BRAND NEW BIKE SEIZED :(
quadman230
PostPosted: 14:07 - 16 Feb 2016    Post subject: BRAND NEW BIKE SEIZED :( Reply with quote
https://youtu.be/f9QZ6Zn2_qQ
Crying or Very sad Has anyone got any idea as to what has happened here? The bike had fresh oil put in it when it arrived, it was left idling on my drive for 20 minutes then put away. I got it out the next day to go for a ride and then this happened. I cant move the kickstart (even if I pull the clutch in) and the bike is stuck in 3rd gear. The back wheel is locked up as well.
PostPosted: 14:22 - 16 Feb 2016    Post subject: Reply with quote
I can't hear the video as working but 4 stroke or 2?
Brand new? If so, dealer phone call yo.
Why idle for 20 minutes.... also, is there still oil in it.
quadman230
PostPosted: 14:26 - 16 Feb 2016    Post subject: Reply with quote
4 stroke, The engine is being collected by the company today. I was following a video online about running in new pitbikes and it said to idle it for 20 mins then give a few revs to set everything in place.
PostPosted: 14:28 - 16 Feb 2016    Post subject: Re: BRAND NEW BIKE SEIZED :( Reply with quote
Just out for a quick ride (with a satnav?) around a residential estate on your non road legal, uninsured bike, were we?
Karma
Start stripping it down and find out what's seized. I don't know what else you expect to be told. It might (but probably won't) help if you tell us what bike it is, including a model number, and any codes on the engine.
Oh, I've just seen what you did. The idea is to let it idle to warm up, then immediately run it in. Not let it get stone cold again.
Not that you were spanking it, mind, I can't see anything that you did wrong (apart from the Tut Tut legalities).
PostPosted: 14:28 - 16 Feb 2016    Post subject: Reply with quote
Well I definitely wouldn't.
I'd start it and ride gently for ~5 minutes to get everything moving covered in oil, engine a bit loose then give it some beans but not for massive prolonged periods, simply on the power, roll off. Change oil in 50 miles, repeat until 150 miles then ride as is. Thumbs Up
Other people may vary, but this is the method I'd always use.
quadman230
PostPosted: 14:32 - 16 Feb 2016    Post subject: Reply with quote
Very bad of me I know, was just taking it for a quick whizz round the block and then waiting to be collected to go to my local MX track. I only had the bike for about 16 hours previous to it blowing up so was very eager to ride it. I've attached a link to the page where I bought the bike.
Oh and the sat nav looking device is my phone in a case, wanted to test a new speedo app and holder I got for my pushbike.
https://www.funbikes.co.uk/M2R_Racing_KM125MX_125cc_Petrol_1714_86cm_Yellow_Dirt_Bike(4698).aspx
Copycat73
PostPosted: 15:19 - 16 Feb 2016    Post subject: Reply with quote
... i`m not convinced that there is just one issue here ...
there is 2 thing i i would try
1.rock the bike back wards ... its still in gear 3rd yes ? ...
against the gear box and dont touch the clutch ...
i have a suspicion that all the slack in the gear box has been "wound to one end" when the bike cut out ...
2. and i would be checkin for electrical problems ie. fuses loose wires shorts etc.
good luck anyway Thumbs Up
caveat emptor
iooi
PostPosted: 15:25 - 16 Feb 2016    Post subject: Re: BRAND NEW BIKE SEIZED :( Reply with quote
Also given anyone inclined the location of a easy steal Embarassed
quadman230
PostPosted: 15:47 - 16 Feb 2016    Post subject: Reply with quote
The back wheel locked up as soon as the bike cut out and i had to push the bike home with it locked up, tried pulling the bike backwards as well and the front end just comes upm co chance of moving it. The engine has just been picked up to be replaced I just wondering if anyone knew what had happened? Got a feeling that the compnay is going to say it was my fault and try and charge me for a new engine.
