| DRZ4Hunned |
 DRZ4Hunned World Chat Champion
| stinkwheel |
 Posted: 18:02 - 16 Dec 2015 Post subject: |
I wouldn't see past the tucano urbano neoprene boxing glove type.
I'd expect them to fit pretty much any bike.
Two main sorts. Ones for bikes with bar ends and one for bikes without bar ends.
Looks like yours has bar ends so that type. Old style R361 which has the plastic bit that stops them pulling your brake on inside or R363 for the newer style with the rigid part on the outside.
I own a pair of the former. The latter look easier to put on and off and a tad less draughty.
EDIT: Handguards might interfere. If they are just plastric ones, I'd still recommend the tucano urbanos but take the handguards off. If they are rigid "barkbuster" type handguards that also protect your levers, I'd go with some other sort.
The oxford ones are shite. Had some. Used once then thrown away. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Itchy |
 Itchy Super Spammer
| Rogerborg |
 Rogerborg nimbA
| DRZ4Hunned |
| G |
 G The Voice of Reason
| DRZ4Hunned |
| G |
| DRZ4Hunned |
| G |
| DRZ4Hunned |
| G |
| DRZ4Hunned |
| G |
| stinkwheel |
| DRZ4Hunned |
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:44 - 17 Dec 2015 Post subject: |
Try £1.94 delivered. They work, and there's no reason that they shouldn't since they're just a couple of resistors, a switch and some heat shrink.
Delivery time would be my priority at the moment. ____________________ Biking is 1/20th as dangerous as horse riding.
| DRZ4Hunned |
| Rogerborg |
 Rogerborg nimbA
 Posted: 14:13 - 17 Dec 2015 Post subject: |
| DRZ4Hunned wrote: | Think I'll buy these and go for the heated grip/muff combo, I like how they've demonstrated them over the top of the grips on the pictures  |
Problem? That's how I fitted mine - that exact kit. The only issue is ensuring there's enough slack in the cable to the throttle side. Also, make sure the heat shrink is holding the cables against the grip, or whip a cable tie around so that the cable isn't tugging at the connectors on the pads.
You can ignore MCN's ratings, he's just on a sperg-sulk again because I downrated him for parroting about chickens. ____________________ Biking is 1/20th as dangerous as horse riding.
The last post was made 10 years, 318 days ago. Instead of replying here, would creating a new thread be more useful? |
