How To: Helmet mount Go Pro
lihp
PostPosted: 23:00 - 06 Aug 2015    Post subject: How To: Helmet mount Go Pro Reply with quote
Thought I would do a quick how to guide, for those wanting a bit of advice on how to mount a go pro to their helmet Smile
This is the most secure way I can think of.
You want to use the mount designed for a tripod/monopod and have a suitable bolt.
The bolt I had required a 6mm hole, so grab a decent 6mm HSS bit, and go slow so you don't damage or crack the helmet!
https://i.imgur.com/w5jIERal.jpg
Next, to fit a 3/8 deep socket, I needed a 16mm drill bit to remove some of the polystyrene from the inside, again make sure you go slow and don't damage it when you're removing some material.
Also, before you drill, make sure you remove the liner so you don't tear and ruin it!
Next, get, or cut a bolt to the correct length, and push it through from the inside.
https://i.imgur.com/COQ1J33l.jpg
Then fit the mount, with something to hold it. I used some grip tape on the underside to bite into the helmet to help it grip, so I didn't destroy the polystyrene inside by overtightening.
https://i.imgur.com/lTV4APnl.jpg
And you're done!
https://i.imgur.com/IVBxUDel.jpg
Tested this today, and the mount is extremely stable Thumbs Up
Just_James
PostPosted: 23:36 - 06 Aug 2015    Post subject: Reply with quote
Shocked
Is it a good idea to be drilling a hole in your helmet? Confused
Might be stable but I'd have thought that mount is now quite capable of ripping your helmet into pieces if it gets a heavy impact?
Current Bikes / Projects: 1999 Rieju RS1 50
Previous bikes - 1986 DT125R (field bike), 1989 KX250, 1980 KX420 (with 500cc big bore), 1992 YZ250, 1988 KX500, 1989 XR250R, 1988 VFR400R NC24, 1999 Cagiva Mito 125, 2008 Rieju RS2 50 , 1993 Honda NSR 125
grr666
PostPosted: 00:48 - 07 Aug 2015    Post subject: Reply with quote
https://static.tvtropes.org/pmwiki/pub/images/Not_Sure_If_Serious_1072.png
wr6133
PostPosted: 08:06 - 07 Aug 2015    Post subject: Reply with quote
lol wut?
Drill a hole in your lid rather than use the sticky pads most people use?
PostPosted: 08:14 - 07 Aug 2015    Post subject: Reply with quote
https://nypost.com/2014/10/13/gopro-camera-caused-schumachers-head-injury-report/
ScaredyCat
PostPosted: 08:21 - 07 Aug 2015    Post subject: Reply with quote
WTF ...
Surely this is a troll, not even Bodyguard is this retarded...
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
MCN
PostPosted: 08:53 - 07 Aug 2015    Post subject: Reply with quote
Cool that medical maroowhannah is already on NHS.
I'll get a prescription off my GP to take to the BBQ.
I know folk do stuff but lots of folk believe religion too.
ps. Dear Korn pleas make this thread a sticky.
Tip: You will have to, somehow, drill a 6mm hole in the forum section (MCN has no idea what the exe. for that would be.)
Very Happy
pompousporcup...
PostPosted: 09:09 - 07 Aug 2015    Post subject: Reply with quote
drilling the hole aside.. are you super duper sure you'd want your head exposed a bit of metal like that Shocked Shocked
this is how i mounted a cam.. not a gopro as it looks ridiculous but i'm positive you could mount it in a similar way.
Go to your local fabric/crafts shop and ask for some strong velcro..yes velcro. The stuff i used was strong enough to support the light structures in the shop.
Get some 3M super sticky double sided tape and the rest should be fairly self explanatory.. but i'l describe it anyway. Double sided tape on the lid with the hard velcro cut into shape and stuck on.. double sided tape onto the mount to you want to use with the soft velcro stuck on..
https://i176.photobucket.com/albums/w188/Sharpe2002/IMAG2288_zpssgv6yugn.jpg
https://i176.photobucket.com/albums/w188/Sharpe2002/IMAG2289_zpsh5ikxtga.jpg
the part stuck to the lid is bigger for different mounts. I ended up using the slim mount.
*tested at silly speeds without a single worry of it coming off. I can pick up the lid using the camera and swing it around Thumbs Up
recman
PostPosted: 09:23 - 07 Aug 2015    Post subject: Reply with quote
These cameras look ridiculous btw.
They'd have to be a lot more discrete and a damn sight cheaper before I'd consider one.
UrbanRacer
PostPosted: 09:25 - 07 Aug 2015    Post subject: Re: How To: Helmet mount Go Pro Reply with quote
And you're done!
Funny as f**k, considering the 3M adhesive pads are very strong as it is to the point you can hold the GoPro mount and swing the helmet about like a madman and it'll still be attached.
