Ground Anchor Recommendation
chickenstrip
PostPosted: 11:27 - 27 Jan 2016    Post subject: Ground Anchor Recommendation Reply with quote
I'm having a shed installed for the bikes soon. Size is 10' x 8', to hold both bikes but with room to work on one if the other is pushed outside (hopefully - I don't really have room for anything bigger). It will be on a concrete base, and I want to have ground anchors installed. I was thinking maybe something that won't protrude above floor level, just to make things a bit easier? Anything about that fits this description? Or if not, what ground anchor set-up can you recommend? Ta.
angryjonny
PostPosted: 12:38 - 27 Jan 2016    Post subject: Reply with quote
You're thinking of something like a Yanchor.
bugeye_bob
PostPosted: 12:49 - 27 Jan 2016    Post subject: Reply with quote
Retractable anchors exist.
https://www.bustersclassic.co.uk/proddetail.asp?prod=PJB508
https://www.nothingbutlocks.com/Autolok-KTGA-p/autolok%20ktga.htm#axzz3yRd3DlKe
hth
DRZ4Hunned
I was just going to ask this Shocked
By concrete base do you mean the shed will be mounted on a concrete base but have a standard flimsy wooden floor? Or there will be no floor and just the concrete base?
Not sure how it would work if you have a wooden floor without cutting a hole in it?
DRZ400-SM
FZS600
chickenstrip
PostPosted: 12:56 - 27 Jan 2016    Post subject: Reply with quote
The shed will have a wooden floor. The folks who are installing it are also doing the concrete base, and will install the anchor(s) when laying the base, cutting the floor to accommodate the anchors. I need to decide on and get the anchors myself before the installation date (end of Feb.). I'd probably best contact them with my anchor choice to make sure they can incorporate whatever I choose before ordering.
Can someone tell me what is the full width of a 19mm Almax chain please? Smile
angryjonny
PostPosted: 13:18 - 27 Jan 2016    Post subject: Reply with quote
By definition it would need to be more than 3x the 19mm metal gauge (probably nearer 4x) which is more than 57mm which is more than the 50mm a standard Yanchor can accommodate.
chickenstrip
PostPosted: 13:27 - 27 Jan 2016    Post subject: Reply with quote
This is what I was thinking, so I may not be able to go with a flush fit anchor after all. So, any other anchor recommendations that will do the job? Should I go for two anchors, or use one chain to secure both bikes (as the main security - will also use disc locks etc)? I see lots of anchors available, just wondered if anyone could suggest any particularly good ones, any general thoughts and ideas of the best way to go.
bugeye_bob
PostPosted: 13:33 - 27 Jan 2016    Post subject: Reply with quote
This is what I was thinking, so I may not be able to go with a flush fit anchor after all. So, any other anchor recommendations that will do the job? Should I go for two anchors, or use one chain to secure both bikes (as the main security - will also use disc locks etc)? I see lots of anchors available, just wondered if anyone could suggest any particularly good ones, any general thoughts and ideas of the best way to go.[/quote]
there are other anchors, I only gave an example.
BTTD
PostPosted: 13:52 - 27 Jan 2016    Post subject: Reply with quote
If you are setting the concrete yourself you could go crazy and bury some 68mm plastic gutter down pipe 150mm below the surface with two 45 degree bends to bring it up the the surface in a U type shape.
\ \__/ /
\____/
In the 150mm put some thick metal rebar rods, crisscrossed, bent so they extend further down into the concrete etc.
To get the anchor out you then have to pull out or cut through 6" (or more) of reinforced concrete.
Obviously check that the chain fits through the pipe before you concrete it, and that the chain's going to be long enough.
For drainage purposes you could (actually should) recreate the Y pipe, with a simple hole drilled in the bottom and a bit of down pipe gaffer taped in place (it won't go anywhere once the concrete around it sets).
Cheaper than and I'd guess as strong as most surface fit ground anchors.
angryjonny
PostPosted: 14:43 - 27 Jan 2016    Post subject: Reply with quote
A quick bit of Google research suggests that Almax chains are roughly 4x their gauge in width. So 19mm chain comes out at roughly 75mm across. You're going to struggle to find much choice in ground anchors that'll take the job on. Guttering may be too narrow, but DIY may be your only choice here. Reinforced concrete with something in it to make a tunnel (allowing for drainage etc).
I'd give some serious thought to just sinking the Almax in concrete with rebar crossed over the top. You can always chain another Almax to the Almax. A chain is, of course, only as strong as its weakest link.
iooi
PostPosted: 14:44 - 27 Jan 2016    Post subject: Reply with quote
How thick is that concrete base going to be?
Go with something like the above idea "jnw010 suggested", but maybe sink it in a large bucket full of concrete with it in and then have the concrete base over the top.
Although to be honest the best security should be going to be based around your door to stop easy entry. Once inside they will be out of sight and can spend time to defeat chains.
chickenstrip
PostPosted: 14:50 - 27 Jan 2016    Post subject: Reply with quote
The thickness of the concrete base is something else I wondered about. I guess I need to discuss this some more with the installers, see what they are willing/able to do.
The security on the shed itself is something else I need to think about, but it is only a wood structure so my options are limited. I can only do so much to protect the bikes.
