| toby_trice |
 toby_trice L Plate Warrior
| pepperami |
 pepperami Super Spammer
| cb1rocket |
 cb1rocket World Chat Champion
| toby_trice |
| pepperami |
| toby_trice |
| bypass2 |
 bypass2 Spanner Monkey
| A100man |
 A100man World Chat Champion
 Posted: 21:51 - 14 Oct 2015 Post subject: |
| bypass2 wrote: | A gp100 should run without a battery with the ignition on.spray some WD 40 inside the flywheel around the points . wood ruff key maybe worn. clean the points. |
Indeed. The battery is a only a small reservoir for running lights/indicators at low revs (stopped at junction etc..) Ignition circuit is separate and uses separate source coil. Deffo check or better still replace points maybe also condenser. Then if all else fails new coil. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| cb1rocket |
| toby_trice |
| P.addy |
 P.addy Red Rocket
 Posted: 22:47 - 16 Oct 2015 Post subject: |
Not too far from me and I've built mine up from no spark.
Can you get to maidstone at all? |
| toby_trice |
| toby_trice |
| toby_trice |
| Triton Thrasher |
 Triton Thrasher Could Be A Chat Bot
| A100man |
 Posted: 13:29 - 19 Oct 2015 Post subject: |
| toby_trice wrote: |
What is the Woodruff key and its purpose?
Shall try some wd40 in the flywheel.
Cheers |
Woodruff key locates the 'flywheel' magneto thingy onto teh crankshaft accurately. As menstioned unless it's damp WD40 might hinder more than help.
IIRC the low-tension timing signal/wire is black and yellow coming from the magneto. If you get someone to hold this close to the frame or other earthing point and kick over the engine you should see some evidence of electricity (sparks) - if not then you have a problem with points of source coil. ____________________ Now: A100, SRX250, XJ598, FZ750, SL1000
| bladerunner |
The last post was made 11 years, 27 days ago. Instead of replying here, would creating a new thread be more useful? |
