How far does a watercooled 2 stroke go without coolant?
Fidge This post is not being displayed because the poster is banned. Unhide this post / all posts.
redeem ouzzer
PostPosted: 17:52 - 22 Dec 2015    Post subject: Re: How far does a watercooled 2 stroke go without coolant? Reply with quote
Fidge wrote:
3.5 miles Pale
Knob.
Be a REAL MAN!
RhynoCZ
PostPosted: 17:54 - 22 Dec 2015    Post subject: Reply with quote
Why, just why would you even, why?! Confused
Wonko The Sane
PostPosted: 18:02 - 22 Dec 2015    Post subject: Reply with quote
has it simply seized and needs to cool down, some tlc, new oil and coolant
or has it melted like a twix in a furnace?
pdg
PostPosted: 18:25 - 22 Dec 2015    Post subject: Reply with quote
Fidge wrote:
all the coolant got sucked out of the radiator and pump and dumped into and out of the reservoir. I think it's the thermastors fault because I'd never used it before.
Anyone translate that to english?
Any and all advice given should not be followed - if you have to ask it means you don't know so get a man in to do it for you.
Ed Case
PostPosted: 20:15 - 22 Dec 2015    Post subject: Reply with quote
Stacks of good advice there !.
stevo as b4
PostPosted: 20:19 - 22 Dec 2015    Post subject: Reply with quote
Nylock nuts on the cylinder head?? Shocked
Oh and I wouldn't if I were you give up your day job to concentrate on your 2stroke engine building talents either.
The motor will be rubber ducked now, and probably not worth trying to re-build.
Did you even check that the water pump was working after your first overheating issue? it's not unknown for water pump impellors to fall off the drive shaft or the shaft to seize or break, especially when they are sometimes driven by nylon gears etc.
I could be wrong but I bet the big end looks purple and blue and smells very burnt now too. You might be able to save a set of crank cases and maybe the gearbox internals etc if your lucky.
Poor NSR though! Thumbs Down
PostPosted: 20:41 - 22 Dec 2015    Post subject: Reply with quote
Fidge wrote:
I got the cylinder barrel from my project bike repaired and overbored and put a head I bought on ebay on there and used the thermostat without checking (forgot to swap with the original on the bike) it worked.
The NSR uses a plated bore and cannot be rebored.
Katy
monkeybiker
PostPosted: 21:59 - 22 Dec 2015    Post subject: Reply with quote
Could it be the head gasket has failed?
pdg
PostPosted: 22:40 - 22 Dec 2015    Post subject: Reply with quote
Fidge wrote:
Got the plating removed, bored, welded, plated then honed, then I melted it Wink
FTFY
Anyway, it won't be the thermostat - whether it works or not it wouldn't cause the symptoms you describe.
Also, you could run the thing with pure water in (just like a racebike innit) - 'coolant' is antifreeze and corrosion inhibitor - it does nothing whatsoever to raise the boiling point. What does raise the boiling point is increasing the pressure.
You left air in the system.
Then, you took out the remaining coolant/water and left air in the system again.
PostPosted: 23:00 - 22 Dec 2015    Post subject: Reply with quote
Yep, antifreeze makes the water a marginally worse as a coolant.
Katy
pdg
PostPosted: 07:07 - 23 Dec 2015    Post subject: Reply with quote
Also, just re-read some of this...
You said you bled the system correctly, but later went on to attempt to fill it by pouring the coolant into the reservoir?
Is that how you initially filled it? If so, you need a better manual.
It's all a bit academic now anyway - if you had treated it well after the very first overheat you might've got away with it (if it weren't for those snooping kids) but to rag the arse off it after overheating it multiple times, well, it's fucked.
It might still run, if the rings aren't too melted to the bore, but it'll not be 'right' without another rebuild.
skatefreak
PostPosted: 10:09 - 23 Dec 2015    Post subject: Reply with quote
Its a 2-smoke...
New barrel and piston and chances are you're on your way again Rolling Eyes
Expensive derp none the less tho.
kovy
PostPosted: 12:39 - 23 Dec 2015    Post subject: Reply with quote
wow, somebody really tried that Smile
The last post was made 10 years, 286 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.17 - MySQL Queries: 13 - Page Size: 111.88 Kb
