| Hahadumball |
 Hahadumball World Chat Champion
| dransy |
 dransy World Chat Champion
| Rogerborg |
 Rogerborg nimbA
| MarJay |
 MarJay But it's British!
| P.addy |
 P.addy Red Rocket
 Posted: 09:00 - 23 Aug 2016 Post subject: |
Get all technical, wire all of the lights that should come on and go off into the circuit that shows the battery warning light.
That only comes on at the beginning and then turns off.
If all the lights come on, you treat it like an engine management fault.  |
| Pjay |
 Pjay World Chat Champion
| dydey90 |
 dydey90 World Chat Champion
 Posted: 10:12 - 23 Aug 2016 Post subject: |
| MarJay wrote: | ESP should be OK. There are some which will fail an MOT such as ABS, Air bag etc, but I doubt ESP would fail an MOT anyway. |
Would probably still appear as an advisory though, which won't look good if there's a chance of selling the car inside of the year.
| Paddy. wrote: | Get all technical, wire all of the lights that should come on and go off into the circuit that shows the battery warning light.
You've done this before, haven't you. ____________________ This post is probably not serious and shouldn't be taken literally.
Past: CBR125,ER6f NINJA 650, ZZR600 Current: VFR750 |
| Rogerborg |
 Rogerborg nimbA
 Posted: 10:13 - 23 Aug 2016 Post subject: |
It should do. Actually, removing the bulb should be a fail as well.
https://www.gov.uk/government/uploads/system/uploads/attachment_data/file/518634/mot-inspection-manual-for-class-3-4-5-and-7-vehicles.pdf
3.4 Anti-Lock Braking and Electronic Stability Control Systems
Electronic Stability Control Systems are commonly referred to as ESC, but may also be known as ESP or some other acronym
Method of Inspection
1. If the vehicle is fitted with an ABS and/or ESC
system, check that the relevant warning
lamp(s):
a. is fitted
b. illuminates
c. does not indicate a fault
Reason for Rejection
1. A warning lamp:
a. is missing
b. does not illuminate
c. indicates a fault ____________________ Biking is 1/20th as dangerous as horse riding.
| P.addy |
 P.addy Red Rocket
| Monkeywrenche... |
 Monkeywrenche... Nearly there...
| P.addy |
 P.addy Red Rocket
| Wonko The Sane |
 Wonko The Sane World Chat Champion
| Hahadumball |
| MCN |
 MCN Super Spammer
The last post was made 9 years, 323 days ago. Instead of replying here, would creating a new thread be more useful? |
