| Wonko The Sane |
 Wonko The Sane World Chat Champion
 Posted: 18:16 - 15 Feb 2016 Post subject: Oiling throttle cables - how and what tools? |
Mornin'
So, my ZZR currently has cruise control in that the throttle is fairly smooth to use but doesn't shut itself very quickly.
I'm presuming it's a case of open the throttle housing on the bars, un-clip the cables and get some oil down them giving them a little jiggle as I go to help the oil on it's way?
Any tools to make this job a bit easier / simpler?
How do you use the tool if it's not obvious?
Ta ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
| Polarbear |
 Polarbear Super Spammer
 Posted: 18:28 - 15 Feb 2016 Post subject: |
| Ariel Badger |
 Ariel Badger Super Spammer
| Fizzer Thou |
 Posted: 20:43 - 15 Feb 2016 Post subject: |
It may well be that it is not the cables themselves but the throttle tube on the handlebar.In the past I have found that old grease and dirt have caused the problem.
So once you have removed the cables from the throttle tube,see if it turns smoothly on the handlebar.I always clean the inside of the tube with some WD40 on a rag,doing the same to the right side of the bar.Then lubricate with GT85.
It will not hurt to do the cables at the same time  ____________________ Just talk bikes.What else is there?
Always have a 'Plan B' |
| mudcow007 |
 mudcow007 World Chat Champion
| talkToTheHat |
| Wonko The Sane |
| Wonko The Sane |
 Posted: 13:44 - 25 Feb 2016 Post subject: |
So, clutch cable done,
it sprayed out again from the other end of the metal noodle so looks like there's a split which isn't great
going to keep an eye on it and think about ordering a replacement cable but will probably just gaffa tape it to stop muck / water getting in
Throttle cables will be done on the weekend. ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
| FlightRisk |
 FlightRisk Spanner Monkey
| davebike |
 davebike World Chat Champion
 Posted: 08:43 - 26 Feb 2016 Post subject: |
Pro tip
Almost all jap throttles have a drain hole in the bottom get a can with a "straw" like WD40 and spray up the whole while working the throttle (engine off) works 9 out of 10 times takes seconds ____________________ Dave
NC750Xdct + others at work !
[email protected] |
The last post was made 10 years, 223 days ago. Instead of replying here, would creating a new thread be more useful? |
