| Rogerborg |
 Rogerborg nimbA
 Posted: 13:36 - 30 May 2016 Post subject: Royal Enfield AVL drive nut removal |
https://i.imgur.com/EpdMn0N.jpg
Wedgey not worky.
Leaving it in gear with the rear brake locked on, the chains are bowstring-taut and it's not for budging.
Time to buy an impact gun? ____________________ Biking is 1/20th as dangerous as horse riding.
| Meatybeaty |
 Meatybeaty World Chat Champion
 Posted: 13:44 - 30 May 2016 Post subject: |
Hi Roger, bought myself a 4ft breaker bar, was the only thing I could shift the rear wheel nut and front sprocket on a vfr750,  |
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:46 - 30 May 2016 Post subject: |
I don't think I can put enough torque on it to budge it without snapping or damaging the drive chains though. I'm just prevaricating about the bush a bit, I'm pretty sure I'll need to impact gun it.
On that, can anyone recommend an electric gun, or am I better off just biting the bullet (har har) and getting a compressor? ____________________ Biking is 1/20th as dangerous as horse riding.
| Meatybeaty |
 Posted: 13:49 - 30 May 2016 Post subject: |
looks like a brass nut that jobbie , how about a bit of heat should warm up faster than the surrounding steel  |
| Pete. |
 Pete. Super Spammer
 Posted: 13:55 - 30 May 2016 Post subject: |
Not looks plated, not brass. Might be threadlocked though so getting it hot might help a whole bunch. ____________________ a.k.a 'Geri'
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:59 - 30 May 2016 Post subject: |
OK, I'll go and get some cannisters for my torch. Please continue the discussion in the best BCF traditions. ____________________ Biking is 1/20th as dangerous as horse riding.
| DRZ4Hunned |
 DRZ4Hunned World Chat Champion
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 14:14 - 30 May 2016 Post subject: |
Out of interest, why do you want it off? Wotcha doin? ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| Polarbear |
 Polarbear Super Spammer
| WD Forte |
 WD Forte World Chat Champion
| Rogerborg |
 Rogerborg nimbA
 Posted: 15:41 - 30 May 2016 Post subject: |
OK, heat did nothing except produce clouds of ATF smoke, and Pete was right (you'll be astonished), it's not a brass nut, it's just plated. Or was until I burned it off.
I don't want to snap my drive chain(s) by using a breaker bar, so I'll be impact wrench time. In my head this is more likely to rattle the nut free than to snap the chain, right?
I reckon I'll go with this un as claims up to 450Nm and I prefer mains, unless anyone can suggest something more suitable. 32mm deep impact socket is already ordered.
| The Shaggy D.A. wrote: | Out of interest, why do you want it off? Wotcha doin? |
Getting access to the one loose screw on the bottom of the electric start housing that's slowly but persistently allowing a fluid leak. It's just on the borderline of moppable-uppable but it's been bothering me for a while so I ordered up the four (!) specialist removal tools for the various drive bits and got stuck in, then got stuck.
It'll all have to come off eventually for a front sprocket change, or if the sprag spacks itself, so this is an "investment" I keep telling myself. ____________________ Biking is 1/20th as dangerous as horse riding.
| Robby |
 Robby Dirty Old Man
| MCN |
 MCN Super Spammer
| Islander |
 Islander World Chat Champion
 Posted: 16:18 - 30 May 2016 Post subject: |
An impact gun is a good thing to have and should remove that without damaging the primary chain. They're also good for removing gorilla tightened wheel nuts and the like.  |
| Rogerborg |
 Rogerborg nimbA
 Posted: 16:29 - 30 May 2016 Post subject: |
| Robby wrote: | The drive chain can handle the thuds of an enfield engine, many times a minute, for many years. |
41.3 Nm, or in scientific terms, 3 bags of sugar (less a cupful) hanging from the end of a 1.5 metre bar.
I can hear creaking from the locked up rear end even without using a breaker bar, so I've gone ahead and ordered an electric impact gun. I'll maybe see about getting the primary chain off as well and wedging the teeth directly. ____________________ Biking is 1/20th as dangerous as horse riding.
| Meatybeaty |
 Posted: 17:10 - 30 May 2016 Post subject: |
Hi Roger, I think definately with the chain tensioner out of the way and the chain off , would give you more room to wedge the two drives and not have to worry about breaking/stretching the chain  |
| mysterious_rider |
 mysterious_rider World Chat Champion
 Posted: 17:12 - 30 May 2016 Post subject: |
If you are near brighton rogerborg you can borrow my snapon battery one.
#helping fellow enfield owners  ____________________ KAWASAKIIIII |
| mysterious_rider |
 Posted: 17:13 - 30 May 2016 Post subject: |
| Oldie |
 Oldie Brolly Dolly
| Commuter_Tim |
 Commuter_Tim World Chat Champion
 Posted: 17:56 - 30 May 2016 Post subject: |
Bit late to the party but have you considered the manual style Hammer Impact Wrench?
I don't find them so friendly to the nut itself, but you already napalmed your current one and this way you have direct control over the impact/torque applied.
Almost every nut and bolt on my shitty bike was seized so I've gotten plenty of practice. ____________________ The above post is most likely nonsensical.
I ride a Bandit 600... badly. |
| sickpup |
 sickpup Old Timer
| Pete. |
 Pete. Super Spammer
| stinkwheel |
| sickpup |
 sickpup Old Timer
| Triton Thrasher |
 Triton Thrasher Could Be A Chat Bot
The last post was made 10 years, 130 days ago. Instead of replying here, would creating a new thread be more useful? |
