Increase bar grip diameter?
PostPosted: 07:26 - 19 Jul 2015    Post subject: Increase bar grip diameter? Reply with quote
I want to increase the diameter of the grips on my bike, but without removing the original (factory heated grips). Looking for suggestions on how do make a tidy and durable job of it.
Vracktal
PostPosted: 07:31 - 19 Jul 2015    Post subject: Reply with quote
Obvious answer, but put a set of grip covers on? They're usually foam so the heat from the grips still bleeds through.
https://www.amazon.co.uk/Grip-Puppies-Throttle-Motorcycle-CoverCover/dp/B00F6S7ER8
2007 BMW R1200R: On road
2009 BMW G650X Challenge: On road
1975 Norton Commando 850: Off road, awaiting recommissioning
PostPosted: 07:54 - 19 Jul 2015    Post subject: Reply with quote
That'll be the sort of thing. Any idea on the foam density and how durable they are? I don't want something that'll fall apart after 3 months use.
PostPosted: 08:36 - 19 Jul 2015    Post subject: Re: Increase bar grip diameter? Reply with quote
What root problem are you solving?
If it's a sore throttle hand, I'd suggest a Cramp Buster.
PostPosted: 08:52 - 19 Jul 2015    Post subject: Reply with quote
Sore hands, yes. Never suffered it on my first one which was identical except 1) the grips were ever so slightly fatter and 2) I wore thicker gloves when I bought it in March.
Extra vibration damping would also be a bonus so I'm going to try those foam covers.
PostPosted: 08:57 - 19 Jul 2015    Post subject: Reply with quote
Use Busa
/win.
Shifty
Gunhawk
PostPosted: 09:01 - 19 Jul 2015    Post subject: Reply with quote
Had my grip puppies on for 4 months or so, they are fantastic quality and don't show any sign of wear yet. Would definately recommend
Current: Honda VFR800 VTEC
Previous: Honda CBF125, Honda XL650 Transalp, Honda CBR600f3
CBT: 19/5/12 > Theory: 06/08/12 > MOD1: 29/08/12 > MOD2: 16/10/12
PostPosted: 09:03 - 19 Jul 2015    Post subject: Reply with quote
Why did you fit yours?
defblade
PostPosted: 10:55 - 19 Jul 2015    Post subject: Reply with quote
I had Grip Puppies on my BMW because the standard grips were just too thin for my giant hands, and they were already heated (normally I just stick heated grips on and they're thicker anyway). Showed no sign of wear at all, but did take a few goes to get them to stick down well with hairspray.
PostPosted: 10:59 - 19 Jul 2015    Post subject: Reply with quote
Well that's it then grip puppies it is. I also have large hands, wear size 10 gloves.
PostPosted: 14:02 - 19 Jul 2015    Post subject: Reply with quote
They're a bit skinny even for my stubby digits. Laaaaaydies grips.
BMW owner wrote:
Thinking
Might give them a try. Good thread, have a biscuit. Thumbs Up
ADSrox0r
PostPosted: 14:09 - 19 Jul 2015    Post subject: Reply with quote
I use Grip Puppies and have heated grips, they're the bee's bollocks. Current set went on around 7000 miles ago and the clutch side is only just starting to show signs of wear.
I've had a couple of sets of them and my tip for fitting is to use clear silicone bathroom sealant to stick 'em on. I found that hairspray and other solutions ended up coming loose when it pissed it down, to the point I nearly ended up in a ditch due to spinny-throttle syndrome.
Kaneda80
PostPosted: 16:45 - 19 Jul 2015    Post subject: Reply with quote
Try grip puppy's I ise them and they're nice and comfy, let the heat through too.
https://www.grip-puppy.co.uk/
I like turtles
talkToTheHat
PostPosted: 17:17 - 19 Jul 2015    Post subject: Reply with quote
I tried grip puppies over R&G heated grips. They are horrible if they get wet, and made my hands ache worse whatever the weather as the squishyness invites a tight grip. Size 11 gloves so reasonably large hands and long fingers. I found actively working on not holding on too tight a much better remedy.
Bandit. does. everything.
Major Doss
PostPosted: 00:16 - 21 Jul 2015    Post subject: Reply with quote
cricket bat rubbers are cheap enough, if you can be faffed with the rolling on and trimming.
Shaft
PostPosted: 00:46 - 01 Aug 2015    Post subject: Reply with quote
Just fitted a set of Grip Puppies, for the same reason as Pete.
So far, the cramp across the base of my thumb has gone (will be doing a longer ride than my commute tomorrow, I'll report back then) but I have introduced involuntary cruise control - the extra pressure on the throttle tube has overwhelmed the throttle return spring, so the throttle doesn't close when you release your grip.
Hasn't caused me a problem so far, but worth keeping in mind.
monkeybiker
PostPosted: 08:31 - 01 Aug 2015    Post subject: Reply with quote
You need to get that sorted out. It's not a minor problem.
ADSrox0r
PostPosted: 08:37 - 01 Aug 2015    Post subject: Reply with quote
Yup, that's an MOT fail.
Shaft
PostPosted: 00:20 - 02 Aug 2015    Post subject: Reply with quote
It's OK, I know the tester pretty well and it's another year before it needs doing.
Anyway, back at the plot, cramp seems to be gone - extra fat grips feel a bit unusual at first, but that passes.
Quite happy with the purchase so far, let's see what happens when it rains.
-Matt-
PostPosted: 01:26 - 02 Aug 2015    Post subject: Reply with quote
grip puppies
Quite tempted to give these a go; i've had on and off hand-pain for a couple of years now also.
Has anyone tried them with a cramp-buster out of interest? I'm guessing it might not work properly, which would make me less keen to buy them at the moment.
monkeybiker
PostPosted: 07:07 - 02 Aug 2015    Post subject: Reply with quote
It's not like it's a noisy exhaust it's a safety issue. It might be O.k but also it might cause an accident.
Just saying.
daesimps
PostPosted: 09:28 - 02 Aug 2015    Post subject: Reply with quote
Yes - I've had the 2 things fitted together permanently on the last 3 bikes with no issues. I have severe joint issues so need the larger grips otherwise it's too painful. Not had a problem with them in the rain either - we did 200 miles last Sunday through monsoon type rain and the puppies didn't even feel damp. I did have the heated grips on though.
If it ain't broke, fix it till it is!
Robby
Dirty Old Man
PostPosted: 10:48 - 02 Aug 2015    Post subject: Reply with quote
Did you cut off the excess bit? If you don't, they'll grip around the bar end and provide a stay-open throttle. Even if you do cut them down, they can squeeze the end of the grip so it just touches the bar end.
I'll be up in 20 mins or so and have a look.
Yorkshire Geek
PostPosted: 11:19 - 02 Aug 2015    Post subject: Reply with quote
Hah, try my size 13s! I can never buy gloves or shoes over the interwebs, it's a waste of time. The answer to the question "which one do you prefer?" is usually "the only pair that fits" Sad
-Matt-
PostPosted: 21:38 - 02 Aug 2015    Post subject: Reply with quote
Brilliant, cheers Thumbs Up. Going to order a pair and give them a go.
The last post was made 10 years, 336 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 132.15 Kb
