Lightweight (Airportable) Landrover rebuild.
Bike Chat Forums Index -> Show & Tell Goto page Previous  1, 2, 3, 4, 5, 6, 7
sickpup
Old Timer
PostPosted: 09:13 - 24 Jul 2016    Post subject: Reply with quote
Came off shift yesterday morning so slept all day and last night I got the pressure washer out and did some cleaning, not only of the underside of the truck but also the drive underneath it.
It was just a preliminary clean to get as much off as possible before I spray it down with Gunk degreaser and do it again. When I do this I'll have the wheels off as well so the hubs and drums can be cleaned down.
Chris
Unfortunately no way to get it to somewhere to clean underneath so I just have to do it myself and continue working in the accumulated muck.
sickpup
Old Timer
PostPosted: 19:05 - 24 Jul 2016    Post subject: Reply with quote
The main gearbox is now refilled and the overdrove box is drained and refilled.
With the cleaner underneath I was able to look closer at the prop gaitors, they look like they don't need changing but the grease nipples will need cleaning so the UJ's can be greased.
The UJ on the rear prop that connects to the gearbox may need to be replaced as there is some play in it but we will look closer at it.
sickpup
Old Timer
PostPosted: 23:27 - 01 Aug 2016    Post subject: Reply with quote
The rear cross member
I was bored again today so had a look at the rear cross member, it was in a terrible state.
After undoing the bolts holding the bumperette on the right side on it literally fell apart
This shows how rough it looked.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/20160801_131524_1470061035713.jpg
Some of the detritus that fell out of it.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/20160801_131531_1470061035566.jpg
After unbolting it from the rear tub it pretty much just fell off.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/20160801_132546_1470061035446.jpg
https://i945.photobucket.com/albums/ad297/750RK/LandRover/IMG-20160801-WA0011.jpg
The remains show just how bad it was.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/20160801_132605_1470061035170.jpg
Tomorrow we do the other side.
ADSrox0r
PostPosted: 11:49 - 02 Aug 2016    Post subject: Reply with quote
Heh, there has to be some irony to the fact that you had two whacking great chains to secure the vehicle attached to that.
PostPosted: 12:02 - 02 Aug 2016    Post subject: Reply with quote
it looks like wet cardboard Laughing
lozzypop1
Certified MILF!
PostPosted: 21:57 - 03 Aug 2016    Post subject: Reply with quote
Actually, it was just a convenient place to hang stuff. (That wasn't in my kitchen Laughing )
sickpup
Old Timer
PostPosted: 21:41 - 02 Dec 2016    Post subject: Reply with quote
Not really thought about posting much recently, sort of stuck in a rut with it at the moment. When I have time to work on it, its too cold outside, rest of the time I'm working.
The cross member is now fully removed and I am in the process of trimming the chassis ends. found out after removal that the chassis end rails are flared out so I have to do something about that so the new cross member extensions will slide over the ends. I also have to remove a load of chassis underseal so we have clean metal to weld to.
After stripping out the few remaining door seals I have started to replace them only to find the ones for the windscreen to door are the wrong type and cause the door top to bulge out so I am trying to find the correct type which is a little hard without a parts fiche or parts book which isn't available. The only one that is available is incomplete.
Will try and sort some pictures later.
On the plus side I am having driving lessons so I can get my license.
sickpup
Old Timer
PostPosted: 22:40 - 04 Dec 2016    Post subject: Reply with quote
The door seals are made of two parts, the foam rubber seal and a metal strip that slides inside it.
The seals are avaiable to buy but the metal strip isn't so I had a word with a local engineering firm who cut 12 metre long stainless steel strips for me for £5.
The seals are riveted to the body work so need holes drilled in them, not the easiest thing to do with stainless, the drill tends to catch and twist the strip and if you are holding it cut your hands to ribbons so its important to wear leather gauntlets while drilling for protection.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/20161204_185846_1480886194598.jpg
Marked and punched up strip.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/20161204_180442_1480874732307.jpg
Drilled strip.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/20161204_211545_1480886194089.jpg
The strip is then used to mark up holes to drill through the foam rubber seal and slipped inside.
mentalboy
PostPosted: 01:17 - 05 Dec 2016    Post subject: Reply with quote
Hint for future drilling of thin metal strip - Put a piece of gash wood on the floor, place metal strip on the wood, stand on it and then drill using a hand held power drill rather than a drill press. The wood provides a stable work surface that won't wreck your drill point. Never again will you suffer lacerations/amputations caused by high speed spinning thin metal strip Smile
Make mine a Corona.
sickpup
Old Timer
PostPosted: 15:54 - 05 Dec 2016    Post subject: Reply with quote
A quick explanation of how the seals are fitted.
This is the part of the body panel where the seal fixes to. Its flat with a lip as a retainer.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/20161205_140541_1480948066525.jpg
As discussed the drill strip is placed inside of the foam rubber seal and the foam drilled.
The rivets are fitted through the seal and then into the body work and pushed into place using the rivet gun. An air riveter is used as this means you can push the rivet hard through the seal.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/20161205_140819_1480948049662_1.jpg
Pull the trigger and the rivet is compressed and finished.
