Reccomend me a NAS drive.
PostPosted: 08:00 - 02 Aug 2015    Post subject: Reccomend me a NAS drive. Reply with quote
I want to add a NAS drive to my home network probably a couple of TB capacity. It won't be used for movie streaming or filesharing, just for backup and storage. I intend to site it in the cupboard alongside my wireless AP.
What I'd LIKE to do is set up folders on the NAS drive that automatically sync with various devices to back up whatever the user thinks is relevant, and of course be able to manually copy over files I want saved.
So what are my options? In my household I have a couple of pc's, three laptops, two ipads, one iphone, several smart-phones and an android tablet. A web-facing share service for my own personal use would be fun too but not essential.
Seb
PostPosted: 12:40 - 02 Aug 2015    Post subject: Reply with quote
3 main factors to keep in mind
1: Instant out of the box solutions vs on the fly 'projects' to fiddle with and potentially expand
2: Performance, redundancy and scalability
3: Initial outlay vs long term running costs (And often heat/noise)
All told, you can't really go wrong with a Qnap, Asustor or Synology NAS these days, however they primarily offer up convenience, ease of use and low running costs rather than performance or scalability.
Starting with one of the HP Microservers often linked here and building up from that will get you more potential and generally better performance but of course it'll take some fiddling to get it right.
The other option is to go for a retired server off eBay, I recently sold a twin socket server with hardware raid, 8TB of drives and dual redundancy throughout for £200. That blew any sub £1000 NAS into the weeds in most regards but it also brought a massive elephant into the room by the way of a 200w idle power consumption (35w literally switched off Laughing ) as well as quite an incredible amount of noise from it's cooling system.
My current personal server brings the idle power usage down to a much more reasonable 100w (0.5 when off), gives me almost enough IO to saturate a 10GBe cable and sufficient CPU grunt for HEVC transcoding. As well as being almost entirely inaudible in it's cupboard. The downside there was the upfront cost with the machine weighing in at a little shy of £2000 thus far (And that was with a £500 saving on the raid controller).
It really is a case of checking the bank balance and picking your poison.
2010 Triumph 1050 Sprint ST
CaNsA
PostPosted: 12:50 - 02 Aug 2015    Post subject: Reply with quote
Righto.
Grab a HP Microserver N54L or a new Gen8 one.
Check some drives in it.
Install OpenMediaVault
Problem solved.
My thread for the N54L. The whole thing cost me about 250 quid, including the harddrives.
https://www.bikechatforums.com/viewtopic.php?t=293458
8th Gen thread.
https://www.bikechatforums.com/viewtopic.php?t=298192
t121anf
PostPosted: 13:22 - 02 Aug 2015    Post subject: Reply with quote
Started with a NAS and quickly out grew it, now it's only a backup of a backup.
Skip and get a micro server.
PostPosted: 13:50 - 02 Aug 2015    Post subject: Reply with quote
How does that software work Cansa? Do you install it from disc then connect via a network interface?
CaNsA
PostPosted: 13:51 - 02 Aug 2015    Post subject: Reply with quote
As did I.
I also found that the out-of-the-box NAS drives were slow and very limited as to what you could do with them.
The Buffalo one wouldn't let me use NFS, which is the most simple method of file transfer.
Sload
PostPosted: 15:32 - 02 Aug 2015    Post subject: Reply with quote
Second Cansa, tis very good, but if you are not a software / network guru you will need direction and tuition.
Currently running the setup Cansa has suggested with 6TB of drive installed. I somehow borked my web interface but it runs on Laughing
Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx
CaNsA
PostPosted: 17:01 - 02 Aug 2015    Post subject: Reply with quote
Whats the error?
Something to do with apache?
if so, ssh in and "sudo apt-get remove apache"
The WebUI uses nginx now.
Also, clear cache and cookies on your broswer.
Sload
PostPosted: 18:20 - 02 Aug 2015    Post subject: Reply with quote
Dont want to discolour Petes thread with troubleshooting. Illl have a crack at it (just ignored so far) and if I need a chuck ill put a thread up fella
Edit: fixed
The last post was made 11 years, 38 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.65 - MySQL Queries: 13 - Page Size: 62.01 Kb
