Brake Line Extension Piece
Oldie
PostPosted: 07:44 - 21 Dec 2015    Post subject: Brake Line Extension Piece Reply with quote
Hoping to pull the bars back on my F800GT without stretching the brake line and wondered if there's a simple low cost solution using an extension to the existing fitting. I had a look around but, to be honest, I'm not sure what I should be looking for Embarassed All other cables will be fine.
Here's a pic of the current set up.
https://lh3.googleusercontent.com/-K_LTAst5j60/VneeR5AiOkI/AAAAAAAAFEg/iRFEXYgui_I/s800-Ic42/IMG_20151221_063147314%25255B1%25255D.jpg
Oldie
PostPosted: 08:42 - 21 Dec 2015    Post subject: Reply with quote
Something like this from the States might be what I need although I was hoping for a fixed, say, 2" connector, rather than an extra piece of brake hose.
Trouble is, can't seem to find UK suppliers of either option.
https://lh3.googleusercontent.com/-xBDcFlYc6x0/Vnespib_YkI/AAAAAAAAFFA/5NGQ9gDf53Q/s800-Ic42/f800st_line_extension.jpg
PostPosted: 09:09 - 21 Dec 2015    Post subject: Reply with quote
Have you had a look at where the brake line runs? If it's like my GS, it'll run back to the ABS unit, not straight down to the brakes. Do you actually need to extend it?
Oldie
PostPosted: 09:20 - 21 Dec 2015    Post subject: Reply with quote
The GT has a short straight cable that runs from the bars to a junction box fixed to bottom yolk. Unfortunately there is only room for a very small amount of re-positioning using an angle bracket (which I previously installed for 20mm risers) but I've used up all the "slack" putting 2" Rox risers on. They work fine height-wise, but with minimal pull back, so I need an extra bit of play and extending the brake line is almost certainly the only option.
PostPosted: 09:21 - 21 Dec 2015    Post subject: Re: Brake Line Extension Piece Reply with quote
I'd have thought the 'simple low cost' solution would be just to replace it with a longer one?
Get on ebay and I expect you can find longer ones second hand for not much.
Oldie
PostPosted: 09:26 - 21 Dec 2015    Post subject: Reply with quote
I did think about replacing the cable but I'd prefer not to have to bleed the BMW abs system. I reckon that an extension could go on without bleeding if I take the front caliper off an get the pistons out to their max. Maybe I'm wrong on that point.
PostPosted: 09:58 - 21 Dec 2015    Post subject: Reply with quote
If it's the same system as on the 800 GSes, bleeding shouldn't be an issue.
Unlike on older BMW systems which appear to be a right sod to do, the ABS circuit is sealed off from the normal lines. You can drain/bleed/flush the lines right through and the fluid in the ABS part won't be disturbed.
The Motorrad Monkeys have a gadget that will hold the ABS valve open so that you can flush / bleed that circuit at the same time, but you don't need to.
Ostensibly you can renew the ABS fluid by renewing the fluid in the normal line then triggering the ABS a few times to open the valve, then renewing again. I'm not 100% convinced that will be completely effective, but unless you actually want to renew that fluid it's not an issue - I drained and renewed the front circuit on my GS without any problems or trickery.
Oldie
PostPosted: 10:11 - 21 Dec 2015    Post subject: Reply with quote
I had a brake fluid change recently so I can safely ignore the ABS for now. I did suspect that the bleeding process had been simplified and that would certainly make life easier if I simply install a longer brake line. I was working on the belief that an extension piece would be cheaper, hence the reason that Verholen etc include these in riser kits, rather than a longer brake hose.
bugeye_bob
PostPosted: 10:44 - 21 Dec 2015    Post subject: Reply with quote
Id do it properly, any joint is just another place for a leak to spring while out,
You will have to bleed the brakes to fit the small pipe and jointer so you may as well do it properly in one go.
PostPosted: 10:49 - 21 Dec 2015    Post subject: Reply with quote
How are you going to fit the extension piece without having to bleed?
Hahadumball
PostPosted: 17:18 - 21 Dec 2015    Post subject: Reply with quote
hes going to use the force
Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015
iooi
PostPosted: 17:22 - 21 Dec 2015    Post subject: Reply with quote
So just how to you propose to manage to do it without bleeding the system?
You are going to have to undo a connection. which will mean fluid leak's out and air gets in..
Just get longer brake lines.
Copycat73
PostPosted: 18:05 - 21 Dec 2015    Post subject: Reply with quote
Oldie wrote:
there is a shop in newcastle upon tyne which makes bespoke braided lines ..
quite sure i`ve seen ends as pictured loose in his shop window display
he makes the lines up himself ..
caveat emptor
PostPosted: 18:08 - 21 Dec 2015    Post subject: Reply with quote
Add an extension carefully to the top of the line would result in minimal fluid loss and all the air would start near the reservoir. Pretty much trivial to reverse bleed out, and an interesting suggestion given the reasonable concerns about bleeding past the ABS unit.
PostPosted: 09:18 - 22 Dec 2015    Post subject: Reply with quote
That's very ghetto - I love it.
I've never been sure of the point of those stops on M/Cs. Anyone?
PostPosted: 09:37 - 22 Dec 2015    Post subject: Reply with quote
They stop the banjo rotating to prevent strain on the hose when the bolt is tightened. I've cut a few off here and there you just have to be careful to hold the banjo in the right spot.
Oldie
PostPosted: 20:52 - 22 Dec 2015    Post subject: Reply with quote
Looks like there are a couple of options out there. Verholen or Wunderlich supply a 2" metal extension piece with their riser kits but don't sell them separately but a bit of digging should turn up something.
Oldie
PostPosted: 05:51 - 23 Dec 2015    Post subject: Reply with quote
Thanks Vincent - that just might do the trick Thumbs Up
The last post was made 10 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 113.46 Kb
