Why is my laptop so F**ked?
Clutchy
PostPosted: 10:40 - 09 Jul 2016    Post subject: Why is my laptop so F**ked? Reply with quote
It's so slow and laggy recently, about two weeks ago it was doing the same thing so I CCleanered it, defrag, changed anti virus, full scan etc.
Worked fine for a week or so and now its back and really slow.
What can I do? See attached picture...
https://i.imgur.com/nMpqjdF.jpg
Thanks!
ferrisio
PostPosted: 11:19 - 09 Jul 2016    Post subject: Reply with quote
Looks like you need more RAM..
BMW R1100R
J.M.
PostPosted: 18:12 - 09 Jul 2016    Post subject: Reply with quote
Looks like you need less Windows
2004 R1 & 2018 XSR900
Fin
PostPosted: 18:35 - 09 Jul 2016    Post subject: Reply with quote
Turn off windows update, stop anti-virus, turn off indexing and scheduled tasks. Could get an SSD too because the speeds on your hard drive seem very slow.
Actually you just need more RAM or less windows Laughing I'm using 2.8gb at the moment.
Andy_Pagin
PostPosted: 19:34 - 09 Jul 2016    Post subject: Reply with quote
Download a Linux Live .iso file, burn to DVD (or CD if machine is ancient)
Boot as Linux from the cd, this won't install anything. Try doing some stuff that lags under Windows.
If it's still laggy then it's a hardware problem. If not it's decision time, either bung more of what Windows guzzles into the crate, or consider a change to Linux.
Linux Mint is probably the best choice for this exercise, especially if you're not familiar with Linux.
Going
PostPosted: 22:53 - 09 Jul 2016    Post subject: Reply with quote
Andy_Pagin wrote:
Download a Linux Live .iso file, burn to a USB (DVD or CD if machine is ancient)
Fix for you.
There are a few light weight Linux versions that are meant to be booted from USB/CD etc that may run better than mint if not installing to a hard drive.
For the young ones that see this in a few years after using the Thought Enhanced Search.
CD = Compact Disc
DVD = Digital Versatile Disc
USB = Universal Serial Bus
c_dug
PostPosted: 22:57 - 09 Jul 2016    Post subject: Reply with quote
Going wrote:
Fix for you.
It has 2Gb of RAM, it's probably ancient enough to have a floppy drive!
UncleFester
PostPosted: 08:12 - 10 Jul 2016    Post subject: Reply with quote
Looks like Win10 downloading in the background.
2017 Z1000SX
PostPosted: 15:46 - 10 Jul 2016    Post subject: Reply with quote
Too much porn.
notbike
PostPosted: 17:48 - 10 Jul 2016    Post subject: Reply with quote
Check drivers are up to date, could be a memory leak caused by out of date drivers (if it ain't a hardware issue).
My killer network driver does this shit sometimes when its out of date and half my ram is suddenly unable to cache properly.
Quick and easy way to do this is with Driver Booster 3. I got a free premium key if you want it.
colink98
PostPosted: 08:18 - 11 Jul 2016    Post subject: Reply with quote
Its the 100% disk usage that is killing it.
you need to find out what is causing that and deal with it.
ferrisio
PostPosted: 11:36 - 11 Jul 2016    Post subject: Reply with quote
Well, the 91% memory usage is the clue. It's almost certainly swap file usage that's maxing out the disk usage. Hence, get more RAM!
BMW R1100R
colink98
PostPosted: 14:47 - 11 Jul 2016    Post subject: Reply with quote
Not as simple as that I'm afraid.
more than enough reports of Windows 8/8.1/10 all suffering from bouts of 100% disk usage.
adding more memory (while a good thing) is unlikely to cure this particular issue.
https://www.reddit.com/r/techsupport/comments/3h4wjg/windows_10_high_disk_usage_100_ive_seen_a_thread/cu4nz2y
Loui5D
PostPosted: 16:20 - 11 Jul 2016    Post subject: Reply with quote
You're right on the minimum RAM for the newer windows.
Try disabling Aero and see what that does.
adriansk
PostPosted: 09:51 - 13 Jul 2016    Post subject: Reply with quote
MSCONFIG - Disable all start up programs except antivirus.
