Bike Wont Start
djjohnjones
PostPosted: 13:09 - 26 Sep 2015    Post subject: Bike Wont Start Reply with quote
Hello i have a piaggio nrg power 50cc i dont know alot about bikes i was rebuilding the whole bike with someone that knew alot unfortunately they wont help me any more everything on the bike is done however it wont start the piston is moving fuel is getting into it i have a good spark but can't work it out when i go to start it sometimes the oil light will come on not sure if this has anything to do with it Please Help
Val
PostPosted: 17:07 - 26 Sep 2015    Post subject: Re: Bike Wont Start Reply with quote
Can you kick start it? https://www.youtube.com/watch?v=DSOBg6bUGWg
When you hit the start does the starter motor turns and how much time?
Have you tried to jump start it with jump leads and someone's car battery? Note keep the car engine off if you try just connect the leads.
If the starter spins fine try starting fluid to check is the bike starting at all by spraying some starting fluid in the air intake like in this video:
https://www.youtube.com/watch?v=UaeCFtzW9Xg
Buy starting fluid here:
https://www.halfords.com/motoring/engine-oils-fluids/fuel-oil-additives/bradex-easy-start-300ml
If the bike starts with starting fluid, but does not starts otherwise you have fuel supply issue.
You may have old fuel that is no good there. Means you may need to empty the tank, take off the carb and clean it with carb cleaner.
Than add new fresh fuel and it will start.
Or clogged fuel supply lines. Or fuel vacuum valve issue.
Just let us know does it start with starting fluid?
djjohnjones
PostPosted: 17:44 - 26 Sep 2015    Post subject: Reply with quote
I dont have starting fluid but i sprayed a bit of wd40 in there as someone told me that would start it it still didnt start. The starter motor works fine everything turns inside. The fuel and oil are new and everything has been cleaned. The engine has been rebuilt. Is it possible if my stator was damaged it could cause the bike to not start
djjohnjones
PostPosted: 19:21 - 29 Sep 2015    Post subject: Reply with quote
Hello i swapped the carbs over and still wont star but this time i now have no spark i am sure it is something to do with the alternator/stator
zark
PostPosted: 10:38 - 30 Sep 2015    Post subject: Reply with quote
i'm no expert (in anything)
But the stator/alternator is only useful because it takes the spinning engine, some magnets and some wire and makes it into electricity that it can pass back to the battery to charge it up. (I think that's pretty much how it works... might be some magic involved too)
As such - i don't know a faulty stator - or even no stator would stop your engine from running...
You need fuel, air and a spark. All at the right time.
If one of them's missing - you won't get a running bike. Don't stress about the stator until it's running and then the battery goes flat.
Check fuel is getting to carb. check carb. check spark. Then worry about timing... that's where i'd be looking
CBT - Oct 13. Theory - July 14. Mod 1 & 2 - June 15.
Rides a Fazer like an idiot... Edit: Now ride a Fazer Thou...
Major Doss
PostPosted: 00:18 - 02 Oct 2015    Post subject: Reply with quote
Fit the correct powerband. Your machine has obviously been fitted with a red one. You need a pink headed one. Turn it on and run it up and down gently for a few minutes. Increase your revs gradually, and you will come to a great result.
djjohnjones
PostPosted: 18:15 - 02 Oct 2015    Post subject: Reply with quote
Hello the tool for the flywheel removal was the wrong one so got to get them to send right one out. I used starter fluid today and it was still turning and the odd time it would try to start for half a second if that any advice
zark
PostPosted: 19:00 - 02 Oct 2015    Post subject: Reply with quote
So after blaming the stator for not producing a spark, you're removing the fly wheel?
In that case, I'm out of ideas as to what it could be Confused
PostPosted: 19:25 - 02 Oct 2015    Post subject: Reply with quote
Searches thread for "meter".
Not found.
Keep guessing, OP. If you throw another few hundred quid of random parts at it, might get lucky.
Whatever you do, do not invest £5 or ten minutes in actually diagnosing your problems. Where's the fun in that?
djjohnjones
PostPosted: 23:20 - 02 Oct 2015    Post subject: Reply with quote
I only guessed it my be the stator as im running out of things it could be. I also dont know a massive about bikes and just wanted some help
PostPosted: 23:32 - 02 Oct 2015    Post subject: Reply with quote
Stop guessing.
Spend £5 on a multimeter.
Invest 10 minutes in watching YouTube vidoes on how to use it.
You can now follow one of the many, many, many guides on Google it diagnosing motorcycle electrical problems.
WD Forte
PostPosted: 23:36 - 02 Oct 2015    Post subject: Reply with quote
Burn it
Put it out of its misery
bikers smell of wee
djjohnjones
PostPosted: 02:07 - 03 Oct 2015    Post subject: Reply with quote
I have a multi meter and know how to use it
PostPosted: 09:36 - 03 Oct 2015    Post subject: Reply with quote
Then I suggest that you do.
Voltage, continuity, resistance at all the appropriate places as per the easily Googlable guides.
Honestly, I don't know what else you expect, other than to ask if you've checked the obvious stuff like fuses, kill switch, battery, earth strap.
djjohnjones
PostPosted: 10:35 - 03 Oct 2015    Post subject: Reply with quote
I know its not electrical faults as they have just recently been on a previous bike
zark
PostPosted: 13:11 - 03 Oct 2015    Post subject: Reply with quote
So the components may not be faulty... What about the connections and wires joining them together? A meter will help here
The last post was made 10 years, 350 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.14 - MySQL Queries: 13 - Page Size: 89.66 Kb