MCN
PostPosted: 09:30 - 07 Aug 2015    Post subject: Reply with quote
Yeah they do look a bit, 'Hey everyone look at me. I'm vloggin.'
0 = Number of æsthetics given.
The OP could have hollowed out the liner and Aradited the camera 'inside the helmet.
Took a round file to the hole so the lens could poke out.
Bingo Crash Cam-met.
HSE Warning: Try not to have a crash while wearing a modificated crash helmet.
ScaredyCat
PostPosted: 10:18 - 07 Aug 2015    Post subject: Reply with quote
You only need to have one driver try to potato you to stop giving a fuck what a camera looks like.
Contour Roam is slimmer and there are others that can be hidden better.
Although, speak to goto10 about giving footage as evidence of psycho activity and he'll tell you they'll ignore that part and and look for you killing kittens at speed..
MCN
PostPosted: 10:31 - 07 Aug 2015    Post subject: Reply with quote
I have a tiny wee camera I picked up from one of the bargain-bins at Schiphol airport. It isn't gopro HD but possibly presentable as 'evidence'.
https://www.denver-electronics.com/
AC1300
https://www.youtube.com/watch?v=9cBYXyHPbbk
I don't know if looping and mounting can be altered to suit a helmet but this device could sit inside a helmet. L55mm x H23mm x D32mm
The Chinese could do it.
PostPosted: 12:51 - 07 Aug 2015    Post subject: Reply with quote
The usefullness or otherwise of helmets notwithstanding, sticking a metal bolt through it pointing directly at the top of your skull is utter madness in my book. It's a nail looking for a hammer.
3m VHB pads will stick any mount you care to name to a helmet. The mount or helmet will fail before the adhesive.
I've also attached a mount using 3M dual-lock which is kind of like heavy duty velcro. I have the same stuff holding a mast foot in my canoe, I can lift the 40kg canoe off the ground by it.
I think the OPs advice is actively dangerous.
ScaredyCat
PostPosted: 13:14 - 07 Aug 2015    Post subject: Re: How To: Helmet mount Go Pro Reply with quote
https://dl.dropboxusercontent.com/u/188253/_bcf/helmet/w5jIERal.jpg
https://dl.dropboxusercontent.com/u/188253/_bcf/helmet/COQ1J33l.jpg
https://dl.dropboxusercontent.com/u/188253/_bcf/helmet/lTV4APnl.jpg
And you're done!
https://dl.dropboxusercontent.com/u/188253/_bcf/helmet/IVBxUDel.jpg
Quoted to preserve history.
CaNsA
PostPosted: 13:18 - 07 Aug 2015    Post subject: Reply with quote
Stunning a cow for slaughter?
POSSIBLE NSFW - MAY MAKE YOU CRY IF YOU ARE A VEGGIE
https://www.youtube.com/watch?v=nr00arV2XIw
lihp
PostPosted: 13:19 - 07 Aug 2015    Post subject: Reply with quote
Maybe now would be a good time to say that this is an old helmet, that i used for karting and obviously it would be very stupid to actually do this on a motorcycle!
Just_James
PostPosted: 14:36 - 07 Aug 2015    Post subject: Reply with quote
Maybe the start of the thread would have been better?
Considering you've done it as a 'how to' on a motorbike forum Rolling Eyes
PostPosted: 14:37 - 07 Aug 2015    Post subject: Reply with quote
How to? It's a recipe for potato salad. Wink
recman
PostPosted: 14:43 - 07 Aug 2015    Post subject: Reply with quote
'Cos that's never happened to me before. Liar
I'm not invalidating the merits of being able to capture incidents etc, I just don't want to look like Tinky Winky while I'm doing it.
I could, however, live with the camera mounted on the bars or something as it wouldn't look much worse than the sat-nav I have.
PostPosted: 21:46 - 07 Aug 2015    Post subject: Reply with quote
tested the 3m mounts up to 165 and not found them wanting. drilling a bolt into your helmet seems about as smart as drilling through your ECU to fit a numberplate hanger. (Yes really)
lihp
PostPosted: 21:57 - 07 Aug 2015    Post subject: Reply with quote
Y U NO HUMOUR?!
Just_James
PostPosted: 22:28 - 07 Aug 2015    Post subject: Reply with quote
Y U NO HUMOUR?!
https://s-media-cache-ak0.pinimg.com/originals/50/bd/25/50bd25d3373b46495f8093bec401c537.gif
lihp
PostPosted: 22:44 - 07 Aug 2015    Post subject: Reply with quote
Just_James wrote:
https://cdn.meme.am/instances/400x/53655442.jpg
Just_James
PostPosted: 23:04 - 07 Aug 2015    Post subject: Reply with quote
That's it now! You pushed me too far! Evil or Very Mad
https://i.imgbox.com/abdyJzOz.gif
Seriously though, you've done a good job of making that helmet into a fine ornament! Thumbs Up
The last post was made 11 years, 46 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 137.73 Kb