After all the rivets are fitted it looks like this.
https://i945.photobucket.com/albums/ad297/750RK/LandRover/20161205_141417_1480948049079_1.jpg
Johnnythefox
PostPosted: 16:38 - 05 Dec 2016    Post subject: Reply with quote
my first (and only missed) car was one of Leylands finest, a 1275gt clubman. denim blue.... this thread is a joy to read.
There is a gap of 2 years, 95 days between these two posts...
sickpup
Old Timer
PostPosted: 00:38 - 11 Mar 2019    Post subject: Reply with quote
Time for an update.
After the rear cross member was removed I discovered the corrosion goes all the way forward to the rear right spring hanger. This means I either have to plate the chassis which is risky and would need the spring hanger cutting off and a new one fitting or to buy a 1/4 chassis where the chassis rails go further forward on the chassis.
https://cdn.bcf.44bytes.net/files/rear_chassis.jpg
sickpup
Old Timer
PostPosted: 14:44 - 12 Mar 2019    Post subject: Reply with quote
Here is the new galvanised 1/4 chassis complete with spring hangers. The bushes were included and already fitted. £180.12 delivered.
https://www.bikechatforums.com/files/rear_chassis.jpeg
sickpup
Old Timer
PostPosted: 14:34 - 13 Mar 2019    Post subject: Reply with quote
Heres a clearer picture of the corrosion on the back of the chassis. As you can see the corrosion is all the way to and behind the spring hanger so we could remove the hanger, plate behind and fit a new one but we may as well just fit a 1/4 chassis wth all new metal.
https://cdn.bcf.44bytes.net/files/20190313_132821_resized.jpg
Before we can fit the 1/4 chassis I will have to cut the chassis right back, remove the underseal and then remove the wiring loom from the chassis rail as otherwise it will melt during welding. The rear tub will also need removing once the chassis sides have been tacked in place so the top can be weled without melting the aluminium tub floor.
BTTD
PostPosted: 15:02 - 13 Mar 2019    Post subject: Reply with quote
£180 for a galvanized quarter chassis. Laughing
As classic car ownership goes, Landy's have got to be amongst the cheapest to restore.
sickpup
Old Timer
PostPosted: 15:06 - 13 Mar 2019    Post subject: Reply with quote
I was talking to Fisty about this yesterday and he was surprised how cheap the price was.
When you consider a set of front SBS pads for his ZX10R caliper equipped Busa is £90 yes its an absolute bargain.
There is a gap of 1 year, 139 days between these two posts...
sickpup
Old Timer
PostPosted: 10:40 - 30 Jul 2020    Post subject: Reply with quote
Now the ER6 is doneand the head races on my Deauville runaround are done I've had some time to do a bit more work on the LW. I'm just taking things apart at the moment in preparation for reassembly work.
Headlights on older British vehicles were very different to what are fitted to modern vehicles.
Where modern vehicles have the headlight bulb removed from the rear older vehicles had things like sealed beam units where the whole headlight was the bulb or they used a removable headlight with a headlight bucket behind so you had to remove the headlight to get the bulb out the back.
In the case of the lightweight it has a bucket type headlight with spring loaded bolts so to replace the bulbs you push the headlight in and rotate it a few degrees and the whole headlight pops out.
On the lightweight up until they stopped making them in 1984 they use1d a BPF (British Pre Focus) bulb. As these are pretty crap virtually everyone replaces them with Halogen conversions which only requires changes the lens complete with reflector and only costs around £12 per side. Mine also needs the buckets changing due to corrosion so half an hour with a grinder and you end up with this.
https://cdn.bcf.44bytes.net/files/headlight_view.jpg
The headlight fittings use 2BA threads so before I reassemble I need to clean out the threads so I'm now waiting for a new die, plug and taper taps to arrive.
I also spent some time removing a rear spring hanger off a leaf spring. Not the easiest thing to do after 35 years on a vehicle but my Dewalt 18v impact made it very easy.
You always have to be careful with these because they are under sprint pressure from either the leaf spring or from the twisted bushing.
https://www.bikechatforums.com/files/img-20200729-wa0017.jpeg
I also removed the silencer as it has rotted internally. Again the Dewalt impact made easy work of removing the bolts.
As the exhaust pipework is no longer held in place this has shown a problem with where the front pipe enters the manifold, it's rotten so the whole exhaust will need changing.
https://www.bikechatforums.com/files/img-20200729-wa0015.jpeg
I've had a chat with a local scrap merchant who is happy to now take all of my scrap metal which has made disposal a lot easier and made my other half a lot happier. As most of the parts on this are metal they aren't the easiest to dispose of when you don't have a car.
Valentino Mossy
PostPosted: 23:04 - 28 Oct 2020    Post subject: Reply with quote
.......is it done yet ?
Cool
sickpup
Old Timer
PostPosted: 09:40 - 07 Nov 2020    Post subject: Reply with quote
Cool
Not yet, how you getting on with the air cooled beetle?
The last post was made 5 years, 295 days ago. Instead of replying here, would creating a new thread be more useful?
Page 7 of 7
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 111.59 Kb
