| stinkwheel |
 Posted: 18:06 - 08 Jan 2016 Post subject: Toilet plumbing question |
The downstairs cludgie in my house has been subject to a shonky installation.
The waste pipe goes from the U-bend straight down through the floor and into the sewer.
Not normally a problem until there is a lot of water in the sewer (like with recent rain) and the water level covers the end of the waste pipe.
If this happens, it forms an airlock in the waste pipe and the water can't get away. The toilet can actually start to backfill. I have to put a bit of hosepipe down round the u-bend to let the air in and the waste can get away.
Anyone know of some sort of valve I could fit to let air into the system but not let foulage out?
The trouble is, there is no conventional "vertical" waste pipe. It comes out of the back of the bog then does a 90 degree turn down into the floor then underground about 4 feet to the sewer. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Sload |
 Sload World Chat Champion
| Nobby the Bastard |
| Ariel Badger |
 Ariel Badger Super Spammer
| Nobby the Bastard |
| Hahadumball |
 Hahadumball World Chat Champion
| stinkwheel |
 Posted: 19:35 - 08 Jan 2016 Post subject: |
A manual valve might in fact be enough. It's just finding a way to fit one.
Even a simple 1/4 turn gate valve in the top of the waste pipe would porobably do it.
Mind you. I'd need to put my fish fingers into a tupperware before opening it, just in case. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Hahadumball |
| Al |
 Al World Chat Champion
 Posted: 19:46 - 08 Jan 2016 Post subject: |
McAlpine make a straight and an angled pan connector with a 32mm connection for a basin which you could fit a small air admittance valve to if you can easily replace the pan connector. ____________________ Yamaha FZR400RR 3tj
My Instagram Thingy |
| Itchy |
 Itchy Super Spammer
 Posted: 20:43 - 08 Jan 2016 Post subject: |
Poop at work? /thread ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Sload |
| stinkwheel |
| hellkat |
 hellkat Super Spammer
| Tracey Suntan-King |
 Tracey Suntan-King World Chat Champion
| Nobby the Bastard |
| Hahadumball |
| stinkwheel |
| G |
 G The Voice of Reason
| Sload |
 Posted: 06:38 - 11 Jan 2016 Post subject: |
Physically move the toilet forward to allow you to fit something between the Ubend and the elbow if you have the room, or possibly have to drill and bond into the top part of the pipe at the elbow.
Why have I never thought of toilet physics before
Change of toilet perhaps? Is there something available that suits your circumstance? ____________________ Honda Varadero >> Triumph Speed Four >> Honda CBR1100xx |
| Hahadumball |
 Posted: 08:34 - 11 Jan 2016 Post subject: |
under the floorboards, remove a section of pipe fit a soil branch pipe that goes out the wall
go for around 110 - 120 degree around £20 from plumbers merchant.
Had to do exactly the same in our old house which was also plumbed in by a herp derp
https://i.imgur.com/7j5kfXY.png
do you have a bath and sink in the toilet?
if so are they all linked to the same pipes? if so youve got a greater choice of where to put the vent.
where i am at the moment i have toilet, bath and sink in same room but the bath and sink go to a pathetic 76mm drainage pipe and toilet goes straight down to the sewer.
Other option is to get a 90 degree pan connector with a built in vent hose and just run that straight up inside the house through the ceiling and out the roof.
easier less pretty
like so: https://www.jtmplumbing.co.uk/pipe-fittings-c433/toilet-pan-connectors-c187/viva-sanitary-90-flexible-pan-connector-32mm-adapter-1-1-4-pp7084 ____________________ Fin: no matter how much I look at It I can't understand what was going through my head, all I remember is going about 80 and redlining it to stop it seizing.
360 Deg... Five 1/4 turns. :- Teflon-Mike 18 Jan 2015 |
| hellkat |
| stinkwheel |
 Posted: 12:51 - 11 Jan 2016 Post subject: |
| Paul Fzs wrote: | under the floorboards, remove a section of pipe fit a soil branch pipe that goes out the wall
easier less pretty
like so: https://www.jtmplumbing.co.uk/pipe-fittings-c433/toilet-pan-connectors-c187/viva-sanitary-90-flexible-pan-connector-32mm-adapter-1-1-4-pp7084 |
Thanks for taking the time to do that.
I'm not seeing a good option that doesn't involve diggging up the patio unfortunately. It was dug up when a new water pipe was put in and I saw where the main pipe was but didn't know this was a problem at the time.
What I might be able to do is use a connector like the one you linked to then take a smaller diameter vent pipe out through the wall and up to gutter level. Still means drilling through the wall mind but I need to get a guy in with a core drill soon anyway so drilling two holes won't be much more expensive than drilling one.
Luckily all the real fuckwittery like that in this house is confined to a relatively small extension built by the same guy. You should have seen his combi boiler install!
paint diagram showing what's been installed:
https://www.bikechatforums.com/download.php?id=96977 ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| G |
| Hahadumball |
| Hahadumball |
The last post was made 10 years, 242 days ago. Instead of replying here, would creating a new thread be more useful? |
