Replacement brake Discs/Rotors
joezxr
PostPosted: 15:03 - 14 Sep 2015    Post subject: Replacement brake Discs/Rotors Reply with quote
My front brake discs on my 03 zx6r are warped and jolt on and off when braking heavily so they need replacing.
Iv never had to buy new discs before so im not sure where to start, i dont mind spending a bit of cash but i cant afford brembos lets put it that way Embarassed
There are a few sets on eBay called armstrong from japan for around £150 which i can imagine will be terrible?
or i can buy EBC ones at around £250 for a pair which iv also heard are not great...
or i can maybe get some low milage OEM ones from a newer zx6r (thats if they are all the same fitment???)
does anybody know what the best option would be for me?
many thanks! Mr. Green Thumbs Up
MCN. This post is not being displayed because the poster is banned. Unhide this post / all posts.
kramdra
PostPosted: 15:37 - 14 Sep 2015    Post subject: Reply with quote
If its not result of a disc lock I would first give them a good clean, make sure all the bobbins are free so the disc can move. Also check for cracks which commonly spread out from the drilled holes.
Then I would get a DTI and measure it before buying new OEM discs.
joezxr
PostPosted: 17:06 - 14 Sep 2015    Post subject: Reply with quote
sounds like a plan to me, is there a special way to clean them? Iv been spraying the bobbins with brake cleaner and tapping them with a rubber mallet so far Embarassed
PostPosted: 17:52 - 14 Sep 2015    Post subject: Reply with quote
I've seen people tighten a nut and bolt through a bobbin then get ther end of the bolt in an electric drill and spin them while spraying brake cleaner on.
Armstrong discs are ok.
OEM discs are best.
joezxr
PostPosted: 18:57 - 14 Sep 2015    Post subject: Reply with quote
Just checked the bobbins they do look pretty caked up!
Also just tried to give the old tighten a bolt through it trick a go and none of them will turn Rolling Eyes not sure if all discs bobbins spin???
joezxr
PostPosted: 19:10 - 14 Sep 2015    Post subject: Reply with quote
Vincent wrote:
If they're big round silver things, they move. Did you give them a good soaking with brake cleaner? They don't like to move if dry. Don't be tempted to use anything but brake cleaner as it's hard to get it out again and, as the wheel spins up, it'll get chucked on the pads Wink
yup big silver things with holes in the middle lol might give them a soak in wd40, then rinse them out with brake cleaner tomorrow and try again Wink
kramdra
PostPosted: 23:08 - 14 Sep 2015    Post subject: Reply with quote
Ive also tried cleaning mine, than gave up. My bobbins couldnt be turned with a bolt and are pretty stuck, but since they are not warped Ive been quite happy to ignore them Embarassed
Bobbins have a clip and are removable, which will separate the disc from the inner. I don't know if thats a good idea.. but I probably would. The clips should probably be replaced when disturbed, and in the same alignment.
sickpup
Old Timer
PostPosted: 11:05 - 19 Sep 2015    Post subject: Reply with quote
Many aren't removable, the bobbin is actually a rivet.
The last post was made 11 years, 5 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 70.71 Kb
