Help with keeping an NSR running smoothly...
verbalremedy
PostPosted: 19:21 - 18 Feb 2005    Post subject: Help with keeping an NSR running smoothly... Reply with quote
2 stroke so I've heard they need a lot of love and attention anyone gimme some pointers..?
Please note I know jack about bikes.
Thanks
fuzz
PostPosted: 20:29 - 18 Feb 2005    Post subject: Reply with quote
Use decent 2-stroke oil. I'm using GTS at the moment, but you can use good semi-synthetic also.
Warm up for a good 3-5 miles before going past about 5000 revs.
When starting from cold, put the choke on full, and wait until the revs drop to normal idle speed, about 1.5-2k, then choke fully in. You might need a little blip of the throttle when you come off the choke to keep it running (if it's very cold).
All other maintenance is general, so I think that's it for 2-strokes.
HTH.
simon1221
PostPosted: 20:01 - 19 Feb 2005    Post subject: Reply with quote
And even then dont go straight up to the redline, keep it low and biuld it up then play Twisted Evil . But dont rev it all the time, just occasionally.
Barker-CBR 600
PostPosted: 11:28 - 20 Feb 2005    Post subject: Reply with quote
Lubricate your chain - I do this at least once a week, what you use it up to you they range from Enduro lubricant to Sportsbike Chain wax. One tip is to do this AFTER you come back from a ride since the chain is warmer and the lubricant can work its way into the links.
Check your oil levels - Fully synthetic/Half synthetic 2 stroke oil, shouldnt need filling up too often but keep an eye out for it.
Check Your coolant (if it has a resevoir) - especially if the engine temperature is constantly higher than normal.
Brake fluid levels - so you can stop before you hit that tree. Although this probably wont be a problem but its a 2 second check. Make sure bike is upright (might need a mate to hold it since might have no centre stand).
Tyre Pressures - Especially when in cold weather where they heat up and cool down again each time you ride it.
Other than that.
Warm the engine for 1-2 minutes before moving off, or more if its peticularly cold or if its convienient.
(I open garage get bike out and leave it to warm up while i get helmet, gloves, balaclava on... and close up the garage etc. Warms up for a good 5 mins without me having to sit around)
Previous - Gilera DNA50 / XVS125 Dragstar/Honda CBR 600F/GSF 650 Bandit
Current - 2013 Suzuki VZ800 Intruder
'Is this a rhetorical question?'
The last post was made 21 years, 181 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 40.66 Kb
