| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
 Posted: 23:00 - 28 Jul 2015 Post subject: R clips. |
Wiping down my bike today I noticed one of the R clips is missing from one of the front calipers on my Fazer I went to the local motorcycle spares for a replacement but unfortunately he did not have the correct size I took the smallest he had anyway but it pokes out and is bugging me.
Does anyone know where I can obtain one of the correct size?
Bike; FZS 600.
https://images.wemoto.com/full/BRAKE_FITTINGS/10014156.jpg
Wemoto stock them with the pin for £3 each plus postage however I would like to buy a dozen which should last a life time over the counter. |
| kramdra |
 kramdra World Chat Champion
 Posted: 23:25 - 28 Jul 2015 Post subject: Re: R clips. |
https://www.ebay.co.uk/itm/360986777659 (I have no idea what size you need)
For securing brake pad pin..I dont like.. never had that sort of calliper and much prefer the screw in type pin.
For any other uses, split pins are significantly cheaper in qty and they can be snipped down to correct size - But do not use for brake pad pins! |
| G |
 G The Voice of Reason
| Suntan Sid |
 Posted: 23:39 - 28 Jul 2015 Post subject: |
I was looking for small R clips on Saturday.
I went to a local, independent, motor factor, mainly car stuff, 20p each in the smallest sizes. I just took in the ones I wanted and they matched them! ____________________ "Everybody needs money, that's why they call it money!"  |
| Raffles |
 Raffles World Chat Champion
| kramdra |
 Posted: 00:30 - 29 Jul 2015 Post subject: Re: R clips. |
| P.addy |
 P.addy Red Rocket
 Posted: 07:26 - 29 Jul 2015 Post subject: |
Why I do like the cut of his jib  |
| davebike |
 davebike World Chat Champion
 Posted: 08:04 - 29 Jul 2015 Post subject: |
Any Motorcycle workshop will have them
Most car places as well ether used on lots of car brakes too ! ____________________ Dave
NC750Xdct + others at work !
[email protected] |
| Rogerborg |
 Rogerborg nimbA
| Islander |
 Islander World Chat Champion
| Busa1340R |
 Busa1340R Nova Slayer
 Posted: 10:33 - 29 Jul 2015 Post subject: Re: R clips. |
| Rogerborg wrote: | | kramdra wrote: | For any other uses, split pins are significantly cheaper in qty and they can be snipped down to correct size - But do not use for brake pad pins! |
Genuine question, why not? |
Because split pins are softer and not good for shear forces..........
https://en.wikipedia.org/wiki/R-clip
https://en.wikipedia.org/wiki/Split_pin ____________________ Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc |
| Islander |
| kramdra |
| Beehive Bedlam |
| Copycat73 |
 Copycat73 World Chat Champion
| bugeye_bob |
 Posted: 14:39 - 29 Jul 2015 Post subject: |
| Fizzer Thou |
| DanRLee |
 DanRLee Two Stroke Sniffer
| Tiff |
 Tiff Nitrous Nuisance
 Posted: 20:34 - 30 Jul 2015 Post subject: |
Pop into a Fiat dealer- they are used on their calipers and are the right size. Probably pennies each.
Or.
https://www.ebay.co.uk/itm/50-X-R-CLIPS-PINS-TO-SUIT-BRAKE-DISC-PAD-PIN-RETAINING-CLIP-CALIPER-SMALL-BR6-/280969286247 ____________________ 1996 Kawasaki GPZ1100s,1996 VFR750,1980 BMW R80,1982 Kwak Z250B,1992 ZZR1100C,1996 BMW K1100LT,1994 Kwak ZZR600E,1993 BMW R1100RS,1992 ZZR 600D,1988 BMW K100LT,1998 Aprilia Pegaso 650,1994 Suzuki RF900,1991 Yamaha XJ600, 1988 Honda Dominator,1992 Kwak KMX125,1987 Yamaha RD50MX,1984 Honda MBX50.1984 Honda Superdream 125 |
| kramdra |
| Busa1340R |
 Posted: 17:03 - 31 Jul 2015 Post subject: |
| Islander wrote: | They aren't exposed to shear forces though. |
I knew someone would say that, and for the most part I would agree.
I think it's a belt and braces approach (it is the brakes after all!) to a problem that doesn't really exist.......except maybe in this scenario.
You have a multi piston opposed piston caliper which you routinely neglect. The brake dust and generic crud build up and cause the pin to stick/seize in the hole at the back of the inboard pad. When the brakes are applied, you will then be attempting to push the pin out through the open ended hole on the outboard side of the caliper, No? Have you tried to stop a piston moving against lever pressure? ____________________ Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc |
The last post was made 11 years, 83 days ago. Instead of replying here, would creating a new thread be more useful? |
