Strange mot advisories
Ebbs73
PostPosted: 20:54 - 07 Jun 2016    Post subject: Strange mot advisories Reply with quote
It's not a moan as it passed but ...
Took my 1979 cb250 super dream for an Mot 3 months early as I'm going to sell it .
Some of the advisories seem a bit odd , I'll list them all just to give balance as some are fair enough .
Chain and sprocket worn ( not excessively )
Exhaust is leaking but excessively
No chain guard ??
No neutral light ? ( it works so not sure )
Rusty mudguard ?
Foot rests worn ?
Gear lever pivot bush worn ?
First two are fair and I knew this but as I'm selling I'm not worried but the others .
Is he just filling it in to look like he's been busy checking it my bike over .
He did say don't worry as it's an old bike .
Just thought I'd share .
CaNsA
PostPosted: 20:59 - 07 Jun 2016    Post subject: Reply with quote
Whats the reg of the bike?
Ebbs73
PostPosted: 21:01 - 07 Jun 2016    Post subject: Reply with quote
FJH214V
thx1138
PostPosted: 21:03 - 07 Jun 2016    Post subject: Reply with quote
last advisory I got was worn wheel bearings
did another 1000 miles before I changed them
PostPosted: 21:03 - 07 Jun 2016    Post subject: Re: Strange mot advisories Reply with quote
Ebbs73 wrote:
Is he just filling it in to look like he's been busy checking it my bike over.
Probably as that is kind of how an MOT works. Wink
CaNsA
From https://www.check-mot.service.gov.uk/
Advisory notice item(s)
front mudguard has a crack and rust on the top of the brace.
offside Exhaust is leaking but is not excessively noisey (7.1.1b)
offside front upper Exhaust mounting deteriorated. (7.1.1.c)
no chain guard.
no neutral light.
all four foot rest stops worn,rear worn more than the front.
gear lever pivot bush worn.
Drive chain worn but not considered excessive (6.2.1e)
Fix it.
thx1138
PostPosted: 21:06 - 07 Jun 2016    Post subject: Reply with quote
CaNsA wrote:
Vehicle make: HONDA CRF 250 L-D
Date first used: 10 May 2013
Fuel type: Petrol
Colour: Red
MOT history of this vehicle
Test date: 26 March 2016
Expiry date: 25 March 2017
Test Result: Pass
Odometer reading: 6,901 miles
MOT test number: 6712 4799 9974
Advisory notice item(s):
rear Rear wheel bearings have slight free play (2.4.A.2c)
Mr. Green
slight free play, meh.
Ebbs73
PostPosted: 21:12 - 07 Jun 2016    Post subject: Reply with quote
If I was keeping it I certainly would but I want a shiney bike so I need the space , I'll put it in the advert what's needed .
He mentioned the bearing last year but nothing this year .
Just a couple seem very strange .
PostPosted: 21:14 - 07 Jun 2016    Post subject: Reply with quote
Which seem very strange?
Shaft
PostPosted: 21:20 - 07 Jun 2016    Post subject: Re: Strange mot advisories Reply with quote
No chain guard ?? - Not having a chain guard isn't a fail (having a loose one is) but it's not all that safe, so advise and pass.
Rusty mudguard ? - The steel mudguard incorporates a fork brace, if it's weakened by rust, it can be a fail, depending on how bad it is.
Foot rests worn ? - They are meant to be anti slip, if they are worn, they might be slippery, so not safe.
Gear lever pivot bush worn ? - This would fall under the scope of a defective machine control, again, could be a fail if it's bad enough.
Having lots of advises can be a PITA, especially if you're busy, you don't want to be writing the Magna Carta when you've got a queue. I'm pretty sure some of those don't a have a predefined entry, so he would have had to type them out manually.
All testers have different ways, I tend to mention it to the presenter if it's a single minor thing, or something I've noticed that isn't part of the test, others will put it on the certificate as a visual reminder.
But with a list, I'll put it on the cert just to be safe - better to have a record that you noticed it, than get hauled over the coals when something the presenter forgot you told them, breaks down the line.
Kawasaki Jimbo
PostPosted: 21:25 - 07 Jun 2016    Post subject: Reply with quote
Sounds like a good tester. Had you mentioned you were going to sell it?