CBR600F4
Jayy
Mr. Ponzi
PostPosted: 10:33 - 13 Jul 2016    Post subject: Reply with quote
Install Pokemon Go, it will solve all your problems... and more.
Fin
PostPosted: 21:44 - 13 Jul 2016    Post subject: Reply with quote
you could use a usb stick for extra ram (readyboost) as windows calls it, doubt it would speed up your computer that much but I used to leave a 4gb stick in the back of a shit computer. Actually my college usb is tiny, you wouldn't notice it in a laptop.
J.M.
PostPosted: 22:49 - 13 Jul 2016    Post subject: Reply with quote
If using a USB as extra RAM actually helps anything there are more serious problems at bay. USB access speeds are hideous in comparison to RAM.
What do you actually need Windows for? If there is nothing specific, I wouldn't bother.
johnsmith222
PostPosted: 12:42 - 15 Jul 2016    Post subject: Reply with quote
2gb of RAM is no longer enough. 4gb is the minimum acceptible amount for an old computer with windows 7 imo.
If you can, try and upgrade to 8gb of ram. Download speccy and use that to find out what the correct type of ram it is, and find some on ebay.
I also advise opening up the laptop, just to make sure, as speccy reports 2 extra slots for my laptop, than there actually is.
ninja_butler
PostPosted: 20:47 - 22 Jul 2016    Post subject: Reply with quote
I agree 2B of RAM isn't enough, but I am also wondering how old the hard drive is, it might be wearing out. Even a low-budget SSD drive should help with start-up times compared to a mechanical disk drive.
Andy_Pagin
PostPosted: 10:17 - 23 Jul 2016    Post subject: Reply with quote
Agreed, unless you're using it for gaming or something only available on Windows then at least take a look at Linux. Linux is way way more efficient in resource usage than Windows and has the added advantage that any application you could possibly want is available for free.
An easy way to try Linux without committing yourself is to install VirtualBox, then download a Linux .iso image and install it into VirtualBox. You can then run Linux as if it was the 'real' operating system. Nothing changes in reality and your machine will still boot as a Windows box. Obviously performance won't be great since it's running on top of an iffy Windows setup, but at least you get a feel for Linux, and can ditch it if you don't like it.
Sample resource usage, currently I'm running, Firefox, Evolution (email) and a Libreoffice spreadsheet, total memory usage is 1.5Gb, zero swap file about 5% CPU.
J.M.
PostPosted: 11:09 - 24 Jul 2016    Post subject: Reply with quote
I think that given his current memory situation, a virtual machine could perform really badly. Instead, in this specific case, I'd recommend a persistent live USB. Very easy to create and the full system's resources will be available to test with.
If the HDD is a decent size, OP could even just go straight to dual-booting. A distribution like Ubuntu makes a dual-boot setup very easy to get running. I imagine others may do too, but I don't have experience with many distros.
Andy_Pagin
PostPosted: 11:17 - 24 Jul 2016    Post subject: Reply with quote
Quite right, silly me. Obviously OP can boot a Linux Live system from a USB. I wouldn't dive headlong into dual boots though. Try a few Linux distros first, OP may not like Ubuntu, or any of the alternatives for that matter.
Clutchy
PostPosted: 12:47 - 19 Aug 2016    Post subject: Reply with quote
I actually have 4gb of RAM, not entirely sure why it was saying 90 odd percent was being used.
I removed AVAST anti virus and a load of other programmes and it seems to be working fine now. Just using windows defender Shocked
Sorry I didn't see all the replies, thank you all for your help.
Going to upgrade soon anyway.
Alpineandy
PostPosted: 13:20 - 19 Aug 2016    Post subject: Reply with quote
Wafer_Thin_Ham wrote:
Too much porn.
That's one of those things where it's impossible to have too much of it ! Laughing
The above comment isn't necessarily the truth and anyone that says it is, is only correct if it's the truth or they're bigger than me.
The last post was made 9 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> The Geek Zone All times are GMT
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.4 - MySQL Queries: 14 - Page Size: 128.14 Kb
