Royal Enfield AVL drive nut removal
PostPosted: 13:36 - 30 May 2016    Post subject: Royal Enfield AVL drive nut removal Reply with quote
https://i.imgur.com/EpdMn0N.jpg
Wedgey not worky. Sad
Leaving it in gear with the rear brake locked on, the chains are bowstring-taut and it's not for budging.
Time to buy an impact gun?
Meatybeaty
PostPosted: 13:44 - 30 May 2016    Post subject: Reply with quote
Hi Roger, bought myself a 4ft breaker bar, was the only thing I could shift the rear wheel nut and front sprocket on a vfr750, Thumbs Up
PostPosted: 13:46 - 30 May 2016    Post subject: Reply with quote
I don't think I can put enough torque on it to budge it without snapping or damaging the drive chains though. I'm just prevaricating about the bush a bit, I'm pretty sure I'll need to impact gun it.
On that, can anyone recommend an electric gun, or am I better off just biting the bullet (har har) and getting a compressor?
Meatybeaty
PostPosted: 13:49 - 30 May 2016    Post subject: Reply with quote
looks like a brass nut that jobbie , how about a bit of heat should warm up faster than the surrounding steel Thumbs Up
PostPosted: 13:55 - 30 May 2016    Post subject: Reply with quote
Not looks plated, not brass. Might be threadlocked though so getting it hot might help a whole bunch.
PostPosted: 13:59 - 30 May 2016    Post subject: Reply with quote
OK, I'll go and get some cannisters for my torch. Please continue the discussion in the best BCF traditions.
DRZ4Hunned
PostPosted: 14:03 - 30 May 2016    Post subject: Reply with quote
If it's anything like the front sprocket on my DRZ a 4' breaker bar won't work, I then bought an impact gun for £30 and it came off with two short blasts.
DRZ400-SM
FZS600
PostPosted: 14:14 - 30 May 2016    Post subject: Reply with quote
Out of interest, why do you want it off? Wotcha doin?
PostPosted: 14:22 - 30 May 2016    Post subject: Reply with quote
Roger, I have one of these
https://www.tool-net.co.uk/p-363436/clarke-cir13c.html?gclid=CjwKEAjwya-6BRDR3p6FuY2-u3MSJAD1paxTFl1XNDRuueHLf2XRXFZEROEqfTcLQjxsAXRFbJ8YwxoCZszw_wcB
Cheap as chips and got me out of a hole a few times BUT whether it's up to something you can't move with a breaker bar?
WD Forte
PostPosted: 15:06 - 30 May 2016    Post subject: Reply with quote
I'd be a bit leery of using heat on anything in situ on an engine
and try an impact gun/ breaker bar/ flogging spanner etc first
bikers smell of wee
PostPosted: 15:41 - 30 May 2016    Post subject: Reply with quote
OK, heat did nothing except produce clouds of ATF smoke, and Pete was right (you'll be astonished), it's not a brass nut, it's just plated. Or was until I burned it off.
I don't want to snap my drive chain(s) by using a breaker bar, so I'll be impact wrench time. In my head this is more likely to rattle the nut free than to snap the chain, right? Thinking
I reckon I'll go with this un as claims up to 450Nm and I prefer mains, unless anyone can suggest something more suitable. 32mm deep impact socket is already ordered.
Getting access to the one loose screw on the bottom of the electric start housing that's slowly but persistently allowing a fluid leak. It's just on the borderline of moppable-uppable but it's been bothering me for a while so I ordered up the four (!) specialist removal tools for the various drive bits and got stuck in, then got stuck.
It'll all have to come off eventually for a front sprocket change, or if the sprag spacks itself, so this is an "investment" I keep telling myself.
Robby
Dirty Old Man
PostPosted: 16:10 - 30 May 2016    Post subject: Reply with quote
The drive chain can handle the thuds of an enfield engine, many times a minute, for many years. I doubt you'll snap it with a breaker bar.
Alternatively, use a chain strap (like an oil filter removal tool) or make one with some chain and some manner of bar. Your current method is putting more pressure than I would like on the engine casing.
An impact gun might not get it off. My compressor driven one gets annoying spinny things off usually - like lower cambelt pulleys on cars - but if it's really tight then I need to find a way of locking it and using the big breaker bar.
MCN
PostPosted: 16:13 - 30 May 2016    Post subject: Reply with quote
Have you spoken to Draganfly? There's a couple of dudes there who know a thing or two about Beezers.
