| lihp |
 lihp World Chat Champion
 Posted: 23:00 - 06 Aug 2015 Post subject: How To: Helmet mount Go Pro |
Thought I would do a quick how to guide, for those wanting a bit of advice on how to mount a go pro to their helmet
This is the most secure way I can think of.
You want to use the mount designed for a tripod/monopod and have a suitable bolt.
The bolt I had required a 6mm hole, so grab a decent 6mm HSS bit, and go slow so you don't damage or crack the helmet!
https://i.imgur.com/w5jIERal.jpg
Next, to fit a 3/8 deep socket, I needed a 16mm drill bit to remove some of the polystyrene from the inside, again make sure you go slow and don't damage it when you're removing some material.
Also, before you drill, make sure you remove the liner so you don't tear and ruin it!
Next, get, or cut a bolt to the correct length, and push it through from the inside.
https://i.imgur.com/COQ1J33l.jpg
Then fit the mount, with something to hold it. I used some grip tape on the underside to bite into the helmet to help it grip, so I didn't destroy the polystyrene inside by overtightening.
https://i.imgur.com/lTV4APnl.jpg
And you're done!
https://i.imgur.com/IVBxUDel.jpg
Tested this today, and the mount is extremely stable  ____________________ covent.gardens: lihp is my most favourite member ever |
| Just_James |
 Just_James Could Be A Chat Bot
 Posted: 23:36 - 06 Aug 2015 Post subject: |
Is it a good idea to be drilling a hole in your helmet?
Might be stable but I'd have thought that mount is now quite capable of ripping your helmet into pieces if it gets a heavy impact? ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125 |
| grr666 |
 grr666 Super Spammer
| wr6133 |
 wr6133 World Chat Champion
| Ste |
 Ste Not Work Safe
 Posted: 08:14 - 07 Aug 2015 Post subject: |
| ScaredyCat |
 ScaredyCat World Chat Champion
 Posted: 08:21 - 07 Aug 2015 Post subject: |
WTF ...
Surely this is a troll, not even Bodyguard is this retarded...
 ____________________ Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple |
| MCN |
 MCN Super Spammer
 Posted: 08:53 - 07 Aug 2015 Post subject: |
Cool that medical maroowhannah is already on NHS.
I'll get a prescription off my GP to take to the BBQ.
I know folk do stuff but lots of folk believe religion too.
ps. Dear Korn pleas make this thread a sticky.
Tip: You will have to, somehow, drill a 6mm hole in the forum section (MCN has no idea what the exe. for that would be.)
| pompousporcup... |
 pompousporcup... World Chat Champion
 Posted: 09:09 - 07 Aug 2015 Post subject: |
drilling the hole aside.. are you super duper sure you'd want your head exposed a bit of metal like that
this is how i mounted a cam.. not a gopro as it looks ridiculous but i'm positive you could mount it in a similar way.
Go to your local fabric/crafts shop and ask for some strong velcro..yes velcro. The stuff i used was strong enough to support the light structures in the shop.
Get some 3M super sticky double sided tape and the rest should be fairly self explanatory.. but i'l describe it anyway. Double sided tape on the lid with the hard velcro cut into shape and stuck on.. double sided tape onto the mount to you want to use with the soft velcro stuck on..
https://i176.photobucket.com/albums/w188/Sharpe2002/IMAG2288_zpssgv6yugn.jpg
https://i176.photobucket.com/albums/w188/Sharpe2002/IMAG2289_zpsh5ikxtga.jpg
the part stuck to the lid is bigger for different mounts. I ended up using the slim mount.
*tested at silly speeds without a single worry of it coming off. I can pick up the lid using the camera and swing it around
| recman |
 recman World Chat Champion
| UrbanRacer |
 UrbanRacer World Chat Champion
 Posted: 09:25 - 07 Aug 2015 Post subject: Re: How To: Helmet mount Go Pro |
| lihp wrote: | Thought I would do a quick how to guide, for those wanting a bit of advice on how to mount a go pro to their helmet
And you're done!
Tested this today, and the mount is extremely stable  |
Funny as f**k, considering the 3M adhesive pads are very strong as it is to the point you can hold the GoPro mount and swing the helmet about like a madman and it'll still be attached. |
| MCN |
 MCN Super Spammer
| ScaredyCat |
| MCN |
 MCN Super Spammer
| stinkwheel |
 Posted: 12:51 - 07 Aug 2015 Post subject: |
The usefullness or otherwise of helmets notwithstanding, sticking a metal bolt through it pointing directly at the top of your skull is utter madness in my book. It's a nail looking for a hammer.
3m VHB pads will stick any mount you care to name to a helmet. The mount or helmet will fail before the adhesive.
I've also attached a mount using 3M dual-lock which is kind of like heavy duty velcro. I have the same stuff holding a mast foot in my canoe, I can lift the 40kg canoe off the ground by it.
I think the OPs advice is actively dangerous. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| ScaredyCat |
 Posted: 13:14 - 07 Aug 2015 Post subject: Re: How To: Helmet mount Go Pro |
https://dl.dropboxusercontent.com/u/188253/_bcf/helmet/w5jIERal.jpg
https://dl.dropboxusercontent.com/u/188253/_bcf/helmet/COQ1J33l.jpg
https://dl.dropboxusercontent.com/u/188253/_bcf/helmet/lTV4APnl.jpg
And you're done!
https://dl.dropboxusercontent.com/u/188253/_bcf/helmet/IVBxUDel.jpg
Quoted to preserve history. ____________________ Honda CBF125 ➝ NC700X
| CaNsA |
 CaNsA Super Spammer
| lihp |
| Just_James |
 Posted: 14:36 - 07 Aug 2015 Post subject: |
| lihp wrote: | Maybe now would be a good time to say that this is an old helmet, that i used for karting and obviously it would be very stupid to actually do this on a motorcycle! |
Maybe the start of the thread would have been better?
Considering you've done it as a 'how to' on a motorbike forum  ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
| Ste |
 Ste Not Work Safe
 Posted: 14:37 - 07 Aug 2015 Post subject: |
How to? It's a recipe for potato salad.  |
| recman |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 21:46 - 07 Aug 2015 Post subject: |
tested the 3m mounts up to 165 and not found them wanting. drilling a bolt into your helmet seems about as smart as drilling through your ECU to fit a numberplate hanger. (Yes really) ____________________ My Flickr |
| lihp |
| Just_James |
| lihp |
| Just_James |
 Posted: 23:04 - 07 Aug 2015 Post subject: |
That's it now! You pushed me too far!
https://i.imgbox.com/abdyJzOz.gif
Seriously though, you've done a good job of making that helmet into a fine ornament!  ____________________ Current Bikes / Projects: 1999 Rieju RS1 50
The last post was made 11 years, 46 days ago. Instead of replying here, would creating a new thread be more useful? |
