R clips.
kramdra
PostPosted: 23:25 - 28 Jul 2015    Post subject: Re: R clips. Reply with quote
https://www.ebay.co.uk/itm/360986777659 (I have no idea what size you need)
For securing brake pad pin..I dont like.. never had that sort of calliper and much prefer the screw in type pin.
For any other uses, split pins are significantly cheaper in qty and they can be snipped down to correct size - But do not use for brake pad pins!
PostPosted: 23:38 - 28 Jul 2015    Post subject: Re: R clips. Reply with quote
Little R clips are common in RC models, especially cars.
If you can't find any cheap, can have a look around as I've got loads, but not sure if I've got them down here and they'll probably be a bit buried if so.
Suntan Sid
PostPosted: 23:39 - 28 Jul 2015    Post subject: Reply with quote
I was looking for small R clips on Saturday.
I went to a local, independent, motor factor, mainly car stuff, 20p each in the smallest sizes. I just took in the ones I wanted and they matched them!
Raffles
PostPosted: 23:46 - 28 Jul 2015    Post subject: Re: R clips. Reply with quote
MrGs1 wrote:
Does anyone know where I can obtain one of the correct size?
Padgetts in Batley will be able to supply the correct parts and may even keep them in stock. Alternatively, you could learn to live with your current set-up or simply stick in a short piece of wire or a small nail.
kramdra
PostPosted: 00:30 - 29 Jul 2015    Post subject: Re: R clips. Reply with quote
https://www.pixbud.com/photo/full/2056
PostPosted: 07:26 - 29 Jul 2015    Post subject: Reply with quote
Why I do like the cut of his jib Shocked
davebike
PostPosted: 08:04 - 29 Jul 2015    Post subject: Reply with quote
Any Motorcycle workshop will have them
Most car places as well ether used on lots of car brakes too !
Dave
NC750Xdct + others at work !
[email protected]
PostPosted: 08:49 - 29 Jul 2015    Post subject: Re: R clips. Reply with quote
Genuine question, why not?
Islander
PostPosted: 09:49 - 29 Jul 2015    Post subject: Reply with quote
Same question. ^^
I've had a few bikes that had them fitted to the caliper pins as standard. With the ends are bent over so that they can't slip out they're actually more secure than an R clip.
I wouldn't hesitate to use them if that was all I had in the toolbox.
Busa1340R
PostPosted: 10:33 - 29 Jul 2015    Post subject: Re: R clips. Reply with quote
Because split pins are softer and not good for shear forces..........
https://en.wikipedia.org/wiki/R-clip
https://en.wikipedia.org/wiki/Split_pin
Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc
Islander
PostPosted: 11:28 - 29 Jul 2015    Post subject: Reply with quote
They aren't exposed to shear forces though. They were standard in Brembo calipers for a long time and in some Honda calipers too.
They're also used to lock castellated nuts in place on spindles.
Nope, I'd be happy to use a split pin to hold a caliper pin in place.
kramdra
PostPosted: 11:45 - 29 Jul 2015    Post subject: Reply with quote
Fair enough if standard, as I said, Ive never used for that purpose.
I consider split pins more secure, but if internal of the pad space? would be bitch to get out.
Copycat73
PostPosted: 14:36 - 29 Jul 2015    Post subject: Reply with quote
I got a box of them from Halfords of varying sizes and thicknesses
I know its a bit expensive if you only want one but at £7.99 you will then have lots of spares Thumbs Up
https://www.halfords.com/motoring-travel/tools-diy/fuses-electricals-fixings/halfords-assorted-r-clip
caveat emptor
bugeye_bob
PostPosted: 14:39 - 29 Jul 2015    Post subject: Reply with quote
https://www.xtools.co.uk/silverline-r-clips-pack-150pce-783127.html?language=en¤cy=GBP&gclid=Cj0KEQjw8-GtBRCMl7m54PzgjNQBEiQAIZckvytPnNDMBKdmI2i0c2SWJGXA4OcyfmIyHOQn_tOKqK4aApSp8P8HAQ
Fizzer Thou
PostPosted: 02:12 - 30 Jul 2015    Post subject: Re: R clips. Reply with quote
MrGs1 wrote:
Wiping down my bike today I noticed one of the R clips is missing from one of the front calipers on my Fazer I went to the local motorcycle spares for a replacement but unfortunately he did not have the correct size I took the smallest he had anyway but it pokes out and is bugging me.
Bike; FZS 600.
https://images.wemoto.com/full/BRAKE_FITTINGS/10014156.jpg
Wemoto stock them with the pin for £3 each plus postage however I would like to buy a dozen which should last a life time over the counter.
If you need just the one/maybe two then PM me your address and I will send you some in the post Wink Thumbs Up
Always have a 'Plan B'
DanRLee
PostPosted: 17:30 - 30 Jul 2015    Post subject: Reply with quote
Once bent one of the mrs hair grips into a make shift clip
Six Strings & Two Wheels!
Tiff
PostPosted: 20:34 - 30 Jul 2015    Post subject: Reply with quote
Pop into a Fiat dealer- they are used on their calipers and are the right size. Probably pennies each.
Or.
https://www.ebay.co.uk/itm/50-X-R-CLIPS-PINS-TO-SUIT-BRAKE-DISC-PAD-PIN-RETAINING-CLIP-CALIPER-SMALL-BR6-/280969286247
1996 Kawasaki GPZ1100s,1996 VFR750,1980 BMW R80,1982 Kwak Z250B,1992 ZZR1100C,1996 BMW K1100LT,1994 Kwak ZZR600E,1993 BMW R1100RS,1992 ZZR 600D,1988 BMW K100LT,1998 Aprilia Pegaso 650,1994 Suzuki RF900,1991 Yamaha XJ600, 1988 Honda Dominator,1992 Kwak KMX125,1987 Yamaha RD50MX,1984 Honda MBX50.1984 Honda Superdream 125
kramdra
PostPosted: 21:54 - 30 Jul 2015    Post subject: Reply with quote
MrGs1 wrote:
My quest goes on.
what was wrong with ebay? I did not link the correct ones, but there are plenty on there and cheap.
I believe 23mm length is correct one for 5-6mm diameter shaft..
PostPosted: 21:58 - 30 Jul 2015    Post subject: Re: R clips. Reply with quote
That is truly idiotic. Why would someone deliberately arrange something to hold the pads at an angle to the disc?
Busa1340R
PostPosted: 17:03 - 31 Jul 2015    Post subject: Reply with quote
I knew someone would say that, and for the most part I would agree.
I think it's a belt and braces approach (it is the brakes after all!) to a problem that doesn't really exist.......except maybe in this scenario.
You have a multi piston opposed piston caliper which you routinely neglect. The brake dust and generic crud build up and cause the pin to stick/seize in the hole at the back of the inboard pad. When the brakes are applied, you will then be attempting to push the pin out through the open ended hole on the outboard side of the caliper, No? Have you tried to stop a piston moving against lever pressure?
The last post was made 11 years, 84 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 117.06 Kb
