| Wonko The Sane |
 Wonko The Sane World Chat Champion
 Posted: 22:19 - 30 Mar 2016 Post subject: Why hasn't my window fallen out yet? - house renovation stuf |
Got an internal window that's in a wooden frame with window putty which I've removed,
I've also cut off the nails holding the glass in place other than the ones at the bottom that I've cut short due to not being able to get the dremel in
The window is showing no signs of budging, it can't just be the stumps of these two nails at the bottom holding it, surely?
The window frame does have a lot of gloss paint on it
I've tried giving the window a bit of a tap from the other side, but I don't want to break it due to a 2 year old running around the place
Any ideas why it's not shifting? ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
They're also on Facebook https://www.facebook.com/pages/Focus-Rider-Training/196832923734251 |
| doggone |
 doggone World Chat Champion
| Wonko The Sane |
| Beehive Bedlam |
 Beehive Bedlam World Chat Champion
| Wonko The Sane |
| Beehive Bedlam |
This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
| Wonko The Sane |
| Beehive Bedlam |
| lihp |
 lihp World Chat Champion
| Wonko The Sane |
| Howling TerrorOutOfOffice |
 Posted: 23:36 - 30 Mar 2016 Post subject: |
Possibly the stumps of the pins. They're tapped in at an angle and a pair of needle nose pliers get them out with a bit of twisting.
Also worth using an old stanley knife blade to break the paint. ____________________ Diabolical homemade music Bandcamp and Soundcloud
The Harry Turner Project |
| Beehive Bedlam |
| andym |
 andym World Chat Champion
 Posted: 02:10 - 31 Mar 2016 Post subject: |
Depending on when they were fitted, (we had a lot of broken windows when I was younger), they used to put putty round the frame before putting the glass in, cut the pane to size push it in to place then put a few pins in to secure it, then put the putty over the pins to make it look neater (I guess).
Depending on how long the glass has been in place, it might just need some gentle persuasion (a bit of force in 1 corner moving along the top with your fingertips to the other corner and round the edge of the glass), failing that, and still believing it's possibly ancient putty that has done its job for many years, get a thin sharp blade and run it round between the glass and window frame.  |
 Posted: 06:14 - 31 Mar 2016 Post subject: |
Buy a 2" wide roll of sellotape. Tape the window both sides and bosh it through. ____________________ a.k.a 'Geri'
| bugeye_bob |
| BTTD |
 BTTD World Chat Champion
 Posted: 10:20 - 31 Mar 2016 Post subject: |
Is it a double glazed unit? Could be hung-up on something between the two panes. You'd normally want to lift it slightly with a plastic wedge between the bottom of the pane and the frame then slide it out bottom first over the top of the wedge.
Buy a suction cup too. They are super cheap. Sold as "dent pullers". If nothng else, it makes handling and fitting the new pane much easier. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Pjay |
 Pjay World Chat Champion
| bugeye_bob |
| Kris |
 Kris World Chat Champion
 Posted: 12:00 - 31 Mar 2016 Post subject: |
Another vote for tape-it and smash-it.
 ____________________ NSR125RR - ZXR750H1 - ZX9R E1 - GSF600S - GSF600SK3 - VFR400-NC30 - SV1000N - ST1100-R - CBR900RR-R - GSF1200SK5 - GSF600SK1 - VFR1200FA - GSXR1000K2 - ZZR1400 D8F
www.prisonplanet.com |
| mentalboy |
 mentalboy World Chat Champion
| Islander |
 Islander World Chat Champion
| MCN |
 MCN Super Spammer
| c_dug |
 c_dug Super Spammer
| Wonko The Sane |
 Posted: 12:47 - 01 Apr 2016 Post subject: |
Sorry for lack of update, didn't get home until 11 last night and the toilet broke this morning so will probably be fixing that tonight.
I can get to both sides of the window as it's above a doorway between dining room and conservetory - it's always been an internal window as far as I can tell.
As far as I can see the window has been placed into position (it's frosted so not sure if a plunger / gripper will help) nails put in and then putty, no bed of putty first
It's possible the lower two nails are still holding with help from the paint on the back.
My next plan of action is to use a cold chissel as a drift to hammer the nails in, I'll then put some plywood over the side that faces into the dining room and try to scrape the paint from between glass and frame and push out.
If it breaks then the plywood should stop any shards going into the dining room ____________________ Looking to pass your CBT / Bike tests in Bury Lancashire? try www.focusridertraining.co.uk Would recommend.
The last post was made 10 years, 181 days ago. Instead of replying here, would creating a new thread be more useful? |
