| sr7492 |
 sr7492 L Plate Warrior
 Posted: 15:27 - 19 Aug 2016 Post subject: Honda CBF125 Brake light Always on |
Hi BCF,
First post, passed my CBT a couple of weeks ago and went and bought a 125 over the weeked.
Buzzing to be part of the biker group . . . plan is to get both Mod 1 & 2 in the coming months and nice 600
Anyhow, the Honda 125 I bought has a slight issue with it, when you press the rear brake, the brake light constantly stays on.
Apprently the switch is 'sticky' - I'm very much learning the ropes here so can you help in terms of me getting it sorted?
Easy fix?
Appeciate all comments and help so thank you in advance. |
| Commuter_Tim |
 Commuter_Tim World Chat Champion
| ScaredyCat |
 ScaredyCat World Chat Champion
 Posted: 16:24 - 19 Aug 2016 Post subject: |
Look at the back of the brake lever, there's a spring and an adjuster. They often get full of road crud, give it w clean and a bit of lubrication. Also make sure it's attached at the other end
https://dl.dropboxusercontent.com/u/188253/_bcf/cbf125_spring.png ____________________ Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple |
| sr7492 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 13:18 - 22 Aug 2016 Post subject: |
It's a very simple mechanical switch - cleaning it should be sufficient.
It may need adjusted though. There will be a big nut or two on it that controls the height that the switch is held at. If you adjust the nuts to move the switch down a fraction and release a little tension on the spring, the brake light should go off. ____________________ Biking is 1/20th as dangerous as horse riding.
| sr7492 |
The last post was made 10 years, 65 days ago. Instead of replying here, would creating a new thread be more useful? |
