Oiling throttle cables - how and what tools?
Wonko The Sane
PostPosted: 18:16 - 15 Feb 2016    Post subject: Oiling throttle cables - how and what tools? Reply with quote
Mornin'
So, my ZZR currently has cruise control in that the throttle is fairly smooth to use but doesn't shut itself very quickly.
I'm presuming it's a case of open the throttle housing on the bars, un-clip the cables and get some oil down them giving them a little jiggle as I go to help the oil on it's way?
Any tools to make this job a bit easier / simpler?
How do you use the tool if it's not obvious?
Ta
PostPosted: 18:28 - 15 Feb 2016    Post subject: Reply with quote
https://i461.photobucket.com/albums/qq335/Rookzx/2008%20ZX-14/throttle%20cable%20clean%20and%20lube/strawinserted.jpg
Silicon spray Thumbs Up
Ariel Badger
PostPosted: 18:31 - 15 Feb 2016    Post subject: Reply with quote
I cut the corner off an envelope then snip the very corner off that so it is just big enough to get the nipple through. I then tape this over the cable like a little funnel and make sure the cable is being held verticaly and fill with oil.
Fizzer Thou
PostPosted: 20:43 - 15 Feb 2016    Post subject: Reply with quote
It may well be that it is not the cables themselves but the throttle tube on the handlebar.In the past I have found that old grease and dirt have caused the problem.
So once you have removed the cables from the throttle tube,see if it turns smoothly on the handlebar.I always clean the inside of the tube with some WD40 on a rag,doing the same to the right side of the bar.Then lubricate with GT85.
It will not hurt to do the cables at the same time Wink Thumbs Up
Always have a 'Plan B'
mudcow007
PostPosted: 23:41 - 15 Feb 2016    Post subject: Reply with quote
i had an issue with bar end weights causing drag on my throttle. basically the weight was rubbing on the tube no allowing it to spring back
talkToTheHat
PostPosted: 05:04 - 16 Feb 2016    Post subject: Reply with quote
Make blu-tack / plasticene funnel around top of cable and pour in lube of choice. I use wd40 to flush out crud and then usually some engine oil, although i took to filling a very corrosion prone cable with acf50. The cables should have a nylon liner so mostly you just need to use a light oil to clush out any crud buildup.
Grip rubber used to bind against the control body on one of my bikes. I got given a large washer made of shiny smooth plastic to sort that out, along with a very long lecture on mounting my grip rubbers. Worked well, fitting grip rubbers was even harder to get wrong.
Bandit. does. everything.
PostPosted: 13:20 - 16 Feb 2016    Post subject: Reply with quote
Could also be a broken "close" branch of the throttle cable?
Wonko The Sane
PostPosted: 21:57 - 24 Feb 2016    Post subject: Reply with quote
Throttle opens and closes normally, just not under it's own steam.
I'm presuming the close cable not being connected / snapped would cause a delay in throttle shutting?
Wonko The Sane
PostPosted: 13:44 - 25 Feb 2016    Post subject: Reply with quote
So, clutch cable done,
it sprayed out again from the other end of the metal noodle so looks like there's a split which isn't great
going to keep an eye on it and think about ordering a replacement cable but will probably just gaffa tape it to stop muck / water getting in
Throttle cables will be done on the weekend.
FlightRisk
PostPosted: 20:05 - 25 Feb 2016    Post subject: Reply with quote
No, springs in the carbs will snap them shut even without the 'close' cable.
Honda CB500S
davebike
PostPosted: 08:43 - 26 Feb 2016    Post subject: Reply with quote
Pro tip
Almost all jap throttles have a drain hole in the bottom get a can with a "straw" like WD40 and spray up the whole while working the throttle (engine off) works 9 out of 10 times takes seconds
Dave
NC750Xdct + others at work !
[email protected]
The last post was made 10 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.31 - MySQL Queries: 13 - Page Size: 70.51 Kb