Copycat73
PostPosted: 15:53 - 16 Feb 2016    Post subject: Reply with quote
not sure .. was just a stab in the dark really ... if its away now only time will tell. Thinking
caveat emptor
PostPosted: 17:15 - 16 Feb 2016    Post subject: Reply with quote
The oil that comes in those Chinese bikes is basically chip fat. I'd not run it for longer than 20 mins on it before changing it. Ideally sooner.
Copycat73
PostPosted: 17:17 - 16 Feb 2016    Post subject: Reply with quote
but it would appear to have fried the engine ... Sick
caveat emptor
weasley
PostPosted: 17:39 - 16 Feb 2016    Post subject: Reply with quote
The lock-up appeared to happen as you changed gear. The fact that the whole drive-line is locked up suggests the issue is on the transmission side rather than the engine - my thinking is that even if the engine was a steaming pile of molten metal, you should still be able to pull the clutch, get it in neutral and move the bike.
I suspect either the flywheel/clutch have seriously let go, or you have two gears engaged at the same time, with the resulting lock-up buggering the clutch/flywheel.
Ariel Badger
PostPosted: 00:15 - 17 Feb 2016    Post subject: Reply with quote
That was a gearbox going potato not the engine.
nightshaddow
PostPosted: 01:08 - 17 Feb 2016    Post subject: Reply with quote
i would say bang on
that was exactly what happened to my cagiva w8 16 years ago except i was traveling at a higher speed in a higher gear, in my case the input shaft had sheared and locked all the dogs in place,
quadman230
PostPosted: 10:54 - 17 Feb 2016    Post subject: Reply with quote
Do you think the company will replace the engine and send me out a new one or repair this engine? Hoping to get a new one.
PostPosted: 11:53 - 17 Feb 2016    Post subject: Reply with quote
I think they'll say "Owner abuse" and invite you to prove otherwise while they have both your bike/engine and your money.
I'd hope to be pleasantly surprised.
From where did you get it?
Fidge This post is not being displayed because the poster is banned. Unhide this post / all posts.
Evil Hans
PostPosted: 14:59 - 17 Feb 2016    Post subject: Reply with quote
FunBikes wrote:
** This product requires assembly of Handlebars, Front wheel, Front mud guard, and rear suspension attaching before use. Please also give the bike a full inspection, change oil and check chain tension.
Did you change the oil? Did you check that you had oil pressure?
skatefreak
PostPosted: 16:13 - 17 Feb 2016    Post subject: Reply with quote
I'monn'a go with Full potato gearbox.
If it were just an engine seize then the wheel would stop, transmission would stop and not go Grzrrrrwhirrrrrrr like gears slipping on each other locking everything clutch or no clutch.
Cheap tat, hope they don't blame you however that video does prove the tranny shat itself whilst not being abused so you defiantly have that in your favor!
PostPosted: 17:24 - 17 Feb 2016    Post subject: Reply with quote
But chinese bikes are so good now, someone said on here so it must be true Wink Laughing
£600 new in UK. I presume that means it's cheaper than a bowl of noodles in China. Good luck with getting any recompense on that.
ADSrox0r
PostPosted: 17:48 - 17 Feb 2016    Post subject: Reply with quote
https://i.imgur.com/2YQfd37.jpg
Ribenapigeon
PostPosted: 18:29 - 17 Feb 2016    Post subject: Reply with quote
Surely a good hard thump to the engine with a mallet would fix it.
quadman230
PostPosted: 19:18 - 17 Feb 2016    Post subject: Reply with quote
Yes I gave it a full oil change when it arrived, I know it may be Chinese shite and only £600 but I'm only 16 so it's really all I could afford. When I can I'll update but this is (was) my first bike 😬
PostPosted: 19:56 - 17 Feb 2016    Post subject: Reply with quote
I wasn't trying to belittle your purchase, it was a petty dig at someone who comes on here saying that Chinese quality is getting better and proceeds to spout how brilliant his Chinese bikes are. Wink
Hopefully they will repair it for you. Thumbs Up
The last post was made 10 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 128.6 Kb
