Its not vertical, I swear.
blackbosh
PostPosted: 18:14 - 21 Nov 2015    Post subject: Its not vertical, I swear. Reply with quote
My Bike (2015 R1200GS) feels like its leaning when riding. I noticed it more when I had the missus on the back, sorry the missus pointed out I didn't look like I was in the middle of the bike and when I shifted it felt very wrong. The bars don't look like they line up with the fairing either. Being shaft drive I can't adjust the rear wheel so... Help, please?
Fidge This post is not being displayed because the poster is banned. Unhide this post / all posts.
blackbosh
PostPosted: 18:33 - 21 Nov 2015    Post subject: Reply with quote
its only when riding to be honest. Is there some kind of wheel alignment check I can do?
Itchy
PostPosted: 19:02 - 21 Nov 2015    Post subject: Reply with quote
Twisted forks in yokes?
blackbosh
PostPosted: 19:07 - 21 Nov 2015    Post subject: Reply with quote
bugger I hope not, only done 2.5k.
blackbosh
PostPosted: 19:23 - 21 Nov 2015    Post subject: Reply with quote
No, but I have done some very light off roading wonder if Ive hit too many bumps for it. Tyre pressures were fine last time I checked. Unless the TPG is now lying.
smegballs
PostPosted: 21:02 - 21 Nov 2015    Post subject: Reply with quote
De-twisting forks is not big deal
https://www.youtube.com/watch?v=vSunBRB6-r8
temeluchus
PostPosted: 23:22 - 21 Nov 2015    Post subject: Reply with quote
Doubt you'd twist a telelever.
Out of interest, do you have a back problem?
MCN
PostPosted: 23:26 - 21 Nov 2015    Post subject: Reply with quote
They use telelever suspension (to prevent the bike diving down at the front when braking. The bike will drop sort of parallel with the road surface.) so the 'forks' only serve are guides for the front wheel.
Check the alignment 1st with string between the rear and front wheels.
Check both side and extrapolate the difference. It should be almost 0ยบ diff between L&R. (you need to make some allowance for the difference in tyre width.)
Google checking bike wheel alignment. Some phaph with a length of wood but string is simpler and easier to find in your hoose. Smile
Taught2BCauti...
PostPosted: 10:48 - 22 Nov 2015    Post subject: Reply with quote
First bike I ever rode, on my CBT, felt like it was pulling to the left and needed some force to get it to turn right. Instructor agreed, saying the forks were twisted, and swapped the bike.
Honda Varadero XL125(V8)
www.TheFutureIsHere.eu
blackbosh
PostPosted: 16:13 - 22 Nov 2015    Post subject: Reply with quote
Thanks for the comments, I shall get busy this weekend. Now I know what to look for I won't be putting it off anymore
blackbosh
PostPosted: 16:41 - 22 Nov 2015    Post subject: Reply with quote
26 and healthy so nope...
MCN
PostPosted: 16:51 - 22 Nov 2015    Post subject: Reply with quote
Oh well, that rules out Stephen Hawking using a sock account to post on here. Rolling Eyes
Very Happy
blackbosh
PostPosted: 20:39 - 22 Nov 2015    Post subject: Reply with quote
1 arms longer than the other though, if that helps
Cool
temeluchus
PostPosted: 21:10 - 22 Nov 2015    Post subject: Reply with quote
you may just be going mad.
blackbosh
PostPosted: 23:37 - 23 Nov 2015    Post subject: Reply with quote
Quite possibly.
hmmmnz
PostPosted: 01:09 - 24 Nov 2015    Post subject: Reply with quote
if i remember rightly, bmws run off set alignment on some models.
so the rear can be as far as 25mm off set from center to the left
bmw got a bit lazy and couldnt be fucked changing the engine/swing arm design when adding fatter wheels to the rear, so just spaced out the wheel.
normally you dont notice it though
the humans are dead
I kick arse for the lord
PostPosted: 09:55 - 24 Nov 2015    Post subject: Reply with quote
I thought the torque reaction of the motor meant that you always ride slightly on-the-cock?
PostPosted: 12:45 - 24 Nov 2015    Post subject: Reply with quote
Would the gyroscopic effect of the wheels not cancel that out in normal riding?
PostPosted: 13:51 - 24 Nov 2015    Post subject: Reply with quote
Get someone else to ride it. You ride round all sorts of issues before noticing something is wrong.
PostPosted: 13:58 - 24 Nov 2015    Post subject: Reply with quote
I've ridden a Rocket 3, and I didn't notice it at anything above say 20mph, if you are stopped and you rev you can feel it kick and if you are going slow and smash the throttle open you feel it then too but not in normal riding.
MCN
PostPosted: 19:37 - 24 Nov 2015    Post subject: Reply with quote
I had two R1200GS there is no effect of 'torque' reaction that would cause the bike to track.
If the frame/wheels are out of alignment then the bike will try to follow the alignment.
hmmmnz
PostPosted: 01:00 - 25 Nov 2015    Post subject: Reply with quote
you don't get the "jacking" on the paralever bikes,
only the monolever or twin shock bikes,
ive never noticed the mis alignment to show up when you are riding.
my money is on the wheel being twisted in the forks/yokes
the humans are dead
The last post was made 10 years, 307 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 127.33 Kb
