Moving the Location of a Rectifier
Motorhate
PostPosted: 16:42 - 24 Sep 2015    Post subject: Moving the Location of a Rectifier Reply with quote
I have the rectifier on my bike mounted in a very precarious position - i.e. right at the bottom of the frame of my bike, which worries me that it could get damaged if I hit a bump or speed hump and get torn off. I want to move it to a safer location, not too far away but away from the bottom of the frame and was wondering if there were a set of male and female leads I could simply attach to extend the range. Is there such a thing or would I have to somehow re-wire the existing wiring loom to allow it to be moved?
Current - Harley Davidson FXDB Street Bob | Harley Davidson FLTR Road Glide | Harley Davidson Road King
GONE - Honda CB500 Ratbike | Yamaha FZ750 | Yamaha XVS1100 | Kawasaki VN2000 | Kawasaki ER-6 F | Harley Davidson XL883L Sportster
Matt B
PostPosted: 17:28 - 24 Sep 2015    Post subject: Reply with quote
Soldering iron, wire, heat shrink. Extend wires, move reg/rec, job jobbed.
Try to put it somewhere it can dissipate its heat with some airflow over it.
Casper
PostPosted: 17:30 - 24 Sep 2015    Post subject: Reply with quote
Make a couple of foot loom and move it to somewhere that will get a bit air flow. All you want is the male and female side of your connector and whatever length of wire you need. You can get a sheath for the wire but i prefer loom tape. You should get it all here
https://stores.ebay.co.uk/towzatronics/
PostPosted: 17:57 - 24 Sep 2015    Post subject: Reply with quote
The mouldings for the multi-pin connectors tend to be unique to each reg/rec.
BUT
The connectors inside them are not. You can buy those over the counter.
You can, with either the proper terminal removal tool or patience and a small screwdriver wiggle the connectors out of the moulding.
So. Neatest way I can think of doing the job.
1) Mark the wire positions in the moulding.
2) Wiggle the wires out of the moulding with terminals attached.
3) Snap the terminals into a new, 6-wire connector block.
4) Attach the other end of the connector block to a new, multi-core cable. The stuff they sell for towbars is ideal, works out very neat and saves wrapping.
5) Attach new terminals for connectors to the far end or your multi-core cable and snap them back into your original moulding.
This place also has most things you'd need. Watch the postage and VAT!
https://www.vehicle-wiring-products.eu
Motorhate
PostPosted: 18:02 - 24 Sep 2015    Post subject: Reply with quote
Thanks everyone, will probably try this next week.
Fizzer Thou
PostPosted: 18:21 - 24 Sep 2015    Post subject: Reply with quote
Pictures of the rectifier and its present location would be useful.Then work out where you would like to relocate it to Thumbs Up
Always have a 'Plan B'
andys675
PostPosted: 20:22 - 24 Sep 2015    Post subject: Reply with quote
even manufacturers move them
1050 sprint and daytona 675 had them in better places in later production
PostPosted: 11:30 - 25 Sep 2015    Post subject: Reply with quote
A lot of factory customs/cruisers have the reg/rec mounted on the bottom of the frame near the front engine mounts as standard, presumably because that's where Harley put them.
Oldie
PostPosted: 17:19 - 25 Sep 2015    Post subject: Reply with quote
The early Deauvilles went through reg/recs like crazy. Used to try using thermal paste and also run an extra neg lead direct to the battery (but I can't remember exactly why Confused )
The last post was made 10 years, 348 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.45 - MySQL Queries: 13 - Page Size: 65.31 Kb
