Brake pads
stranger12
PostPosted: 05:40 - 13 Aug 2015    Post subject: Brake pads Reply with quote
Hi guys
When you hear a robbing sound of metal on metal on ur disc, it is a sign of low brake pad , right?
I remember reading somewhere saying when pads get low they have this built in feature to make that noise and make you aware of the need to change
The pad seems to have some meatbon it still
How is that sound produced, do pads have a metal that scratches against the disc?
SV650 Red
R6 Red
PostPosted: 06:36 - 13 Aug 2015    Post subject: Reply with quote
No its badly maintained brakes.
stranger12
PostPosted: 07:08 - 13 Aug 2015    Post subject: Reply with quote
well I changed the pads 2k ago to sintered ebc
and rebuild the caliper 3k ago( last year).
I haven't since then opened the caliper to clean it etc
but I know most pads have the saftey feature of making the metal to metal contact sound when they wear down to limit but don't know how it works.
my assumption is if there is any contact to the disc ( metal to metal) then that is pad so why manufactures implement this ?
SV650 Red
R6 Red
Busa1340R
PostPosted: 08:28 - 13 Aug 2015    Post subject: Reply with quote
This is more of a feature on cars and light vans. The pads have a small metal tang attached to the brake pad backplate and perpendicular to the pad material, sticking out approx 2-3mm past the front side of the brake pad backplate. This tang scrapes the swept surface of the disc when the pad material gets lower than the protruding metal tang, giving advanced warning of impending expense...
I have not come across this on bikes.....usually pad wear is indicated by a groove in the pad material which slowly disappears as the pad wears down.
Sintered pads can sometimes be noisier than organic pads as they contain small bits of soft metal to improve braking friction.
Current: 2010 Suzuki GSX1340R Hayabusa, 2013 Yamaha YP250R X-Max Sport - Previous: Triumph Sprint ST1050ABS, Honda XL600V Transalp, Honda NT650V Dullsville (don't ask!), Kawasaki ZX9R E1, Honda NX650 Dominator, Suzuki GSX1300RKZ Hayabusa, Honda CBR1000FM, Kawasaki GPZ500S, etc etc
stranger12
PostPosted: 08:32 - 13 Aug 2015    Post subject: Reply with quote
so in your view is it my pad or just needs cleaning ?
SV650 Red
R6 Red
Busa1340R
PostPosted: 08:39 - 13 Aug 2015    Post subject: Reply with quote
Could be either.....
Only takes a few minutes to whip the pads out and have a look.
Why not take the pads out, if they still have more than a few mm of pad material on them, clean 'em up with.a bit of coarse emery cloth and refit using some copper/graphite grease on the backplate and abutments at the end of each pad.
If worn low.....replace pads and check caliper pistons and slider pins move freely before reassembly.
Matt B
PostPosted: 08:52 - 13 Aug 2015    Post subject: Reply with quote
^^This.
In the time you wasted posting and waiting for replies here you could have had the calipers off and the pads out to check Rolling Eyes
stranger12
PostPosted: 09:03 - 13 Aug 2015    Post subject: Reply with quote
yep what I do over the weekend .
I wanted to get some opinion and maybe get the pads and change any way
after I realised they are £40 a pair hence £80 I am thinking of first taking the pads off and checking Very Happy
unless someone here has £80 to donate Very Happy
SV650 Red
R6 Red
Taught2BCauti...
PostPosted: 09:29 - 13 Aug 2015    Post subject: Reply with quote
Shop around - £40 sounds like too much!
Change the pads when there is 3mm or less of the friction material remaining, or you run the risk of trashing the discs themselves.
You can usually see how badly the pads have worn, just by looking at them - like you shound be doing once a week.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
stranger12
PostPosted: 09:56 - 13 Aug 2015    Post subject: Reply with quote
so you take the calipers off once a week Very Happy?
SV650 Red
R6 Red
Taught2BCauti...
PostPosted: 10:44 - 13 Aug 2015    Post subject: Reply with quote
Don't be daft!
Just bend over and have a look.
stranger12
PostPosted: 10:55 - 13 Aug 2015    Post subject: Reply with quote
yes do that but there are so tiny anyway that you can't know .
they are about 10 mm brand new I think but I agree and do what you say
SV650 Red
R6 Red
Jefr0
PostPosted: 11:06 - 13 Aug 2015    Post subject: Reply with quote
What I've found through experience is even though you can look at what's remaining on the pad like the picture above, it doesn't account for uneven wear.
I've had pads out where the pad still has a couple mm on one side, but metal on metal on the other end.
Usually down to a sticky piston or alignment out.
Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95)
Taught2BCauti...
PostPosted: 11:25 - 13 Aug 2015    Post subject: Reply with quote
True.
Happens a lot on dual piston calipers if one piston is sticking, or single piston calipers if one of the slider pins is sticking.
There is no reason why you can't look at both edges of the pads, to see if one side is wearing more than the other.
You may have to bend over a bit more, move your head a little, or use a mirror - but why would you not bother to check something so important on a regular basis if your life could depend on it?
It's not rocket surgery.
Fizzer Thou
PostPosted: 13:34 - 13 Aug 2015    Post subject: Reply with quote
There are times when the pistons and seals can be nice and clean and still have a caliper that causes uneven pad wear.
I borrowed this pic but it shows a pin that is quite corroded and can cause all sorts of problems.Quite often if a caliper is allowed to get to this state then the other pin that the caliper sits on will be just as bad.
https://i744.photobucket.com/albums/xx90/wingnutter/GL1500%20Goldwing%20Brake%20Pads%20Replacement/gl15pushpads.jpg
No excuse for bad maintenance Rolling Eyes Thumbs Down
Always have a 'Plan B'
The last post was made 11 years, 22 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 86.77 Kb
