ZZR1400 injector replacement
Copycat73
PostPosted: 20:31 - 12 Sep 2015    Post subject: ZZR1400 injector replacement Reply with quote
I was informed during a dyno / ecu flash that an injector was malfunctioning and should be repaired or replaced..
I opted for the latter..
well the bits have arrived and I made a start on this task..
Stripping off the plastics and fuel tank down to the air box ..
;which is part of the frame;. and another part of the frame which unbolts..
Once inside set about removing the inlet rubbers or velocity stacks or whatever you wanna call them.. they pulled out into the air box with a little manipulation once the jubilee clips were loosened..
The throttle bodied are in a very tight hole with very little hand room..
There are more wires and connectors than I have ever seen on any previous bike I have ever owned..
Still with patience they came out ...disconnecting those wires is a pain in the arse.. Crying or Very sad
Cleaned with a little carb and choke cleaner and rinsed with petrol..
enough for one day..
caveat emptor
ADSrox0r
PostPosted: 06:04 - 13 Sep 2015    Post subject: Reply with quote
Were you having it dyno'd for a fuel remap? It'll need another go to remap after the injector is replaced.
PostPosted: 06:15 - 13 Sep 2015    Post subject: Reply with quote
Did they tell you which injector it was? If so, how did they know?
Copycat73
PostPosted: 09:26 - 13 Sep 2015    Post subject: Reply with quote
yes he did ..
there was some deposits inside the throttle body .. visible with a light
and the computer diagnostics on the dyno showed it up as a series of spikes on one of the read outs.
caveat emptor
Copycat73
PostPosted: 09:31 - 13 Sep 2015    Post subject: Reply with quote
yes @ hilltop..
no it wont need another go .. he partitioned the ecu memory, updated the firmware and loaded a " learning map"
watched it alter settings whilst on the dyno run as the room pressure was increased..
I can also fit what exhaust or air filter I like and it will compensate for that too.
caveat emptor
PostPosted: 09:48 - 13 Sep 2015    Post subject: Reply with quote
Closed-loop tuning to full revs? I wasn't aware that the ECU had the processing power to do that.
Copycat73
PostPosted: 10:01 - 13 Sep 2015    Post subject: Reply with quote
tbh.. it all got very technical .. and yes the closed-loop circuit was altered though the lambada sensor it still referenced but not to the same extent as the original map does, as it takes it as gospel but the new map just compares with it ... if that makes any sense ???
caveat emptor
PostPosted: 10:27 - 13 Sep 2015    Post subject: Reply with quote
Not really. Sounds like someone has written some auto-tune code to make it behave like a PC5.
Hilltop have a good rep at least, though 'likes' from people ignorant of what's going on only carry so much weight.
I remember a guy who used to 'tune' Suzuki ecu's by post with a yoshbox.
Copycat73
PostPosted: 17:25 - 13 Sep 2015    Post subject: Reply with quote
was told he wrote the software himself ..
caveat emptor
Copycat73
PostPosted: 18:27 - 15 Sep 2015    Post subject: Reply with quote
well to day I did remove defective injector from the common rail and fit the new one ... along with all the 0 ring seals and washers on the others..
silicone lubricated the manifold rubbers and squeezed the throttle boddies back into place.. along with all the wiring Rolling Eyes
caveat emptor
PostPosted: 18:36 - 15 Sep 2015    Post subject: Reply with quote
Looks like just a faulty o-ring.
Copycat73
PostPosted: 19:15 - 15 Sep 2015    Post subject: Reply with quote
the white you can see is the paint I applied before I removed the injector .. no chance of mixing them up...
the 0rings and seals were all intact and un-damaged..
will take it to be cleaned .. new one fitted so no rush .. but curious to hear what they have to say..
caveat emptor
ADSrox0r
PostPosted: 19:48 - 15 Sep 2015    Post subject: Reply with quote
Wouldn't it be better to get them all cleaned at the same time? I intend to whip mine out (oo-er) in winter if and when it gets 'orrible enough to justify the downtime to send them off.
Copycat73
PostPosted: 10:00 - 16 Sep 2015    Post subject: Reply with quote
the others were fine .. that one showed up on the dyno run as defective .. I replaced that one with new and now the bike is mostly together now.. the removed/ defective one I`ll get cleaned.
where will you be sending yours to ?
caveat emptor
Copycat73
PostPosted: 12:21 - 17 Sep 2015    Post subject: Reply with quote
mostly done .. stripped out and cleaned the fuel pump..
the fuel filter was minging and @ 19k miles ..
replaced the 0 ring seal on the base and fired up...
just the plastics to go back on.
caveat emptor
The last post was made 10 years, 354 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 88.77 Kb
