Why hasn't my window fallen out yet? - house renovation stuf
Wonko The Sane
PostPosted: 22:19 - 30 Mar 2016    Post subject: Why hasn't my window fallen out yet? - house renovation stuf Reply with quote
Got an internal window that's in a wooden frame with window putty which I've removed,
I've also cut off the nails holding the glass in place other than the ones at the bottom that I've cut short due to not being able to get the dremel in
The window is showing no signs of budging, it can't just be the stumps of these two nails at the bottom holding it, surely?
The window frame does have a lot of gloss paint on it
I've tried giving the window a bit of a tap from the other side, but I don't want to break it due to a 2 year old running around the place
Any ideas why it's not shifting?
doggone
PostPosted: 22:28 - 30 Mar 2016    Post subject: Reply with quote
Could be in a groove on three or all sides.
Can you tap the surround apart at all?
There may be no easy way other than tape over it both sides and break it out.
Wonko The Sane
PostPosted: 22:33 - 30 Mar 2016    Post subject: Reply with quote
I've got round the top and the sides having scraped most of the putty out, it appears to be a loose fit in the frame held by the pins - except all but the bottom two pins are gone
Wonko The Sane
PostPosted: 22:49 - 30 Mar 2016    Post subject: Reply with quote
God.i wrote:
Remove the bead.
what bead?
There is a bead on the reverse but putty is used on the other side instead, I've removed this.
Beehive Bedlam This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
Wonko The Sane
PostPosted: 23:06 - 30 Mar 2016    Post subject: Reply with quote
God.i wrote:
Remove the beading on both sides and the glass should come out in one piece. Failing that lock the brat up and smash it.
Firstly, don't refer to my daughter as a brat.
secondly, while it is a bead on the back, the bead has been created by making the frame from L sections of wood and so it is also the carcass of the frame itself, it can't be removed without simply dismantling the whole window frame which is something I can't do with the glass in place.
The glass should come out after removing the putty, it isn't doing, simple
lihp
PostPosted: 23:19 - 30 Mar 2016    Post subject: Reply with quote
If they're under 21. They're a brat.
Wonko The Sane
PostPosted: 23:23 - 30 Mar 2016    Post subject: Reply with quote
God.i wrote:
The 'L sections' are probably points which can be removed with a flat head screwdriver.
They're 4 inch square and go into the wooden window surround, it'd be a days work to remove the window, they are the structure of the window
We're getting off track
PostPosted: 23:36 - 30 Mar 2016    Post subject: Reply with quote
Possibly the stumps of the pins. They're tapped in at an angle and a pair of needle nose pliers get them out with a bit of twisting.
Also worth using an old stanley knife blade to break the paint.
andym
PostPosted: 02:10 - 31 Mar 2016    Post subject: Reply with quote
Depending on when they were fitted, (we had a lot of broken windows when I was younger), they used to put putty round the frame before putting the glass in, cut the pane to size push it in to place then put a few pins in to secure it, then put the putty over the pins to make it look neater (I guess).
Depending on how long the glass has been in place, it might just need some gentle persuasion (a bit of force in 1 corner moving along the top with your fingertips to the other corner and round the edge of the glass), failing that, and still believing it's possibly ancient putty that has done its job for many years, get a thin sharp blade and run it round between the glass and window frame. Thumbs Up
PostPosted: 06:14 - 31 Mar 2016    Post subject: Reply with quote
Buy a 2" wide roll of sellotape. Tape the window both sides and bosh it through.
bugeye_bob
PostPosted: 08:10 - 31 Mar 2016    Post subject: Reply with quote
Cover glass on both sides with cling film and then break, less bits to clean up. .
BTTD
PostPosted: 09:36 - 31 Mar 2016    Post subject: Reply with quote
Gloss paint can have a surprising amount of grab. On external window frames it's the gloss that weather seals the panes in place.
If you're not striping the paint, then "tape & break" is probably the most efficient solution.
PostPosted: 10:20 - 31 Mar 2016    Post subject: Reply with quote
Is it a double glazed unit? Could be hung-up on something between the two panes. You'd normally want to lift it slightly with a plastic wedge between the bottom of the pane and the frame then slide it out bottom first over the top of the wedge.
Buy a suction cup too. They are super cheap. Sold as "dent pullers". If nothng else, it makes handling and fitting the new pane much easier.
Pjay
PostPosted: 10:23 - 31 Mar 2016    Post subject: Reply with quote
Sounds like the wooden frame has swollen over the years and grabbed hold of it.
Smash it.
bugeye_bob
PostPosted: 11:36 - 31 Mar 2016    Post subject: Reply with quote
Hairspray and any paper/plastic bag if you`re desperate.
Kris
PostPosted: 12:00 - 31 Mar 2016    Post subject: Reply with quote
Another vote for tape-it and smash-it.
www.prisonplanet.com
mentalboy
PostPosted: 12:50 - 31 Mar 2016    Post subject: Reply with quote
This thread is useless without pictures...
Islander
PostPosted: 17:21 - 31 Mar 2016    Post subject: Reply with quote
It'll have a bead of putty behind it - that's most likely to be holding it but do remove any remnants of nails as well.
MCN
PostPosted: 01:04 - 01 Apr 2016    Post subject: Reply with quote
Be careful you don't smash the feckin glass when you hammer the little nails in. Wink
c_dug
PostPosted: 06:26 - 01 Apr 2016    Post subject: Reply with quote
If you're based near London I have some very decent glass suckers I can lend for a weekend.
If I was in a stick and needed it out quick I'd probably try a toilet plunger just to give a little pull (I'm in a flat so a push from outside isn't an option for me) before I resorted to breaking the glass. Even with it taped you'll have the odd chip here and there from the outter edges of the pane, I can see why you'd want to avoid it with the toddler.
Wonko The Sane
PostPosted: 12:47 - 01 Apr 2016    Post subject: Reply with quote
Sorry for lack of update, didn't get home until 11 last night and the toilet broke this morning so will probably be fixing that tonight.
I can get to both sides of the window as it's above a doorway between dining room and conservetory - it's always been an internal window as far as I can tell.
As far as I can see the window has been placed into position (it's frosted so not sure if a plunger / gripper will help) nails put in and then putty, no bed of putty first
It's possible the lower two nails are still holding with help from the paint on the back.
My next plan of action is to use a cold chissel as a drift to hammer the nails in, I'll then put some plywood over the side that faces into the dining room and try to scrape the paint from between glass and frame and push out.
If it breaks then the plywood should stop any shards going into the dining room
The last post was made 10 years, 180 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 129.96 Kb