Nobby the Bastard
Harley Gaydar
PostPosted: 21:27 - 07 Jun 2016    Post subject: Reply with quote
Registration number: G283PYC
Vehicle make YAMAHA Vehicle model FZR Date first used 16 June 1990 Fuel type Petrol Colour Blue
Test date 3 May 2016 Expiry date 2 May 2017 Test Result Pass Odometer reading 48,856 miles MOT test number 7958 6824 2047 Advisory notice item(s)
front Tyre worn close to the legal limit (4.1.3(ii))
Test date 11 April 2015 Expiry date 10 April 2016 Test Result Pass Odometer reading 42,324 miles MOT test number 2353 3170 5168 Advisory notice item(s)
Front Brake fluid reservoir fluid level low (3.2.B1d)
Test date 28 March 2015 Test Result Fail Odometer reading 42,168 miles MOT test number 9361 2708 5078 Reason(s) for failure
Steering movement excessively 'notchy' with the wheel raised (2.2.1b)
Nearside Headlamp aim too low (1.6)
Offside Front shock absorber seal failed and leaking oil (2.3.3)
Rear Roller brake test indicates a binding brake (3.3.A1a)
Steering headbearing has slight free play (2.2.2)
Rear Brake pad(s) close to minimum limit (3.2A1f(ii))
Rear Brake disc(s) slightly worn (3.2.A1l)
Razz
Triumph Sprint ST 1050
Ebbs73
PostPosted: 21:31 - 07 Jun 2016    Post subject: Reply with quote
The chain guard , didn't really take much notice it didn't have one , but now I stands out , worn pegs and the mudguard , it's a chrome one that's had better days but it's solid as a rock and the neutral light , seems a strange few for advisories .
I'm not moaning though , just I've never had anything close to them before .
He's a nice bloke , I always go there .
I didn't mention I was selling , I wondered off and had a full English .
Chris
thx1138
PostPosted: 00:02 - 08 Jun 2016    Post subject: Reply with quote
Razz
Is it wrong that I want to see who can get the most advisories and applaud?
CaNsA
PostPosted: 00:11 - 08 Jun 2016    Post subject: Reply with quote
Just remember that if we can get all the MOT info on your bike, then so can everyone else.
Ebbs73
PostPosted: 00:52 - 08 Jun 2016    Post subject: Reply with quote
Of course , I'll paste the advisories up in my ad , I'm not that type of seller .
Im sure most wouldn't be scared of that list .
Roll up roll up , cb250 for sale .
Suntan Sid
PostPosted: 07:07 - 08 Jun 2016    Post subject: Reply with quote
On my bikes previous MOT the only advisory was:-
"Rear reflector not central"
It actually had two reflectors, one either side of the centre line of the bike, I ignored it.
The same bike passed this years MOT with the same reflector arrangement but no advisories, go figure!
Andy_Pagin
PostPosted: 08:05 - 08 Jun 2016    Post subject: Reply with quote
"Misty forks" Confused ....
Sounds like a 1970s country music singer.
So I immediate changed my MOT centre forks have been fine ever since.
andyscooter
PostPosted: 08:10 - 08 Jun 2016    Post subject: Reply with quote
strangest one I had was either one washer jet wasn't working on the car
had a look under the bonnet and found the pipe wasn't joined so I put a bit of oversized pipe on it to join them works spot on now
or it failed for having a different size tyre on it once
I'm guessing they put different tyres on at some point and had to use the spare which had the oe tyre on
Snowdonia Rider
PostPosted: 08:34 - 08 Jun 2016    Post subject: Reply with quote
I'd bin them ( the MOT centre), they're obviously trying to con work out of you. I had this on a car once, it got an advisory for wheel bearings. Weird I thought, as there were no signs of wheel bearings going. I did 8k in that car before it had it's next MOT, it went to the same place and the same bloke tested it. Passed with no mention of wheel bearings, he obviously forgot what he lied about a year earlier Rolling Eyes After an extra 8k those bearings should've been worse, right?
Snowdonia Rider
PostPosted: 08:44 - 08 Jun 2016    Post subject: Reply with quote
Oh yeah my GSX had this in 2008, OK it was off the road for years (by previous owner) and it hasn't done many miles since, but it hasn't been picked up on an MOT since.
Test date5 April 2008
Expiry date4 April 2009
Test ResultPass Odometer reading24,468 miles MOT test number1207 1619 8469
Rear shock absorber has a slightly reduced damping effect (2.4.A.3b)
DrDonnyBrago
PostPosted: 09:28 - 08 Jun 2016    Post subject: Reply with quote
7 MOTs ago I had an advisory for play in the rear shock.
Naturally, I did nothing and haven't heard anything of it since.
Teflon-Mike
tl;dr
PostPosted: 09:57 - 08 Jun 2016    Post subject: Reply with quote
I got an advisory for front wheel bearings being 'out of tune'...
Eh?
"Well they make a noise..." He said... "but it's not very melodious...
- you can grease'em
- you can change'em
- or you could try teaching them the score of Sgt Pepper's... your call, really!"
I think it was a 'slow' day for him!
He gives the Seven-Fifty the same Advisory every year "Handlebars rusty"; Otherwise only one I ever seem to get off him on any of the other bikes is "Tyres are old"
thx1138
PostPosted: 15:46 - 08 Jun 2016    Post subject: Reply with quote
wouldn't that be a cb250n for sale?
The last post was made 10 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.09 - MySQL Queries: 16 - Page Size: 141.6 Kb