Also the Beezer clubs/forums are a bit more specialised than some of the spazed out buffoons on here. 😀
The impact gun will still stress the chain whether you like it or not. 😀
It may be more efficacious/safer to undo the primary chain and lock the teeth directly.
Then get your bar on it.
If you exhausted your efforts with 1/2"drive then may I suggest Bills Tool Store and pick up a 3/4" bar and socket. Even a 3/4" drive ratchet will do it. Then you will have a 3/4" drive ratchet to impress the chicks with.😎
Islander
PostPosted: 16:18 - 30 May 2016    Post subject: Reply with quote
An impact gun is a good thing to have and should remove that without damaging the primary chain. They're also good for removing gorilla tightened wheel nuts and the like. Thumbs Up
PostPosted: 16:29 - 30 May 2016    Post subject: Reply with quote
41.3 Nm, or in scientific terms, 3 bags of sugar (less a cupful) hanging from the end of a 1.5 metre bar.
I can hear creaking from the locked up rear end even without using a breaker bar, so I've gone ahead and ordered an electric impact gun. I'll maybe see about getting the primary chain off as well and wedging the teeth directly.
Meatybeaty
PostPosted: 17:10 - 30 May 2016    Post subject: Reply with quote
Hi Roger, I think definately with the chain tensioner out of the way and the chain off , would give you more room to wedge the two drives and not have to worry about breaking/stretching the chain Thumbs Up
mysterious_rider
PostPosted: 17:12 - 30 May 2016    Post subject: Reply with quote
If you are near brighton rogerborg you can borrow my snapon battery one.
#helping fellow enfield owners Laughing
KAWASAKIIIII
mysterious_rider
PostPosted: 17:13 - 30 May 2016    Post subject: Reply with quote
KAWASAKIIIII
Oldie
PostPosted: 17:38 - 30 May 2016    Post subject: Reply with quote
Interested to hear how you get on as I really should get one myself. The one you linked to has good reviews on Amazon and seems a good price.
Commuter_Tim
PostPosted: 17:56 - 30 May 2016    Post subject: Reply with quote
Bit late to the party but have you considered the manual style Hammer Impact Wrench? Thinking
I don't find them so friendly to the nut itself, but you already napalmed your current one and this way you have direct control over the impact/torque applied.
Almost every nut and bolt on my shitty bike was seized so I've gotten plenty of practice.
I ride a Bandit 600... badly.
sickpup
Old Timer
PostPosted: 18:30 - 30 May 2016    Post subject: Reply with quote
Got myself one of those a few weeks back. It's big and heavy so I hope you have strong arms and not limp wrists because if you don't it will hurt.
PostPosted: 18:32 - 30 May 2016    Post subject: Reply with quote
How powerful are they mate?
PostPosted: 18:41 - 30 May 2016    Post subject: Reply with quote
I wedge a folded piece of nylon webbing strap between the sprocket and primary chain to remove the engine sprocket on my bullet. This locks it up solid.
EDIT: There's another way of locking up a sprocket if you can get the chain off one end that's used for removing fixed gear bicycle cogs (which land up EPIC tight). So if you were struggling and can manage to wiggle the chain off the clutch basket then remove it, this ought to work (and at that point, you can use any scabby bit of chain that fits on the sprocket).
Never tried it, it's a thing I've been carrying in my head for if other techniques fail.
https://3.bp.blogspot.com/-TD459KAQxSM/TlgMByp9X8I/AAAAAAAAC1s/4NRn5Xu95mw/s1600/Rota+Fix+Tire+Whip+to+tighten+cog+on+fixed+gear+bike.JPG
sickpup
Old Timer
PostPosted: 18:42 - 30 May 2016    Post subject: Reply with quote
Not used in anger yet but 1000w motor and 450nm of torque compared to the standard 1/2 windy gun that has about 230nm of torque.
Its also about 50% bigger than a standard Windy gun.
You want to borrow and test?
Triton Thrasher
PostPosted: 18:49 - 30 May 2016    Post subject: Reply with quote
I've never heard of anyone breaking a drive chain with a bar on the nut.
Bet nobody else has either.
Rrrrrrrrrrrrrrrrrr
The last post was made 10 years, 129 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.54 - MySQL Queries: 13 - Page Size: 130.46 Kb
