTheHat
PostPosted: 17:13 - 19 Jul 2015    Post subject: Reply with quote
Alarm scares cats and tourists.
stonesie
PostPosted: 20:47 - 19 Jul 2015    Post subject: Reply with quote
Optimate 3+
I don't use it if the bike is in use, so only when there's ice about but it works well and the connection lead is tucked away under the seat rather than flapping in the breeze...
Avoid the really cheap Oxford one, a friend is on her 3rd in as many years, why she keeps buying the same again is beyond me.(Feminine logic perhaps)
PostPosted: 20:51 - 19 Jul 2015    Post subject: Reply with quote
Oximiser 601 that I've has for 4 years and before that a Lidl wallwart type charger that lasted 6 years.
bugeye_bob
PostPosted: 21:11 - 19 Jul 2015    Post subject: Reply with quote
I have two lidl battery chargers, both get pretty constant use and are lasting well.
Islander
PostPosted: 21:39 - 19 Jul 2015    Post subject: Reply with quote
I have two optimate 4s, one is permanently connected to the Hornet when it's not being used to stop the alarm from flattening the battery, the other is mostly used to keep a couple of spare batteries topped up and ready for use.
They've never caused a problem or missed a beat and have recovered a couple of batteries that would have been written off otherwise. Smile
Fidge This post is not being displayed because the poster is banned. Unhide this post / all posts.
bamt
PostPosted: 23:22 - 19 Jul 2015    Post subject: Reply with quote
CTEK MXS 5 here too - chosen as it does also support car batteries. Whilst a lower charge rate would work, my car has a rather large battery and if I need an emergency charge I want it to be relatively quick.
I only use the charger normally on Mrs Bamt's bike which doesn't move much over winter. Also used for an initial charge on the new battery for my bike, but otherwise as I do a decent distance every day on the bike it doesn't normally need a top-up.
andyscooter
PostPosted: 08:02 - 20 Jul 2015    Post subject: Reply with quote
absaar motorcycle 6/12volt and car charger
should of cost about 100 quid but bought it when I was in the trade for about 30 Laughing
weasley
PostPosted: 09:43 - 20 Jul 2015    Post subject: Reply with quote
Optimate 3. I'm on my second - the first lasted about 5 years then gave up. This one is several years old now. I generally keep the bike plugged into it when it is at home; I attached the short fly-lead and also use this for providing power to my satnav or charging my phone when out and about. The Optimate saved my previous battery and extended its life by about 6-7 years; in fact I only recently put a new battery in my 1997 bike - the one I replaced was the factory-fitted one. I have a Datatool 3 which has never caused any problems but is the main reason for the Optimate.
rubyhorse2
PostPosted: 09:47 - 20 Jul 2015    Post subject: Reply with quote
only ever use mine if i'm leaving the bike for several weeks or over winter.
bikertomm
PostPosted: 10:45 - 20 Jul 2015    Post subject: Reply with quote
I need to get one but never get round to doing it. So will follow this thread with interest. Thumbs Up
1198
PostPosted: 11:09 - 20 Jul 2015    Post subject: Reply with quote
I have one, and cycle it between bikes overnight when required. I don't leave a bike plugged in permanently.
The last post was made 11 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 2.06 - MySQL Queries: 15 - Page Size: 128.99 Kb
