Suzuki GP100 restoration - SPARK ISSUE
toby_trice
PostPosted: 09:01 - 14 Oct 2015    Post subject: Suzuki GP100 restoration - SPARK ISSUE Reply with quote
Hey,
This is my first post to the forum and would be very grateful if anyone is able to help me out.
I have just purchased a 1988 Suzuki GP100 and has been sat for at least 2 years from what I understand.
When attempting to start the engine there is no spark.
I have taken the HT lead out and replaced the spark plug but each time I kick the engine over there is no spark. The very, very odd occasion I do see a spark but it is very weak.
Any suggestions as to what I can do?
pepperami
PostPosted: 11:28 - 14 Oct 2015    Post subject: Reply with quote
Hmm? things to look at? possibly? maybe?
1. points
2. condenser
3. HT cap
4. HT lead
5. Coil
6. Plug
cb1rocket
PostPosted: 11:36 - 14 Oct 2015    Post subject: Reply with quote
check, clean and adjust the contact breaker. Left hand side of engine casing
toby_trice
PostPosted: 12:03 - 14 Oct 2015    Post subject: Reply with quote
Thanks!
I've checked the plug and points. Does the gp100 require a battery at all? I have made the assumption it doesn't need a battery for the engine to run.
Will have to check the other items.
Just frustrating as I get the occassional spark but it's very weak.
pepperami
PostPosted: 14:33 - 14 Oct 2015    Post subject: Reply with quote
toby_trice wrote:
Thanks!
Just frustrating as I get the occasional spark but it's very weak.
No ignition light means circuit not complete = no spark .
I`m surprised that if you have no battery in and no ignition light on, that you`re getting a spark at all?
toby_trice
PostPosted: 19:20 - 14 Oct 2015    Post subject: Reply with quote
Want I am trying to understand is, does the gp 100 require a battery as part of the kick start.
I'm led to believe that you don't which is what I want to confirm. There will be no ignition light with this bike due to the nature.
bypass2
PostPosted: 19:33 - 14 Oct 2015    Post subject: Reply with quote
A gp100 should run without a battery with the ignition on.spray some WD 40 inside the flywheel around the points . wood ruff key maybe worn. clean the points.
A100man
PostPosted: 21:51 - 14 Oct 2015    Post subject: Reply with quote
Indeed. The battery is a only a small reservoir for running lights/indicators at low revs (stopped at junction etc..) Ignition circuit is separate and uses separate source coil. Deffo check or better still replace points maybe also condenser. Then if all else fails new coil.
cb1rocket
PostPosted: 22:07 - 14 Oct 2015    Post subject: Reply with quote
Where are you located? I would help get you going
toby_trice
PostPosted: 18:31 - 16 Oct 2015    Post subject: Reply with quote
Thanks for your help, those with helpful things to say.
Will give these things a try.
I'm down in kent near Dover.
PostPosted: 22:47 - 16 Oct 2015    Post subject: Reply with quote
Not too far from me and I've built mine up from no spark. Laughing
Can you get to maidstone at all?
toby_trice
PostPosted: 12:01 - 18 Oct 2015    Post subject: Reply with quote
I have no way really of getting the bike to Maidstone, going to have a tinker next week and see if I can make any progress.
Thanks!
toby_trice
PostPosted: 12:09 - 18 Oct 2015    Post subject: Reply with quote
Thanks!
toby_trice
PostPosted: 12:10 - 18 Oct 2015    Post subject: Reply with quote
Absolute newbie when it comes to bikes.
What is the Woodruff key and its purpose?
Shall try some wd40 in the flywheel.
Triton Thrasher
PostPosted: 13:13 - 18 Oct 2015    Post subject: Reply with quote
Are the faces of the points clean of dirt and corrosion,, free from oil or grease (or WD40) and set to the correct gap when fully open?
Rrrrrrrrrrrrrrrrrr
A100man
PostPosted: 13:29 - 19 Oct 2015    Post subject: Reply with quote
Woodruff key locates the 'flywheel' magneto thingy onto teh crankshaft accurately. As menstioned unless it's damp WD40 might hinder more than help.
IIRC the low-tension timing signal/wire is black and yellow coming from the magneto. If you get someone to hold this close to the frame or other earthing point and kick over the engine you should see some evidence of electricity (sparks) - if not then you have a problem with points of source coil.
bladerunner
PostPosted: 07:11 - 24 Oct 2015    Post subject: Reply with quote
Yup sounds like the usual points+ condenser need cleaning/replacing after not being used for a while
The last post was made 11 years, 27 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.15 - MySQL Queries: 13 - Page Size: 88.5 Kb
