Help please , oil pipe corrosion..
Michelle L
PostPosted: 08:46 - 08 Aug 2015    Post subject: Help please , oil pipe corrosion.. Reply with quote
Hi everyone , I am new to this site , hope you do not mind me asking for some advice please.
I bought a Suzuki Bandit 600 , 99 model... I have always really liked the bandits but never got round to owning one till now..
When I went to buy it the other night I thought WOW , it looks fantastic and it had been very well looked after , I checked it all over and just thought its fine so I bought it..
Next day when I was cleaning it and giving it a closer inspection I noticed one of the oil outlet pipes was badly corroded..
The rest of the oil pipes are just fine even the other outlet pipe is fine with no corrosion on..
My question is what can I do about this ? , can it be repaired ? , or do I need to change it which I no is a big job Crying or Very sad
I will try to put a pic on..
Any advice please and I would be very grateful , PS one more question is it an MOT failure ?.
Regards Michelle.
Ride safe , if you can not ride safe , ride free....
Michelle L
PostPosted: 10:35 - 08 Aug 2015    Post subject: Reply with quote
Hi Vincent , thank you for replying to my post,, I know there only cheap but to replace them I thought I have to split the cylinder head in half ?.
I have not worked on a bandit before so I just don't no.
This may be a silly question but how do you no if there rusty inside with out taking them out first ?..
From the way your post is worded can I replace them with out taking the engine to bits ?.
Michelle L
PostPosted: 10:55 - 08 Aug 2015    Post subject: Reply with quote
Oh ok Vincent ,, I thought you was going to say,, no Michelle there a real easy fix , they just pull out Very Happy
I will , have a look around on the site to see what others have done.
Well thank you kindly for your advice Vincent ,, enjoy the weekend Wink
MCN. This post is not being displayed because the poster is banned. Unhide this post / all posts.
PostPosted: 12:56 - 08 Aug 2015    Post subject: Reply with quote
Forget about them. Changing them is a big job requires removing the head, which in turn requires removing the exhaust, which will likely mean snapped exhaust bolts and if you're not doing the work or getting it done for free it's going to be expensive.
They may look bad but there are many Bandits out there just the same or worse and they'll probably last a long while yet. Paint them with rust inhibitor or cylinder black if you really must, but really the best thing is to leave them alone.
Michelle L
PostPosted: 13:02 - 08 Aug 2015    Post subject: Reply with quote
Hi NKVD , I have ordered some heavy duty brushable underseal.
Should I clean the pipe at all , like with some sand paper or something ?.
Thanks for the top tip chap Very Happy , I might as well do the other oil pipes at the front as well.
MCN
PostPosted: 13:09 - 08 Aug 2015    Post subject: Reply with quote
You could try painting with Rust Stopper stuff. Turns the rust to a black/blue oxide.
They would need to be very clean and dry though or that stuff isn't so clever.
Then paint as above using High Temp Black or woteva takes your fancy/floats your canoe.
ps Do you have a boyfriend? Shifty
PPS
If you can get the beast to a pressure washer you can jetwash the block after letting some de-greaser soak in for ten fifteen minutes.
Don't aim jet directly at switches, gasket joints, seals and more sensitive bits.
There are those who flame for jetting but I use a pressure washer for all my bikes Zero issues ever. Just use the noggin.
Mask off the stuff that's not meant to be painted.
Then spray the block with silver/aluminimumum HT paint.
It is a wee bit of a project for anyone but cheap-ish, well do-able and after the 'new-ness' calms the-fcuk-down a bit it will look sweeter and you will be full of Proudity. Thumbs Up
Michelle L
PostPosted: 13:13 - 08 Aug 2015    Post subject: Reply with quote
It is a big job for me , I have stripped my other bikes down in the past , apart from the gearbox's as I have never had any problems with them...
With the exhaust bolts I would weld some allen keys in them and hope they come out Confused
My dad was very good at stripping engines down and rebuilding them so he showed me a lot..
Michelle L
PostPosted: 13:18 - 08 Aug 2015    Post subject: Reply with quote
I am married and he knows nothing about bikes , in fact he don't no much about anything but I still love him Cool
PostPosted: 13:19 - 08 Aug 2015    Post subject: Reply with quote
I would not go sanding those pipes. Scrape off the worst of the flaky rust if you like but do it carefully and don't dig the pipes with your scraper or you might hole them.
PostPosted: 13:22 - 08 Aug 2015    Post subject: Reply with quote
While a fair bit of rust, I wouldn't want to think about doing those pipes until desperate.
I would go with cleaning them up a bit and painting them, preferably with something that will prevent rust.
They are not pressurised (they are just the oil drains from the head really), beyond normal crankcase pressure.
To replace them means removing the head, which means getting the exhaust off. If you do land up replacing them the seals at the ends are ones that are heavily recommended that you use original Suzuki ones. They are cheap enough, but given if the seals fail you are back doing a top end rebuild it is worthwhile spending the small amount extra
K
Michelle L
PostPosted: 13:28 - 08 Aug 2015    Post subject: Reply with quote
Thanks for all your replies chaps , I am really grateful for all the advice...
It rings out when I tap it with a screwdriver as Vincent says it not so bad when it does that so maybe its not as bad as it looks.
Even though it is a little worrying because I just bought the bike..
The last thing I want to do is take it apart hours after I only just got it Shocked .
Other than that the bike is fantastic , I really like it with the streetfighter look.
Michelle L
PostPosted: 13:46 - 08 Aug 2015    Post subject: Reply with quote
Hi Kick start
Oh I thought they was pressurised , my thought was if the pipe springs a leak when I am riding my engine might seize up.
I thought it looked bad myself with all that rust on but you guys say its like a common thing on bandits ,, so I will just clean it up a bit and put underseal on as I have ordered it already..
MCN
PostPosted: 14:01 - 08 Aug 2015    Post subject: Reply with quote
Michelle L wrote:
Stuff
Married you say?
Sad
Very Happy
CHR15
Turbo nutter bastard
PostPosted: 10:50 - 09 Aug 2015    Post subject: Reply with quote
https://s2.quickmeme.com/img/f8/f8c3e02af667ee4778349a8511bda8f3fdda38435cca14a0ddce20064994e74e.jpg
Michelle L
PostPosted: 14:19 - 09 Aug 2015    Post subject: Reply with quote
That's a strange picture Confused
The last post was made 11 years, 34 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.76 - MySQL Queries: 13 - Page Size: 102.2 Kb
