| jjdugen |
 jjdugen World Chat Champion
| Nobby the Bastard |
| jjdugen |
| bikenut |
 bikenut World Chat Champion
| dydey90 |
 dydey90 World Chat Champion
| MCN |
 MCN Super Spammer
| Ichy |
 Ichy World Chat Champion
| jjdugen |
 Posted: 18:33 - 29 May 2016 Post subject: |
Been out today, clattery valves not withstanding.
Its a '97 CBR900RR Fireblade. About 30,000 miles.
The shims in question are the inlets. 4 of them (no 3 no. 4 cyl.) are marked 2.10, measured as such on my micrometer.
These are tight, minimal clearance.
The next available smaller size is 2.05. This gives a slack fitting number 4 feeler guage. I will call these metric thous because no-one seems to know what the meteric number is.... miili cintimetres?
Therefore, logic would dictate that I need a shim of 2.07 thickness to give the correct clearance of 3 of these things.
As I can't seem to source a 2.07 shim, my original question was, can I cut up a number 2 feeler gauge to take up the slack?
Vote out, bring back furlongs and chains, threepeny bits and tanners, pints and gills, its what won us two world wars and the world cup, all downhill since then! ____________________ The CBR900RR has been sold. Aprilia Falco worms its way into my heart.
Try Soi 23 on Amazon for a good read.... Self promotion? Moi? |
| Nobby the Bastard |
| Ichy |
 Posted: 19:42 - 29 May 2016 Post subject: |
Only thing I can find is:
Intake: 0.13--0.19 mm
Exhaust:0.19--0.25 mm
I cannot find anything that refers to '3'?
I can honesty say that I have never heard of a number 4 feeler gauge.
0.1mm is a tenth and 0.01mm is a hundredth. 0.001mm is a thousanth of a millimetre or a micron. There you go, someone does know what they are called . ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
 Posted: 19:50 - 29 May 2016 Post subject: |
| jjdugen wrote: | Hi
Vote out, bring back furlongs and chains, threepeny bits and tanners, pints and gills, its what won us two world wars and the world cup, all downhill since then! |
"Thou" is only ever used to denote "thousandths of an inch". Don't use it for metric terminology because it'll confuse things. A thousandth of a mm is actually a micrometer but you can't use that either because it'll confuse people as to whether you are talking about a unit of measure or a tool for measuring.
The difference of 0.02 you get from .07 to .05 is not enough to make any audible difference as far as valve clearances go. Something you have done is wrong. ____________________ a.k.a 'Geri'
| lihp |
 lihp World Chat Champion
| lihp |
 Posted: 17:57 - 31 May 2016 Post subject: |
Any news on this. Intrigued to find out where this rattle has come from. ____________________ a.k.a 'Geri'
| CHR15 |
 CHR15 Turbo nutter bastard
 Posted: 21:01 - 31 May 2016 Post subject: |
are they over or under bucket shims? ____________________ Turbocharged drag thing / project death weapon / GK73A
Ste: I'm not entirely sure how you'd go about verbally abusing someone with a potato but I'm sure it's possible. |
| Hong Kong Phooey |
| mentalboy |
 mentalboy World Chat Champion
 Posted: 03:11 - 01 Jun 2016 Post subject: |
| jjdugen wrote: |
...And there, Sir, is your problem!
My 'blades of a similar age were both complete and utter C***ts to get the shims right. I think it had something to do with the fact that unless your torque wrench is absolutely spot on every time you pop the cams back on then that miniscule difference between stopping when the wrench goes click and stopping 5 degrees after it makes the difference between the same shim being tight, right or loose, don't ask me why it is but it was the only feasible explanation for getting different readings with the same shim...in, out, in, out, shake it all about, mutter, mutter, mutter.
All I can say is that I had those bloody shims in and out so many times in the end I said 'f**k it, that'll do'.
EDIT: And it was that way every time I took the bloody readings and decided to try to sort it out, both bikes gave the same problem. |
The last post was made 10 years, 119 days ago. Instead of replying here, would creating a new thread be more useful? |