DRZ4Hunned
PostPosted: 16:51 - 27 Jan 2016    Post subject: Reply with quote
https://www.bikechatforums.com/viewtopic.php?t=280791
DRZ400-SM
FZS600
whitedevil
PostPosted: 16:55 - 27 Jan 2016    Post subject: Reply with quote
I have an almax 19mm chain and the torc ground anchor, i got you some pics
https://i.imgur.com/lz44aP1.jpg?1
https://i.imgur.com/1ez0uKg.jpg?1
https://i.imgur.com/BhiUwAz.jpg?1
GPZ500 sold ~ CBR600FS-2 sold ~ ZX6R sold ~ Street Triple R
BTTD
PostPosted: 17:00 - 27 Jan 2016    Post subject: Reply with quote
I'd be very surprised if they go beyond 4" base + hardcore below. I wouldn't be surprised if it was less.
For a shed, I don't suppose they'll be putting in any DPM, with a timber floor above with ventilation between the concrete and the floor it won't be necessary, and it's just a shed. On the other hand a DPM sheet is what, £8?, and bringing it up to tie into the shed structure isn't that big a deal. Definitely overspec for a shed though (I always seem to go a bit over the top on simple structures).
My suggestion for the sunken anchor would need a deeper hole dug in that one spot, and if was me, taking that route, I would do that first. Dig the hole, bit of hardcore then some gravel at the bottom, then knock up a bit of form work around the top to get the levels right to where the shed base will ultimately be. Mix up in a 'barrow and create your sunken anchor.
They can do the rest of the shed base after, working to the level of the anchor.
It would probably be easier to get an above surface anchor and just create a concrete recess for it to sit in. Effectively dig the same hole as before, and make your formwork up to below the final shed base level. Then when it's gone off gaffa tape something the right thickness on top of your little block of concrete (polystyrene foam for example) and they then do the rest of the concrete base to the level of the top of your foam. Once it's all set, you pull the foam out (break it up if necessary) and voila, a recessed anchor, that you can cover over to have a flat surface if you want.
I can measure my almax and report back later in the week, but they are big feckers.
Edit: Pictures above, I won't bother measuring!
talkToTheHat
PostPosted: 17:41 - 27 Jan 2016    Post subject: Reply with quote
Go to your local metal merchant with the chain you want to use, find some thickwall box section your chain fits inside. Weld up a T or Y shape, weld some rod into the the base of the T/Y, concretre in. Estimated cost: £5 in metal from the scrap bin and a crate of your pet welder's favourite beers.
Bandit. does. everything.
chickenstrip
PostPosted: 17:51 - 27 Jan 2016    Post subject: Reply with quote
A possibility. I'll see what the people installing the base and shed say first. They said they could fit ground anchors, but we didn't discuss it in any detail. They talked about doing the base, then me deciding where the anchors would go before erecting the shed, so they must have been thinking bolt-down jobs.
I don't have much in the way of DIY skills, and am certainly no welder, so it's whatever they can do, or me after the fact, although I could possibly prepare something like jnw's suggestion. And I don't know anyone up here who does welding or owt else. Well, I just don't know anyone up here Laughing
whitedevil, cheers for the pics Thumbs Up
PostPosted: 18:04 - 27 Jan 2016    Post subject: Reply with quote
Surely you can screw bits of wood together. Smile
Dug hole, concreted in a mooring ring..assembled shed.
Could've done with help putting the roof on but manageable.
https://i104.photobucket.com/albums/m174/howlingterror_2006/DSCF0337.jpg
https://i104.photobucket.com/albums/m174/howlingterror_2006/DSCF0339.jpg
https://i104.photobucket.com/albums/m174/howlingterror_2006/DSCF0341.jpg
If it comes with felt then specify they use the thickest available or double layer it.
Even if it's pressure treated timber get some nasty nasty stuff from wickes and slap it on.
chickenstrip
PostPosted: 18:14 - 27 Jan 2016    Post subject: Reply with quote
I don't have the confidence to build a 10'x8' shed myself with a dodgy arm and shoulder. Yep, will be weatherproofing it - any suggestions as to the best stuff? It comes with a base coat, was thinking of having a mosey around B&Q for something suitable. I'll ask them about the roof felt (storm Des tore off some from the small shed that's currently in place).
PostPosted: 18:18 - 27 Jan 2016    Post subject: Reply with quote
Doh! Apologies Nick.
DRZ4Hunned
PostPosted: 19:36 - 27 Jan 2016    Post subject: Reply with quote
How much is it costing you for the shed and the base? I'm looking at getting a 16' x 10' one (roughly £1k for a decent one) and sitting it on paving slabs, but I am considering putting a concrete base down if it's not too expensive.
DRZ400-SM
FZS600
BTTD
PostPosted: 20:01 - 27 Jan 2016    Post subject: Reply with quote
Bugger, an injured arm & shoulder does limit what you can do yourself. Roof felt: I used the heaviest grade gritted roofing felt I could get (the stuff they use on flat roofs I think), usual nailing method plus lots of roofing sealant to both stick it down and seal all the overlapping edges down. That's been on 16 years and still looks good.
For the wood I used creocote mixed 1:1 with used transmission oil. The water still beads off and I did that 5 years ago. Used engine oil will do the same, I just had a load of atf that I'd changed out so used that.
Not terrifically enviro friendly, but very very effective.
chickenstrip
PostPosted: 20:37 - 27 Jan 2016    Post subject: Reply with quote
PM'd.
Pigeon
PostPosted: 21:00 - 27 Jan 2016    Post subject: Reply with quote
I really wish I'd bought a flat / flush anchor than the toe stubbing bastard that I went with Very Happy
chickenstrip
PostPosted: 21:06 - 27 Jan 2016    Post subject: Reply with quote
Laughing That's partly what I'm thinking (steel toecaps only, in the shed? Smile ). But also, with limited space, I thought it'd be easier to move the bikes and work around them.
The last post was made 10 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 145.72 Kb
